Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-05-2013, 07:04 AM   #29
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I have managed to enable the LED DRL strip to come on at full brightness whenever the engine is on and the parking brake released
Open the fuse box on the right hand side of the engine bay and plug in a relay on the emptly slot for the DRL. You can test it out by unplugging the horn relay and plugging it into the DRL slot. Start thr car, release the handbrake and the DRL should activate. This was done to my Philippine spec car, I hope it works for you SA guys. Enjoy!
HRTROB is offline   Reply With Quote
The Following 3 Users Say Thank You to HRTROB For This Useful Post:
GeeTee86 (02-05-2013), sav (02-05-2013), Vladror (02-05-2013)
Old 02-05-2013, 07:10 AM   #30
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Wow! Thanks, I will definitely give that a try!!
Got any pics of where the relay should go?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-05-2013, 07:10 AM   #31
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Going to try that
GeeTee86 is offline   Reply With Quote
Old 02-05-2013, 07:11 AM   #32
HRTROB
HRTROB's Avatar
Drives: Toyota 86
You should be able to see the location of the DRL relay slot by looking at the diagram printed on the fuse box cover
Old 02-05-2013, 07:13 AM   #33
Mike Hoxbig
Mike Hoxbig's Avatar
Thanks! If I knew how to add a thanks to your post then I would
Also, what rating should the relay be? Warranty implications?
Mike Hoxbig is offline   Reply With Quote
Old 02-05-2013, 07:16 AM   #34
sav
sav's Avatar
Great, thanks I'm going to have a look now.
95RON SAV Tuned
Old 02-05-2013, 07:19 AM   #35
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
if i'm not mistaken you need to have a certain number of posts before a TY button appears in the bottom right corner of each post...
Vladror is offline   Reply With Quote
Old 02-05-2013, 07:37 AM   #36
sav
sav's Avatar
I've just tried it - no luck.
95RON SAV Tuned
Old 02-05-2013, 07:38 AM   #37
GeeTee86
86 Nut
GeeTee86's Avatar
would have been waaayyyy to easy
Old 02-05-2013, 07:41 AM   #38
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Did you start the engine and release the parking brake? Can you check if you have 8 wires going to the headlight connector? One of the wires supplies power to the DRL mode of the LED strip. If you only have 7 wires at the connector, it won't work.
Old 02-05-2013, 07:42 AM   #39
sav
sav's Avatar
Haha yeah, but I think there's more to it - the dealership probably fitted the relay then enabled it via Techstream. I'll play some more tonight.
Also - wow on earth do they expect us to get those relays and fuses out without breaking your fingers? You have to try it to believe it.
95RON SAV Tuned
Old 02-05-2013, 07:43 AM   #40
sav
sav's Avatar
Yep, I've done that - I also drove off with somebody watching from the other side, thinking it could be speed and handbrake activated.
I'll go have a look at the headlight connector and report back.
95RON SAV Tuned
Old 02-05-2013, 07:53 AM   #41
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I did the mod myself, not the dealer i have techstream as well and there is no option to customize/activate the DRL (atleast in my car)
Yeah the relays are a PITA to remove. I used needle nose pliers to pull them out, much easier
Old 02-05-2013, 07:56 AM   #42
sav
sav's Avatar
Ah okay, then we're probably out of luck.
I got them out but I can promise you it wasn't easy. At all!
95RON SAV Tuned
Cool feature of the daytime running lights! eriktherod Scion FR-S / Toyota 86 GT86 General Forum 26 08-31-2014 11:28 PM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
