| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Wheel Spacer Size??
Hi, what spacer size would you recommend for stock wheels with Eibach Sportline lowering springs? Brand?
#2 |
Wannabe JDM Type S
Drives: 2013 BRZ Limited
I like my setup. check it out!
My Wannabe JDM Type S build: http://www.ft86club.com/forums/showthread.php?t=24702
| The Following User Says Thank You to ZC6BRZ For This Useful Post: | tonytduc (02-08-2013) |
#3 |
Drives: BRZ Limited
www.ft86club.com/forums/showthread.php?t=28317
Check out my setup, I have 20mm project kics spacers 4 wheels, should be with any lv of lowering needs |
| The Following User Says Thank You to hypermax For This Useful Post: | tonytduc (04-20-2013) |
#4 |
Drives: Subaru BRZ Limited
Bump on this.
I'm new to modifying my car. I ordered some Eibach Sportline Springs after reading some good reviews. I had no idea I was going to need spacers. I definitely want the wheels flush to the body of the car. From the above post I'm assuming that 20mm is the cleanest option? I was looking at the Eibach Spacers. Is there another brand you'd recommend? Also, what else am I going to need with the Sportline Springs? This car is just my DD and I don't do any track time. I'm simply lowering the car to get rid of wheel gap. I've read a lot about needing struts, dampers, and a bunch of other additional parts. Is this true even if I'm only using it as a daily driver? |
#5 |
20-25mm "ADAPTERS"
They bolt up to the wheel hub, you won't need to put in longer hub bolts with adapters... Make sure you get hubcentric ones... |
#6 |
So Adapters are different from Spacers because it'll let me use the same bolts?
Where can I find those? Do you have a link? I'd like to avoid purchasing the wrong item. I think I found them on Eibach: Widen Your Stance—For Better Handling Made from High-Strength Aircraft-Aluminum Alloy Precision Engineered Hub-Centric—for Perfect Fit and Wheel Balance Reduced Weight Compared to Steel Wheel Spacers Kit Includes 2 Spacers and all necessary mounting hardware Million-Mile Warranty Geez, $200 for a set of 2??
#7 |
Time Traveller
I bought the b2autodesigns BRZ spacer/adapter kit for my FRS. The spacers are hubcentric and B2 is a vendor on the board. They shipped FAST. Got spacers from FL to CA in 2 days. I was very happy with the purchase.
http://www.ft86club.com/forums/showt...ghlight=b2auto Then I dropped it on RS-R SuperDowns yesterday, it looks OEM+++ and I'm quite happy. Car is being detailed today, but here is a pic I snapped late last night. Specs: 20mm front 25mm rear -1" front -1.125' rear (as of this morning)
| The Following 5 Users Say Thank You to DAEMANO For This Useful Post: | b2autodesigns (08-03-2013), ericmpena (08-02-2013), garfull (05-06-2014), MJones_RB (09-11-2015), Tristor (03-27-2018) |
#9 |
Which size do you recommend? I'm sure you've seen the FRS Concept before. I love how flush the wheels look on that car! What size would get me similar to this?
http://www.thedetroitbureau.com/2011...rs-86-concept/ |
#10 |
Drives: 2013 Subaru BRZ
im running 20mm front 30mm rear. Perfectly flush with the fenders on stock wheels.
#11 |
Thanks. Sounds dumb but I would'nt have realized the back fender is wider. Thanks for the heads up! Can't wait!!
I went by the dealership today and the actually have a black BRZ Limited with 18" black rims, on Eibach Pro line springs. It looked pretty sweet, but there was still a good 2 finger gap. It's not much, but I think the half inch more from the Sportline will look a little nicer in my eyes. Just gotta order those spacers and then I'm all set!! |
#12 |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
20mm/30mm will get you perfectly flush with the stock wheels/offsets and a 1" drop. Ask around for yourselves but consensus seemed to be H&R made the best spacers.
| The Following User Says Thank You to mit_peid For This Useful Post: | Ryan_86 (05-01-2016) |
#13 |
Drives: 1991 Galant VR4
Just a little info on our spacers guys.
Specs: Aluminum/Magnesium alloy mix. 1pc design. Hub centric to FRS/BRZ. High quality nuts and stud bolts. Easy bolt on. Sizes are 15, 20 and 25mm We have been selling these spacers for over 2 years. There is some feed back on many different forums. Check my post for some feedback from customers. Also installation video. http://www.ft86club.com/forums/showthread.php?t=37407 ![]() These fit perfect with factory wheels. Aftermarket wheels will need to have the whole in the back of the wheel to fit. Feel free to message me with any questions. Thanks Charles |
| The Following 3 Users Say Thank You to b2autodesigns For This Useful Post: |
#14 | |
Thanks for the information. I went ahead and ordered from your site. I got the 20/25 set. Can't wait to receive them! |
| The Following User Says Thank You to ericmpena For This Useful Post: | b2autodesigns (08-06-2013) |
| Wheel Size vs. Balance | jellygorilla | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 09-11-2012 01:23 PM |
| wheel spacer to 5x114 | derka-derka | AUSTRALIA | 12 | 07-02-2012 11:27 PM |
| Wheel Hub Bore Size | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-08-2012 12:01 AM |
| Wheel size and fitment | bsclywilly | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 03-27-2012 12:34 PM |
| Wheel size, what's your opinion? | #87 | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 02-24-2010 03:06 PM |
