Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 02-05-2013, 11:36 PM   #127
Guaruja
Drives: A few...
Anyone seen this kit anywhere else for sale?
Guaruja is offline
Old 02-06-2013, 12:25 AM   #128
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Why would you want to buy anywhere else?
Price is good, service excellent, delivered in 5 days......
Ryan86 is offline
Old 02-06-2013, 01:27 AM   #129
jwbrocloud
Drives: Raven MT
Originally Posted by F-T View Post
I would think that would work, Thats a nice idea. I was thinking about installing a custom one so that the lights arent on all the time. This is something to look into.. Thanks!
I like it but I can't figure out where you would mount the switch in the FRS though... I thought it would be next to the trunk open button but there isn't an empty space there like it was meant to be there. The GT 86's have the foglight switch on the turn signal stock like this one I think.
http://www.nigel-jdmparts.com/japan-...ng-wheel-stalk
Might have to go with it instead but I would think changing out the stock would be alot harder though
jwbrocloud is offline
Old 02-06-2013, 11:52 AM   #130
F-T
F-T's Avatar
Drives: FRS
The precious cargo is on the way guys...
Originally Posted by epsilonkore View Post
They do look fantastic, I am in! PM sent to F-T!
Sent from my SPH-L710 using Tapatalk 2
F-T is offline
Old 02-08-2013, 05:57 PM   #131
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
hey so to get these to work do I turn the regular DRL's off at the dealer? what did some of you guys do
eddieEndo is offline
Old 02-08-2013, 07:15 PM   #132
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
You can but you do not have to. These work independently if you want them to.
FR-Shadow is offline
Old 02-11-2013, 02:55 PM   #133
jwbrocloud
Drives: Raven MT
I think they will look better with the stock DRL off like how you did since the stockers are just Halogens. Unless some have already replaced them with LEDs. Probably gonna get mine turned off as soon as these arrive and get installed
Old 02-13-2013, 08:57 AM   #134
kharn83
Drives: S15 Silvia
Originally Posted by Ryan86 View Post
Received some questions regarding the choice of fog or led.
Having now had both installed, fog due to the bezel looks sportier, but the led in my opinion is all round better looking for day to day use.
The LEDs are bright and match 6000k HID,
The brightest setting is best for both day and night, taking a pic you cannot get what the it actually looks like, as the day looks dim and night looks too bright, but in reality it is perfect. It kind of looks just like the led on a Mercedes C200, to put it into perspective.
Installation is really so simple, under an hour if you know what you doing.
I also ran temp wires from the battery during installation, to ensure after each fit or connection the LEDs worked so I did not find when I closed up something did not work.
Quality is excellent...
hiya ryan, with getting behind the bumper to unscrew the foglights, did u just do that by going behind the wheel arch, or did u need to remove the bumper?
also, if only wired the led drls to the fog light existing wire, how does that differ from wiring to headlight and fog light?
cheers and thanks!
kharn83 is offline
Old 02-14-2013, 03:11 PM   #135
psk
Drives: scion fr-s
sent a message for group buy purchase yesterday. hopefully you guys see this!
psk is offline
Old 02-14-2013, 08:09 PM   #136
jwbrocloud
Drives: Raven MT
Got mine in today. They looking effin beautiful. Now just gotta wait for the oem harness to come in and I'll be ready for install
Old 02-14-2013, 08:27 PM   #137
EBMCS03
Drives: Argento FR-S
where? and how much for the group buy?
EBMCS03 is offline
Old 02-14-2013, 08:39 PM   #138
F-T
F-T's Avatar
Drives: FRS
190 right now pmme
F-T is offline
Old 02-15-2013, 07:59 AM   #139
Ryan86
Road Warrior
Ryan86's Avatar
cheers and thanks!
You pull the bezel off, very easy. Use your hand, screwdrivers will scratch. You will need to turn front wheel either side and get in from behind, enuf space. Remove 2 screws on the fog lights and just pops off.
As for the wiring I put the positive onto the fog harness positive with those red crimp clips and then wired the black earth to the screw below the fuse box.
I did not use the white or blue wires as the LED is perfect on bright setting for both day and night, have not had anyone flash me due the led being too bright.
Very very easy install took me 1 hour taking it slowly and buy this way you can turn your led on or off from the inside switch. I did not connect to ignition, so I could have my radio at ACC on with all the lights off.
Hope this helps.
Ryan86 is offline
The Following User Says Thank You to Ryan86 For This Useful Post:
kharn83 (03-19-2013)
Old 02-15-2013, 11:26 AM   #140
DaveH
Drives: Scion FRS White
I just got mine today, too bad my car is in storage until April 1st. Really excited to try these out, looks sweet.
DaveH is offline
"LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" F-T Exterior Parts - Lighting 169 08-20-2016 02:15 PM
LED daytime running lights sav AFRICA 168 03-22-2016 05:26 AM
Front LED Daytime Running Lights myjobis2pimp NY / NJ / CT / PA 0 04-18-2013 06:47 AM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
