Drives: Silver AT Limited
Drift Office Tune vs Visconti Tune
Introduction
So Bob over at Drift Office LLC and me decided to compare Visconti Tune, FA20Club Tune (was not able to load the tune because I did not get the most up to date tune, and the older tune was not loadable through the newer ecutek software), and the Drift Office tune for the Automatic BRZ. The AT tune from Drift Office is based on @brzranger 's tuned AT. Setup So here are the variables we tried to keep consistent across the two tunes 1. Each run was from a fresh flash, meaning the ECU was not given the chance to learn the new tune. So when I came in I reflashed the Visconti tune to keep it fair. Also given the time frame it was not reasonable to try and have the ecu learn after every flash. 2. We let the car idle for a few minutes after a new flash to let it adjust the cam timing. 3. A fan was blowing at the engine bay with the hood up. 4. My mods that can affect the dyno results are: - Airraid Intake - Motegi M125 wheels - Works resonated AxleBack 5. Each pull was done at 4th gear, 3 times with the best runs compared Results: From a dyno standpoint I think Visconti and Drift Office Tune are neck to neck with the Drift Office tune slightly ahead. However these variances are negligible to daily driving and the occasional autoX and track days. I decided to go with the Drift Office tune because it is a smoother curve from the dyno sheet. Notes: At the first few runs my AFR was not smooth and out of whack, which did not make sense since we did a shootout last year and my AFR was fine with the earlier tunes from FA20 and Visconti as well as having the Airraid intake. Upon further inspection it was because my exhaust was not equally flowing, the passenger side of my exhaust had more air flow than the driver side (to which I dunno why, maybe bad design?) We checked the AFR from ecutek and the numbers were what we expected coming from the ECU. The AFR you see is from the passenger side exhaust readings. Last edited by mechaghost; 01-30-2013 at 12:44 AM. |
| The Following 5 Users Say Thank You to mechaghost For This Useful Post: | BRZranger (01-27-2013), Drift-Office (01-27-2013), MarkRacerX (01-30-2013), Mr.Jay (01-29-2013), Sportsguy83 (01-26-2013) |
#2 |
Drives: GT-86
Honestly not seeing any significant difference here in regards to power and the AFR for visconti's tune seems slightly better on the high end
#3 |
I'm a little bit confused by your statement. The graph shows the very slight advantage to Drift Office. I wouldn't trust those AFR's due to my exhaust (which is throwing off the sensor)
#4 |
Drives: ex500r
#5 | |
Drives: GT-86
peak horsepower is < 1 which is not significantly greater (definately cannot be felt) and may not even be statistically significant.In addition the curves are almost in line with each other for the most part. I would say they are equal in regards to power generated.The differences between the two graphs may be within the margin of error for the dyno. What i do see is the Drift Office AFR curve dipping below 12 above 6000 rpm. which may be a bit to lean for the car. If you dont trust your AFR however (not sure y?) then u can ignore the AFR's. The difference between the AFR curves however is more significantly different than the torque and power graphs IMHO |
#6 |
Drives: Raven FR-S 6MT
Would have been nice to have seen stock tune on graph as well. Waiting to see where the Drift Office tune comes in $$$ wise.
#7 | |
Now, the AFR curve shows drift office being richer than 12 at high RPMS. It appears that Visconti's AFR curve is a tad flatter and more consistent throughout the entire RPM curve. Also, that dip you notice at high RPMs on the drift office dyno is a bit concerning. Either you let off the gas or the ECU pulled timing from knock... |
| The Following User Says Thank You to 2forme For This Useful Post: | Calum (01-27-2013) |
#8 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Drift-Office (01-27-2013) |
#9 | |
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Sounds like your confused. ![]() In any which case, this was supposed to be a fun 3 way 'shootout' but it turns out that FA20 club elected not to send the OP an updated calibration, why I'm not sure... Regards, Bob @ Drift-Office, LLC |
| The Following 3 Users Say Thank You to Drift-Office For This Useful Post: |
#10 | |
Drives: GT-86
My apologies But still I think u will agree the two tunes make basically the same power. |
#11 | |
Now that the OP has installed his stock intake back on, we'll see if we can't get FA20 club to send him an updated tune as well and then we'll shoot for yet another apples - to - apples comparison in the near future. Cheers! Bob @ Drift-Office, LLC |
#12 |
SLO NO MO
That's surprising, given the rave reviews of how fast FA20club responds to customer requests for tunes.
#13 |
#14 |
Go Gators!
Drives: FRS White-out "blown up"
FA20 has been dealing with sick kids......FYI....I'm sure he'll get it to ya as soon as he can
FA20 Turbo + HRI Tune + FA20 Flex fuel + FA20club intake + SRT headerback exhaust + FA20 headers + KW3's + Hotchkis front and rear sway bars + Cusco strut tower bar + Perrin oil cooler + Perrin pulley & brake stop thingy + GFB water & alternator pulleys + Crawford air/oil separator |
| Drift-Office Stage 1, 92 Oct tune | BRZranger | Engine, Exhaust, Transmission | 15 | 01-07-2013 10:40 PM |
| Heading to NC - Come get your EcuTek tune from Visconti ! | Visconti | Southeast | 16 | 09-18-2012 09:15 AM |
| CEL with Visconti tune | tjdiz92 | Issues | Warranty | Recalls / TSB | 44 | 09-16-2012 05:04 AM |
| A Question for Those of You WITH the Visconti Tune | White64Goat | Engine, Exhaust, Transmission | 22 | 09-02-2012 06:27 PM |
| 1st Auto with Visconti E85 tune! | white devil | Engine, Exhaust, Transmission | 35 | 08-22-2012 05:22 PM |
