Old 01-26-2013, 08:22 AM   #43
IMOA
Drives: 86 GTS
What you're looking at is a different intake manifold with different length runners, different cams and to a lesser extent headers. You have to understand though that to close that hole you are going to be taking power from somewhere else. This isn't a 1:1 kind of thing but ultimately the parts have been designed to have maximum efficiency at a certain point in the rev range so to improve the efficiency in a different point you are going to gurt it somewhere else. What I would expect to see is some cams and probably new intake manifold which will be optimised for mid to high range so will fill the hole but also knock off the peak from 2000 - 3000rpm.
IMOA is offline   Reply With Quote
Old 01-26-2013, 08:45 AM   #44
sierra
Drives: Skoda Yeti DSG diesel 4x4
This was my original thought with the torque dip, that they had maximised the bottom and top ends and did their best with the mid range which had to be a compromise. The only other option would have been to reduce the power in those areas to give an even delivery. Clearly this is the best option in a sports car that has budget limitations
You only lose power elsewhere if the changes are fixed. Variable solutions will work and maintain power throughout the range, they are just difficult to implement and the best variable cure so far is a turbo.
sierra is offline   Reply With Quote
Old 01-26-2013, 12:30 PM   #45
Xdragonxb0i
Drives: ex500r
Originally Posted by whtchocla7e View Post
The torque dip is overrated. I don't even feel it..
I feel it. When Stepping on the gas it. the FRS doesnt have any oomp until 5k
Xdragonxb0i is offline   Reply With Quote
Old 01-27-2013, 06:58 PM   #46
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Originally Posted by sierra View Post
No, never heard of them before. The warranty is only 3 years here so i'll save that for later. What do they sell for?
back in the day it use to be universal wiring nightmare. now its plug and play applications. They are made for most every car. i run a series 1, but there is now the series 2 and the infinity which theyre are pushing alot..this is the company the makes the proper sounding launch controls and anti lags lol
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following User Says Thank You to Grip Ronin For This Useful Post:
sierra (01-27-2013)
Old 01-27-2013, 07:21 PM   #47
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I'm surprised Subaru wasn't able to tune the torque dip out.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 01-27-2013, 07:33 PM   #48
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I think the torque dip is the cause of the Toyota direct injection system. The Lexus IS which uses the exact same D2S has the same torque dip.
LeeMaster is offline   Reply With Quote
Old 01-27-2013, 08:30 PM   #49
Synack
Boosted
Synack's Avatar
Drives: Sideways
Dump the clutch, what torque dip?
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-21-2013, 05:43 AM   #50
Metal_88
Metal_88's Avatar
Drives: GT86 First Edition
Hi all, I personally tuned my ECU and I can confirm what been said in this thread, the direct injection is used to compensate the low air flow in that rpm range which is from 2800 to 3800 rpm (more or less). If you enable port injection the sound change but you get disappointed by generated torque. the car use AFR map to allow the fuel flow and another map to decide the % of DI or PI. DI injection anyway gives more torque but his efficiency decrease along the rpm range so it's better to combine DI and PI, infact the stock % at full torque request is 50-50 %
you can clearly see that at those rpm range the car can't breath as it would even with sport air intake
Hope this might help clearing some ideas
Metal_88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Metal_88 For This Useful Post:
Mikem53 (07-21-2013), Rayme (07-21-2013)
Old 07-21-2013, 05:45 AM   #51
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
omg its a 2l NA motor. What the fuck do you guys expect.
bkblitzed is offline   Reply With Quote
The Following 5 Users Say Thank You to bkblitzed For This Useful Post:
Enraged21 (07-21-2013), Muaddib (07-21-2013), Opposed (07-21-2013), Rayme (07-21-2013), tobin (07-21-2013)
Old 07-21-2013, 06:29 AM   #52
Metal_88
Metal_88's Avatar
yes it is, but it's a really good one and obviously if you want some powa you need some modifications
The awesome is the handling of the car which can make it really competitive against other street cars
Old 07-21-2013, 07:06 AM   #53
alan.chalkley
Drives: 4wd zooks
The torque dip is not a problem with the manual gearbox.
When i need more torque i just change down a gear.
This car is about driver involvement and fun.
alan.chalkley is offline   Reply With Quote
Old 07-21-2013, 08:27 AM   #54
Mikem53
Drives: FR-S 6MT
I agree.. While it does exist.. In normal driving, it's not an issue. You can drive around it.. Which just adds to the character of the car.
For normal commuting, driving below the dip there is plenty of tq to where you don't need to rev too much.. Play time keeps the tach above 5k and u don't worry about bogging in the dip.. I've been to the track too and the dip wasn't an issue for me.. A compromise had to be made and I think the OEM made a good choice on keeping tq down low and up high..
Great discussion !!
Mikem53 is offline   Reply With Quote
Old 07-21-2013, 08:43 AM   #55
Metal_88
Metal_88's Avatar
Sure, every NA car has this problem.
It's much more important above 4800 rpm.
Looking at the map I found a limitation in the fuel map and fuel injector which makes you gain enough to feel the car much better, especially while drifting or mountain driving
besides this car is limited above 220 km/h (throttle close to 50% at 230 km/h)
Old 07-21-2013, 09:16 AM   #56
Opposed
Drives: 2013 Asphalt FR-S
Header+tune=torque dip free.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 10:55 PM
It has more power, but less torque. white_knight Scion FR-S / Toyota 86 GT86 General Forum 9 08-09-2012 01:46 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
