Old 02-08-2013, 12:22 AM   #15
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
You can't just look at the number because the brands are different. 215 star specs are as wide as 225 stock michs. Sounds from the above guys that the PSS are wider as well.
Khyron686 is offline   Reply With Quote
Old 02-08-2013, 09:16 AM   #16
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Originally Posted by DanoFA20 View Post
im probably going with a 225/40/17 thinking about continental DW summer tires i hear good things. good tractin in wet and dry good tread life and they are roughly 120$ per tire which isnt bad.
maybe a tire guru can chime in see if im correct or not.
Yeah, the sidewall calculations show not too much difference, a bit high, a bit low depending upon section ratio choice.
Azenis has changed their tread design and compound, and has fallen far from where it was in the mid-2000's, but much stickier than a all-season. Check out vulcantire.com for current pricing, usually pretty reasonable.
Most of the tires I have spoken about aren't great in heavy rain, and pretty sad in any snow, so caveat emptor.
As for the Conti DW's, check out the Nitto Invo's for complete tire 'rotationability.'
With respect to all seasons/non-stickies, check out the Kuhmo Ecsta 4x. A bit cheaper, I put a set on my Focus SVT before my 5k summer trip and was waaaaay happy with them, and I believe according to tirerack, they scored better than the conti's, IIRC.
Eric G
mkiisupra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkiisupra For This Useful Post:
chaoskaze (12-23-2015), DanoFA20 (02-08-2013)
Old 02-08-2013, 10:09 AM   #17
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
This. You will find some varience from manufacturer to manufacturer.
Chimpo is offline   Reply With Quote
Old 02-08-2013, 11:55 AM   #18
jeebus
I'm just about to order some Conti DW in stock size for the stock rims. No increase in weight, a lot more grip...sounds good to me.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
DanoFA20 (02-10-2013)
Old 02-08-2013, 12:23 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by ayau View Post
Personally, I'd stick with OEM 215. Your speedometer will be more accurate.
It's normal for most cars speedometers to read ~5% high, because in Europe, the regulation is that you're allowed to read 10% high, but not allowed to read lower than actual speed.
So, speedo most likely *is* more accurate with 225/45-17s. But odometer most likely will read low...
If you're looking for maximum grip, you shouldn't be looking at Michelin PSS tires to begin with.
If you're looking for maximum wet and dry grip on the street, and aren't in cold/snow conditions, PSS is probably the best choice.
Strictly dry grip, Dunlop Direzza ZII and BFG Rival probably have more.
But on the street, PSS is up there with *Spec, RS3, AD08 in the dry, and much better in the wet:
http://media.caranddriver.com/files/...res-tested.pdf
I doubt you'd feel a difference between 215 and 225 under 95% of your driving conditions.
Agree. 225 adds weight, ride height and not as good a fit on the rim. Should give *slightly* more dry grip, but you'd never notice on the street, and you'd need a stopwatch and super-consistent driving to notice at autoX or track.
Old 02-08-2013, 06:54 PM   #20
sierra
Drives: Skoda Yeti DSG diesel 4x4
You might want to read this post first?
http://www.iwsti.com/forums/3302084-post1.html
sierra is offline   Reply With Quote
Old 02-08-2013, 10:03 PM   #21
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
but you have to also consider that the twins weigh ~2800 lbs and an STI is 3400 lbs
that's going to make a big difference, and not to mention that brz/frs have stiffer springs vs weight vs the sti
dori. is offline   Reply With Quote
Old 02-08-2013, 10:04 PM   #22
jpit
Drives: Subaru BRZ
That post is for the Conti DWS - all season tires. He eventually changes over to the DW and thought they were great.
jpit is offline   Reply With Quote
Old 02-09-2013, 12:47 AM   #23
sierra
My mistake. I thought you had just left the S off.
I'll check them out.
Old 02-10-2013, 09:56 AM   #24
immortal_suby
Drives: 2015 BRZ Limited 6MT
Anyone have experience with the 245/40/17 on a stock rim. Will they fit without rubbing?
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 02-10-2013, 10:11 AM   #25
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
i think 245 is too wide for a 7inch wheel boss. 225 would be the max. my e36 m3 comes stock with 7.5 front width 8.5 rear it was 245/45/17 225/45/17 front
id saygo with a 225/45/17 or 40/17
DanoFA20 is offline   Reply With Quote
Old 02-10-2013, 10:15 AM   #26
DanoFA20
Shift Down
DanoFA20's Avatar
idk ive had a lot of experience with those tires and they are really good. but idk an sti is a completely different car than most of the FR cars ive driven. id say teh DW is a good tire for the price. but id say go with something like my fail safe Toyo Proxys or bfg kdw loud road sound but amazing grip
Old 02-10-2013, 04:06 PM   #27
djliquidsteele
Drives: Scion FR-S
I've decided to go with 225/45/17. Looks like this size come stock on quite a few cars with 17x7 wheels. It's more of a look thing for me than additional grip.
djliquidsteele is offline   Reply With Quote
Old 02-10-2013, 05:20 PM   #28
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
show us some pics if you get a chance
Gearhd79 is offline   Reply With Quote
Tire +/- size guide for FR-S/BRZ SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 12-11-2016 12:12 PM
Tire size advice Lost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-28-2016 06:42 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 12:04 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
A Simple Tool for Tire Size DIE1000DEATHS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-30-2012 05:05 PM
