Old 02-04-2013, 02:19 PM   #15
mhigham
Originally Posted by stealth_fighter View Post
I have an FRS but under light throttle cruise at low speed there is an occasional hiccup in the engine. Running premium, ~4500 miles, happens in third or fourth gear at around 25-30mph. Don't know if anyone else has this issue, I've never had any other issue with this car.
This happens to me everyday, without fail, and only once. The car just hiccups and goes about its business. About 2 miles into my drive to work, usually 4th gear. Only once but everyday.
mhigham is offline   Reply With Quote
Old 02-04-2013, 03:34 PM   #16
NYNOMAD
Drives: BRZ WRB LTD MAN
How about a fix for the windows that "freeze up" every cold morning. I'm getting tired of resetting them.
NYNOMAD is offline   Reply With Quote
The Following User Says Thank You to NYNOMAD For This Useful Post:
NOHOME (02-25-2013)
Old 02-04-2013, 03:42 PM   #17
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
crunchy/notchy 2nd gear
Old 02-04-2013, 05:04 PM   #18
jesperswe
Drives: GT86
No idle issue? As in when the engine is cold, the idle is crappy and you can feel vibrations through the car (even though the idle needle is sitting solid at 650rpm). When the engine is fully warmed up it's rock solid and not a single vibration can be noticed. That one, this really pisses me off.
jesperswe is offline   Reply With Quote
Old 02-04-2013, 05:46 PM   #19
mhigham
You can thank the EPA for that one. They have to retard the timing so much to get quick the catalyst to light off quicker. This reduces power and makes the engine sound weird, since its all about making heat and not power at that point.
Read the manual, it explains it.
Old 02-05-2013, 05:04 PM   #20
jduffy
jduffy's Avatar
Here's my list:
jduffy is offline   Reply With Quote
Old 02-05-2013, 05:05 PM   #21
Fenrir
Drives: Mazdaspeed 3
Driver's and passenger side door control switch cable is loose in the door and rattles. Last time I brought it to the dealer they said "can't be fixed." My experience with that specific dealer leads me to take that as "we didn't even try," but might be worth mentioning as I'm not the only one who has door rattles.
Fenrir is offline   Reply With Quote
Old 02-06-2013, 01:48 AM   #22
foxhu
I have it on the passenger side too. try to open it and fix it yourself I believe is a easy fix with some tap...dealers are all BS. thats why I tried not to go to dealers only if theres major problem like engine light and recall and balalala big problem that would cost a lot!
foxhu is offline   Reply With Quote
The Following User Says Thank You to foxhu For This Useful Post:
tripjammer (02-25-2013)
Old 02-06-2013, 06:06 PM   #23
Fenrir
I don't feel a car with less than 10k miles on it should require me to rip off the door panels to stop rattling. I'm sure I can fix it myself, but that's not the point here. It's an issue out of the box, and I'm sure Subaru is looking for this type of feedback to correct it in future model years.
Old 02-06-2013, 06:10 PM   #24
JWA
Drives: BRZ, Exige, Boxster
FWIW, my Limited doesn't exhibit ANY of those issues - so it is possible for them to get it right. My gearbox is sluggish when cold, otherwise I have ZERO issues in my car. Best of luck with a resolution.
JWA is offline   Reply With Quote
Old 02-06-2013, 06:13 PM   #25
OrbitalEllipses
Drives: Attitude
See my first post in this thread for issues I've had with my Limited. All the TSBs apply too, but I'm waiting for more dealer experience with the fixes before I bring mine in.
FWIW, I have the passenger door panel rattle.
Old 02-06-2013, 06:55 PM   #26
Fenrir
Yup, that's pretty much my mentality at this point. Every time I've gone in to the dealership there's a whole lot of headscratching and "Uhhhhhhh....." going on. Recently I had on of my TPMS sensors go bad. First thing they assumed when I brought it in was that I was an idiot: "It's cold out, you probably just haven't filled up your tires with air. Pressure goes down when it's cold out."
After they found the passenger front sensor was sending an intermittent signal, and that my tire pressure was fine, they ordered a replacement. I went in yesterday to have it replaced, and then was informed they couldn't reprogram them because their tool "didn't accept the code." So now I have to wait another week for them to figure out how to program TPMS.
Confidence in my dealer, right? Useless.
The Following User Says Thank You to Fenrir For This Useful Post:
Gords_zenith (02-25-2013)
Old 02-06-2013, 08:55 PM   #27
Ruckus
Ruckus's Avatar
Drives: Firestorm FR-S
Not sure if the anyone else is having this issue but I changed my door speakers the day after it rained and there was water inside the door. Must be the cheap window seals... :/
Ruckus is offline   Reply With Quote
Old 02-06-2013, 10:06 PM   #28
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
http://www.ft86club.com/forums/showthread.php?t=28183
weird... almost makes me want to check whatsup now because if theres stagnant water just chillin in there it's eventually going to cause mold/mildew buildup which is absolutely disgusting
Jared0934 is offline   Reply With Quote
Drift Day 101, 10/7/12, Alexian Field, Schaumburg philstar Great Lakes 16 11-05-2012 11:42 PM
[Jul 14] FR-S First Drive Tour at LP Field, Nashville, TN scionvip Southeast 44 07-29-2012 04:20 AM
Toyota & Subaru meeting @ Suzuka D1 Grand Prix ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 05-27-2012 08:43 AM
Subaru Engineer caught in a BRZ in NYC (video) ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 28 04-25-2012 05:18 PM
Southeast Drift events at Turner Field MtnDrvr86 Other Vehicles & General Automotive Discussions 1 02-18-2010 03:30 PM
