Old 11-03-2011, 02:07 AM   #281
nate89
nate89's Avatar
Drives: MR2
Originally Posted by kvl View Post
thats stupid!, nowadays even the corolla is using 114.3 x 5 and with the ft86 its still running 100x 5? dont make sense! worst of all, that means my current wheels wont fit ft86 >.<
False, the corollas are still 5x100, as are most other Toyotas (at least the lower models) and Scions I believe.
nate89 is offline
Old 11-03-2011, 03:04 AM   #282
Kostamojen
The hubs/brakes the Subaru has in the parts bin for 114.3 x 5 wheels are EXPENSIVE! Only Tribeca's and STI's use that bolt pattern. Completely unnecessary for this car, and there are a crap load of 5x100 wheels out there anyway.
Kostamojen is offline
Old 11-03-2011, 07:44 AM   #283
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
join the club of course I rock 15s on my cars currently anyways....
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 11-03-2011, 08:57 AM   #284
Dillano609
Teh O1d 5oul
Dillano609's Avatar
Drives: 97' Nissan Maxima SE, 04' BMW 330ci
Originally Posted by Mari0 View Post
nothing that a few red spray cans or red film can't fix
TO:
(not my car)
That looks pretty legit, but wouldn't part of the tail lights need to be masked off and then sanded down to a certain degree to promote adhesion? I definitely would love to do that, because I'm not diggin the altezzas... Can anyone say "Rice"?
Dillano609 is offline
Old 11-03-2011, 09:04 AM   #285
Kazama
Drives: avensis d-cat 177hp wagon 2011
whats the diffrence between trd and tte?
Hey, in Norway its standard for TTE to deliver ekstra styling and mods from toyota. we cant get some TRD parts to but TTE parts are what toyota norway are pushing as exstras . will it maybe come a TTE modell for the european marked? and TRD/MODELISTA be for japan and the us?
Kazama is offline
Old 11-03-2011, 10:22 AM   #286
Dragonitti
Originally Posted by madfast View Post
WTF? since when are we talking about the tC SC? im talking about a SC kit for the FT using a set up similar to the tundra kit. specifically a SC based off the eaton TVS. such a set up will give you enough boost for a modest performance gain, no lag, and a flat tq curve.
maybe you would never put a SC on a 4 banger but that doesnt mean others shouldnt. you can go the turbo route if you want. but you're going to be the one who deals with heat, fitment, overboosting, spool, boost leaks, or whatever problems that are commonly associated with turbos...
PS: centrifugal SC are crap imo, only rotrex is worthy as a consideration.
Is the Tundra a 4 banger? Like I said, of all the S/C'ers for Imports (mostly 4 bangers), I have yet to see one out perform a properly configured turbo setup on the same car.
Turbo's, especially Dual BB have minimal lag when a competent tuner specs out the engine and setup. Key word here is "Competent". You run a bigger A/R on the turbine, it will effectively move your peak torqe and change up your power band. Tuning the car via the dyno with a tuner who knows what he is doing, can deliver a flat torque curve for you. Like I said though, the turbo has to be Matched to what you are trying to do. Peaky torque curves are fun for the street. Flat broad ones are ideal for the track.
S/C is not more efficient than a properly matched turbine. Not in the Import 4banger world. Proper Wastegate size = No overboosting. Heat is a byproduct of both S/C and turbos, no difference there. Either can suffer from boost leaks...it's called a vaccum leak.
Dragonitti is offline
Old 11-03-2011, 10:26 AM   #287
Dragonitti
It's 5x100.
EPIC FAIL! I'm dealing with the dreaded 5x100 pattern now!!! Blasphamey!
Old 11-03-2011, 10:34 AM   #288
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I have no idea if you are being sarcastic or not I think so...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 11-03-2011, 10:51 AM   #289
Dragonitti
Originally Posted by rL-gT View Post
Check the wheels and tires forum. This has been discussed
Centrifugal is Centrifugal. Only S/C I would ever consider would be a Roots Type.
Yeah, ones that no one wants
No, 5x100 pattern sucks. None of the popular track built wheels (i.e. Volk TE37's) come in a deep offset with a 5x100 bolt pattern. Sure you can get 5x100, but there is no deep dish or concave with them. That pattern sucks nutsacks....
