Old 01-24-2013, 01:40 PM   #15
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
looks like I have found my twin! @greenguy101
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
The Following User Says Thank You to Tylub For This Useful Post:
greenguy101 (01-24-2013)
Old 01-24-2013, 02:59 PM   #16
CaptainSlow
CaptainSlow's Avatar
What exhaust is that?
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-24-2013, 03:13 PM   #17
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Its the GReddy SP Elite Axleback
http://www.revworksinc.com/GReddy-SP...R-S_p_699.html
Rev Works is offline   Reply With Quote
Old 01-24-2013, 03:21 PM   #18
CaptainSlow
Looks great! Definitely will have to check that out in the future
Old 01-24-2013, 03:31 PM   #19
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Id be glad to answer any questions for you when you are ready to pick one up buddy! It sounds great on this car as well!
-Matt
Old 02-03-2013, 01:24 AM   #20
enigma
Drives: Asphalt 86
Just out of sheer curiosity, did you or the owner of the car manage to weigh the wheels and/or the coilovers compared to the stock equipment? Those grids look absolutely stellar on there, but I'm wondering if they're a ton heavier than stock?
enigma is offline   Reply With Quote
Old 02-03-2013, 06:23 PM   #21
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Hey buddy,we did not get the chance the weigh the stock suspension, but I believe they are a bit lighter. As for the wheels, the owner might be able to chime in as they were on the car when it came in for the install.
Old 02-03-2013, 09:33 PM   #22
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
Hey guys, the stock wheels are about 20lbs without tires. The front ROTA's are about 21 lbs and the rears are around 24 lbs. So they are more for daily driving than serious track use.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
The Following User Says Thank You to greenguy101 For This Useful Post:
DarkCard (04-23-2013)
Old 02-04-2013, 04:49 PM   #23
WheelDude.com
Drives: 2013 FRS
Send a message via AIM to WheelDude.com
even on serious track use, with a 1-3lbs different you're not going to notice much.
they are more in the 23lbs territory I believe too.
WheelDude.com is offline   Reply With Quote
Old 02-04-2013, 05:27 PM   #24
greenguy101
Awesome, great to know. I was basing my info from another thread so I'm glad you chimed in. Thanks!!
Old 04-23-2013, 12:02 PM   #25
Mikegraves777
Drives: 2013 Scion FRS
did you have to do anything else suspension wise camber bolts or control arms or anything else to make it all fit
Mikegraves777 is offline   Reply With Quote
Old 04-23-2013, 12:47 PM   #26
Rev Works
Rev Works's Avatar
Drives: 2013 STi
No we did not. However, we would recommend some adjustable rear control arms, as the car from factory does not have very much camber adjustment so using an adjustable arm would really help to get that dialed in perfectly.
Old 04-23-2013, 01:38 PM   #27
Mikegraves777
would camber bolts be enough or no
Old 04-23-2013, 01:41 PM   #28
Rev Works
Rev Works's Avatar
Drives: 2013 STi
From past experience, typically not, but it also depends how far off the numbers are to begin with.
The Following User Says Thank You to Rev Works For This Useful Post:
Mikegraves777 (04-23-2013)
Wheel Directory: Rota Grid 18x8.5 +44 / 18x9.5 +38 CoRi J Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 119 04-26-2019 10:42 PM
Wheel Directory: Rota Grid 18x9.5 +38 Sandman3zb Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 67 06-20-2017 02:41 AM
White Rota Grids and Dunlop's Simmons Wheels and Tires 9 01-09-2013 01:49 PM
