Old 01-31-2013, 12:39 AM   #1
Ravenft86
Ravenft86's Avatar
HELP with AC
Hey guys, i end up getting a BRZ over the FRS, but anyway, today i try to turn on my AC and thought it was only me, but the AC did not work. Did anyone have the same problem? i have the limtied, so it the dual automatic climate control
please help lol..
Ravenft86 is offline   Reply With Quote
Old 01-31-2013, 12:44 AM   #2
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
When it comes to trouble-shooting did you follow the a/c operating procedures in the owners manual? What didn't work, fan, temp, vents? It's likely either a loose connection or a fuse. That's why we get warranties with new cars. Take it to your dealer and it probably will be a quick fix.
whaap is offline   Reply With Quote
Old 01-31-2013, 12:54 AM   #3
Ravenft86
Ravenft86's Avatar
The fan works, heater works.. just not the AC. When i press AC, its just regular air. According to the dealers, they said they have to keep it and look it over. Run test and all.. lol, this car is less than 2 days old too
I tired reading the manual, and it does not say anything about trouble shooting or anything. I only read about how it works and all.. Unless i missed it. -_-"
Old 01-31-2013, 12:58 AM   #4
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
I'm lying in bed but I think that AC will come on either when the temp knob is all the way to the max cold area or if its in the blue (cold) area. That's how it is on some Toyotas. I've had my car for 6 months now and only used it to warm the car up; maybe it's time to do so.
I am very insecure. I have no friends. I want people to love me
Old 01-31-2013, 01:17 AM   #5
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i assume u pressed the toggle switch for AC? and set the temp to colder level?
chenshuo is offline   Reply With Quote
Old 01-31-2013, 01:23 AM   #6
Ravenft86
Ravenft86's Avatar
yes, i have both screen that says "LO" and the toggle switch is on cause it has the green light
Old 01-31-2013, 02:11 AM   #7
Porsche
Drives: 2013 BRZ Ltd. MT
What is the ambient temperature, the outside air temp?
Around 32 degrees F automobile AC systems are designed NOT to turn ON; they could, and probably would, freeze the lines causing damage, and leaks, and all of the refrigerant would leak out. So they don't turn ON ... by design. I don't recall what the exact temperature is for the BRZ/FRS.
Is it cold out?
Porsche is offline   Reply With Quote
Old 01-31-2013, 10:45 AM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Is it cold out?
Automobile AC systems are designed NOT to turn on if ambient temp is 32F? says who? My 2010 altima coupe has AC that can be turned on in the cold cold toronto winter.
Old 01-31-2013, 11:49 AM   #9
rhoyle
Drives: BRZ SWP 6MT
FWIW: If I recall correctly, the coldest air a normal automotive air conditioner can output is around 54 degrees. Whether or not that has anything to do with the compressor turning on below that ambient temperature, I have no idea. It can be useful to remove moisture from the air even under heating conditions, and even in colder temperatures, though. Point being that if you're trying to cool below 54 degrees or so, you're not likely to notice a difference.
My HVAC controls stay on full AUTO and the AC light is almost always, if not always, lit.
To the OP: Take it to the dealer, it's not your problem - its theirs.
rhoyle is offline   Reply With Quote
Old 01-31-2013, 12:33 PM   #10
Porsche
The vehicle owner’s manual from the manufacturer.
Perhaps, but that would surprise me. Did you read that manual as well as you read the BRZ manual?
Is it your deliberate intention to sound as combative and rude as you do here in this aggressive post? “Says who?”
What you observed, almost certainly, is the LED or light turn ON when you press the controls for the AC. All of my cars have behaved identically.
What you will discover is that, although the lighted LED indicates the AC is ON, in fact the compressor never kicked in. In other words, the AC is OFF. I have observed this phenomenon in every car I’ve ever owned. (Actually, my new 1968 car and my new 1970 Boss 302 did not have AC.)
Sit in a quiet parking spot, turn on your BRZ, and listen carefully as you press the AC button. In temperatures around 32 deg F and below, you will NOT hear the compressor activated. No compressor operation = no air conditioning.
Some auto manufacturers set the AC cut-off temp even higher; some Ford owners report their manual stating it to be 39 degrees F.
By the way, the manual for my home air conditioning system warns the user not to turn the AC on in temperatures below 50 degrees F. Why do you imagine that is?
The understanding you seek is in your BRZ manual, although admittedly obscure. Subaru only alludes to this condition, but it’s there. You’ll have to ask them why they didn’t just spell it out in simple English like other manuals do.
Why don’t you go and find this (it’s a simple task) in the BRZ manual, copy it, return here and paste it into your next post to help the members of this forum understand. You’ll learn, they’ll learn, win-win all around, wouldn’t you say?
You are here to be helpful, right?
Old 01-31-2013, 12:41 PM   #11
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
well, cause you said "Automotive A/C systems...", perhaps you should have said "BRZ A/C systems". Automotive is a general term that i thought would include all Automotives.
also, when i turn on the A/C in cold Toronto winter, the sound of the car changes, just like when i turn it on in the summer.
so... just because someone said "says who?" doesn't mean they are combative. right?
lol stay calm, i'm not here to be "combative" with you. stay calm... stay... calm...
Old 01-31-2013, 01:13 PM   #12
Ravenft86
Ravenft86's Avatar
it was 76 degree here. going in to dealer today
Old 01-31-2013, 01:16 PM   #13
Porsche
...you should have said "BRZ A/C systems".
I “should have?
I see. How very gracious of you.
Thank you for confirming my original thought.
That will be all.
The Following User Says Thank You to Porsche For This Useful Post:
colHolm (01-31-2013)
Old 01-31-2013, 01:18 PM   #14
rhoyle
Drives: BRZ SWP 6MT
I'm noticing that the maturity level of these forums is not what it could be.
The Following User Says Thank You to rhoyle For This Useful Post:
Freeman (04-16-2013)