Only wheels that are deep and wide with 5x100 are ROTA's and XXR's. Nothing against those, cause I'm going to get some XXR's for the tC. But I wouldn't mind a set of TE37's on the FT and it not look like a flat face to it.
Old 11-03-2011, 10:54 AM   #290
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd prefer 5x114.3 myself, but my wheels just get covered in brake dust anyways so looks don't matter to me :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 11-03-2011, 01:06 PM   #291
madfast
Drives: 2010 Evo X MR-T
define out perform. and at what boost?
the problem is that there are very little SC kits out there that are properly designed. its really that simple. they either use old gen eaton roots blowers, or they dont have an integrated intercooler, or they use a vortech/non-rotrex style centrifugal kit with or without intercooler. ALL of those are NOT up to par with a turbo. i dont think anybody will disagree.
however im talking about the new age of supercharging. either a 6th gen eaton TVS or twin screw design. both offer adiabatic efficiency in the 70% range and some approaching 80%. they can run more boost, more efficiently. AND most modern kits have an integrated water-air intercooler.
so why doesnt anybody make they awesome kits for 4 cyl imports? CULTURE. the "import culture" has always embraced the turbo. maybe because the best imports (gtr, evo, sti, supra, rx7, etc) had factory turbos, maybe because the older gen SC's have a bad rep, etc. but the fact of the matter is, if you look at the domestics, they embrace the SC over the turbo. its part of their culture to slap a blower on. the result? AMAZING kits from lysholm, whipple, magnuson, vortech VTS, roush, edelbrock, kennebell, etc... again, not to say there are no turbo domestics, but if you want FI the common route is SC over turbo. for imports its turbo over SC.
so the bottomline is to not compare a well engineered turbo kit with a crappy second thought SC kit. the FACT remains that a SC will give you a better boost curve given MODEST boost levels. and those levels? they're increasing. it used to be if you go above 10-12 psi or whatever the SC would be so inefficient that you cant boost any more. nowadays? 15-20+ psi is simple and easy with more efficient lobe designs and integrated intercooling.
minimal lag is still lag. you cannot change this fact, lest you run WRC-style ALS on a street car. for some it makes a difference. for others it doesnt. the tq curve of a turbo engine will not be as flat as a SC. again, for some it matters and for some it doesnt.
it may not be more efficient, but the efficiency is coming increasingly closer to a turbo. some SC literature/advertising even claim better efficiency. but i digress. its not always about efficiency. sometimes the boost curve/torque curve and the driveability of it is more important to you than numbers...
madfast is offline
Old 11-03-2011, 02:42 PM   #292
Kostamojen
Says you!
I'd be perfectly happy with Subaru or Toyota take-offs. I could care less about spending obscene money on wheels.
My only concern is the offset, but I suspect they will be Subaru offsets (Between +48 and +55)
Old 11-03-2011, 02:57 PM   #293
Leeky
3S-GTE Junky
Leeky's Avatar
Drives: Toyota Celica GT-Four ST205
5x100 FTW hehe
Leeky is offline
Old 11-03-2011, 03:15 PM   #294
Andy
Drives: Toyota
People seem to forget, Wheels are not manufactured with PCD and offset there from the initial construction.
The wheels are normally made as a blank then machined for PCD, centrbore and ofter ET after the wheel is made.
The manufacturers will be able to do whatever size you want (within reason) and if not, then buy a blank and find a engineering company to machine them for ET and PCD (and centrebore)
Andy is offline
fr-s trd, fr-s trd parts, frs trd, ft-86 trd, ft-86 trd parts, scion fr-s trd, scion frs trd, toyota ft-86 trd, trd fr-s, trd frs, trd ft-86, trd scion fr-s, trd scion frs, trd toyota ft-86
How much would custom parts be? LexusFman Other Vehicles & General Automotive Discussions 10 07-23-2012 12:59 AM
How do you buy aero kit / TRD parts? scwewywabbit Scion FR-S / Toyota 86 GT86 General Forum 25 03-17-2012 10:45 PM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
after market parts serchmarc Scion FR-S / Toyota 86 GT86 General Forum 90 05-31-2011 08:18 PM
