Old 02-01-2013, 04:56 AM   #15
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
1/4" ring for $.99? what application is that one for?
mrlewistan is offline   Reply With Quote
Old 02-01-2013, 11:36 AM   #16
NON-VTEC
Drives: acura integra..brother owns FRS
Originally Posted by Xanatos View Post
Two problems I see with this:
Figure 1. The center bore seems like its too big for the outer diameter of that tow rod. The slivers on the side definitely wont hold as much weight as the shackle.
Figure 2. Not sure if both sides of the shackle are threaded but for sure after using the tow hook the middle threads on that screw will be gone. Thats why bolts are not threaded in that area in pin shackles like the picture you posted above. It will also cause premature wear on the inside of the tow rod.
Just a personal preference I would go with the solid piece on the right
This piece is a prototype, we will be using different button head bolts without threads all the way up in later designs. I understand what you are thinking about the tow rod, we will do some testing and get back to you. remember, the direction of the stress is straight out and it would have to strech the steel rod. In later designs we may use a 1" diameter rod instead of this one which is 3/4" thank you for your thoughts
NON-VTEC is offline   Reply With Quote
Old 02-01-2013, 11:38 AM   #17
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
do people actually use those? or is it just another rice thing that some people do?
chenshuo is offline   Reply With Quote
The Following User Says Thank You to chenshuo For This Useful Post:
dem00n (02-01-2013)
Old 02-01-2013, 12:43 PM   #18
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
It'd mostly be meant for being towed on a track if you crash / get stuck / etc.
That being said mostly they will end up being used on street cars for looks. They would be handy in winter though and makes me contemplate getting one in case I ever hit the ditch
pheoxs is offline   Reply With Quote
Old 02-01-2013, 12:49 PM   #19
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
99% of the time you see these on cars they don't track ever.
But if you do track, some places require you to have one. (Don't think any do in the US though...?)
Old 02-02-2013, 12:15 AM   #20
NON-VTEC
updated with painted pictures, no tests run yet.
Old 02-02-2013, 04:48 AM   #21
Walldodger
Walldodger's Avatar
Drives: Four wheels, two seats, etc
Originally Posted by campy View Post
Yup... that's a tow hook all right...
Sorry but I don't really know what opinions you expect us to have. People who buy tow hooks do so because they need them (or they're mad JDM honda drivers). So as long as you can drag the car out of the sand pits with it, then it's fine.
And is it just me or does it look a bit small compared to most other hooks?
You don't know if you don't ask.
Originally Posted by NON-VTEC View Post
The estimated strength rating for the D-ring itself is 2'000lbs. The tensile and shear strength of the bolts is substantially higher than that. We will also be doing rigorous testing both on the street and track before releasing these. Also all of our products will carry a full lifetime warranty.
Thank you for the info.
Walldodger is offline   Reply With Quote
Old 02-02-2013, 12:59 PM   #22
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
I am glad someone is making things themselves for these cars, however make sure it is spec'd to the race class these cars most likely will run it. I have looked into it before and I know the "eye" has to be like 60mm ID or something etc etc.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 02-02-2013, 01:00 PM   #23
Dfideth
Dfideth's Avatar
Drives: WhiteOut Auto
The strength of the D ring or breaking strength is 10,000lbs. Rigging gear uses a 5 to 1 factor for working load capacities, in this case 2,000lbs. working load. Using the allen instead of the original screw supplied with the D ring "Shackle" weakens it. You may have noticed the over sized hole of the unthreaded part of the shackle and how lose it is at the cap side. But good news, the D ring isnt your weak link. If you use that tie down to pull in any other direction than a straight pull, you will snap that bolt that screws into the vehicle.
....My background, 25 year crane tech and rigging, engineering life line for fall protection, in house testing on pulling eyebolts etc.
Dfideth is offline   Reply With Quote
Old 02-06-2013, 10:59 AM   #24
TickTacker
Tow hook will come with a button head allen rather than the full size allen pictured.
Please let us know what you think of these. Any feedback is appreciated.
Thanks everybody for looking.
No offense personally, but as long as you're looking for feedback, it looks like you skipped the 'R' and went straight to the 'D'. You'd have to be crazy to put something like this on your car and expect to be safely towed. How are you threading the rod? It looks like you've welded a bolt to the end of a piece of bar stock and then ground it down with an angle grinder.
I can appreciate the effort, but I think you need to take a step back and re-evaluate a few of your design choices here if you're going to confidently call it a "track grade tow hook".
On a grander scale, can I ask what advantages something like this offers over the stock tow hook, designed and manufactured to pull the BRZ/FR-S.
:happy0180:
TickTacker is offline   Reply With Quote
Old 02-06-2013, 11:06 AM   #25
zenki_levin
Road Warrior
zenki_levin's Avatar
Drives: AE86 Levin
Give me 20sec and i'll break it.
zenki_levin is offline   Reply With Quote
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 11:41 PM
Tow Hook Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 7 09-11-2012 12:39 PM
Scion Canada FR-S Track Day Behind the Scenes Pictures DjDATZ FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 08-09-2012 02:04 PM
Willow Springs Track Day Pictures & Review LeavingNormal Tracking / Autocross / HPDE / Drifting 22 06-28-2012 02:19 PM
Dutch General Director of Toyota comments on price Navi Scion FR-S / Toyota 86 GT86 General Forum 34 12-28-2011 03:08 PM
