Old 11-02-2011, 02:48 PM   #57
Abflug
Abflug's Avatar
Drives: MR2
THIS DAILY INFORMATION FLOOD IS SO SICK!!
THANK YOU!
Abflug is offline   Reply With Quote
Old 11-02-2011, 02:48 PM   #58
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Quick translation of yellow writing (due to work is killing me )
"Driver can control/adjust front & rear weight.
But driver cannot control/adjust center gravity, so we have focused on low center gravity."
bottom big white letters
"High focus of driver control f/r weight ratio"
wanted to translate more... but gtg, before my boss find out
Old 11-02-2011, 02:49 PM   #59
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by skinsfn36 View Post
12.5:1 will make boosting safely on the stock internals very difficult, probably why we don't have a TRD FI option yet
Direct Injection is a different ball game.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 11-02-2011, 02:50 PM   #60
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
this website is like crack...
i get high sitting here reading info
im going to go through withdraws if this keeps up
WingsofWar is offline   Reply With Quote
Old 11-02-2011, 02:51 PM   #61
Sparkplug
Rotard
Sparkplug's Avatar
Drives: 135i M-Sport
Same here... it makes me feel like your avatar.
Sparkplug is offline   Reply With Quote
Old 11-02-2011, 02:52 PM   #62
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by madfast View Post
i expected a much flatter torque curve. is this D-4S related perhaps? in the literature there is talk of the engine using a mix of DI and PI in low and mid rpm, and DI only in high rpm...
So let me get this straight. The engine torque is peaky rather than flat and rich? If so I hate that shit.
SUB-FT86 is offline   Reply With Quote
Old 11-02-2011, 02:55 PM   #63
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
The graph shows a "before" and "after" D4-S, with a 20NM gain and 10KW gain by using D4-S. The torque curve shape itself is more a function of the ports and combustion chamber [the main items that affect VE].
Thanks for the translation; it makes sense technically. DI can control cold-start and WOT combustion much better than PI. PI would be used mainly during low and medium load cruising, where stoich is relevant and wall-wetting or knock isn't an issue.
I still want some real numbers bolted on that graph to make it logical. At this point, based on the written specs on the scan, the dyno graph might actually be an "example" of how D4-S is effective, not the actual FA20 engine output.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 11-02-2011, 02:55 PM   #64
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
power output reminds me of the Japanese 80s.
so much nostalgic win.
Old 11-02-2011, 02:59 PM   #65
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
^ i wonder if its even necessary. the battery is already mid mounted on the firewall
I wouldn't bother unless it's in front of the axle. It'll help a little but I wouldn't want it behind the rear axle. Properly securing the box so it passes tech seems to be something most people can't do (I've failed a TON of relocated batteries before for not insulating the pos term, having a solid box, mounting a box without huge fender washers, etc).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 02:59 PM   #66
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
So with so much compression, does that mean FI is most likely a no no?
KaliKev is offline   Reply With Quote
Old 11-02-2011, 03:01 PM   #67
Ryephile
Hot Dog
Ryephile's Avatar
Light boost [perhaps as much as 10PSIg] would be possible, assuming the rest of the engine can cope with the BMEP increase. DI improves chemical quench remarkably [as in, less knock for a given dynamic compression ratio]
Old 11-02-2011, 03:02 PM   #68
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
In a normal motor you'd have to be really careful and probably upgrade internals before too long (and lower comp). With DI, I have no idea as I'm not anywhere near familar enough with DI to say.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 03:03 PM   #69
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
^ best option is to do a stroker kit and raise the stroke path maybe different pistons and lower the CR.
Much like what the mazdaspeed 3 does, with a small bore and long stroke to bring the CR down to 9.5:1 Direct Injection.
I cant seem much room for forced induction on stock internals.
Old 11-02-2011, 03:04 PM   #70
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Originally Posted by FBS View Post
Took another look...
I'd love to know what that graph on the 3rd page is all about
Torque and hp curves. Comparing D4S and non d4s
edit... Didn't see there was a page 2
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 08:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 03:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 02:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 07:35 PM
