Old 01-25-2013, 10:18 AM   #29
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Originally Posted by sierra View Post
Blue injection volume curve?
The problem with that is if it's showing the total fuel being injected at full throttle? Then why is it only showing another 10% of fuel being used at 5,600rpm than is being used at 3,500rpm? Or almost the same fuel at 7,600rpm as at 4,900rpm?
Blue-green on my screen.
I think it's the volume per cylinder, not volume per second. That would make it much less dependent on RPM.
b.e is offline   Reply With Quote
Old 01-25-2013, 11:20 AM   #30
IMOA
Drives: 86 GTS
You can be more aggressive with the tune when you're only running direct injection as it's fundamentally more detonation resistant. My read is that the combination of the intake and the cams have been designed to give a big hump in torque low down for daily driving and a hump up top for when you're driving hard. This leaves a hole in the middle which they have been really aggressive in the tune in an attempt to minimise as much as possible.
IMOA is offline   Reply With Quote
Old 01-25-2013, 11:32 AM   #31
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Just googled AEM tuning and found a whole new world!
you didnt know about them? i been running one in my civic for years. best ecu ever. closes think to a motec and a sub normal price
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 01-25-2013, 12:33 PM   #32
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
@Visconti perhaps he could comment on adjusting the direct/port injection overlap and its affects on the torque dip in his tunes?
pheoxs is offline   Reply With Quote
Old 01-25-2013, 12:35 PM   #33
Synack
Boosted
Synack's Avatar
Drives: Sideways
No, turbocharging always fills the torque dip too.
Do you know if Ecutek can turn the port injection back on?
At the time we were using ProEFI.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 01-25-2013, 08:09 PM   #34
sierra
Drives: Skoda Yeti DSG diesel 4x4
The Mass Airflow is green but it's the only one without a trace on the chart.
I've been picked up many times by women for the blue/green border, they have a better sensitivity to colour so who knows?
Good point with the volume. If that's the case then the chart should indicate volumetric efficiency. The only problem with that is that the lines climbs from just below 3,000rpm to 3,600rpm when it's losing power?
sierra is offline   Reply With Quote
Old 01-25-2013, 08:15 PM   #35
sierra
It still makes no sense that they would have left the gap. The only thing that makes sense is emissions at say 50% of the max rpm which is 3,700rpm and they turned off the port injection to keep it super clean at the expense of some torque.
Old 01-25-2013, 08:17 PM   #36
sierra
That would be very interesting. I'm wondering if Ecutek has the ability to turn it back on?
Old 01-25-2013, 08:22 PM   #37
sierra
No, never heard of them before. The warranty is only 3 years here so i'll save that for later. What do they sell for?
Old 01-25-2013, 11:37 PM   #38
IMOA
Drives: 86 GTS
I think you're underestimating how hard it is to get a flat torque curve! The engine has variable valve timing but lift is fixed and intake length is fixed, you're going to end up with a hole somewhere as you just don't have the adjustability in the intake to maximise VE everywhere. It's a sportscar so it needs to work up top but it is intended as a road car so it needs bottom end to cope with DD. That leaves the lower/midrange which you don't really need for either duties as the one which is the least important. It's not a matter of choosing to leave a hole, it's a matter of not being able to fit the more expensive intake/cam technologies in the price target and then selecting the other items (intake length, cam lift and duration etc) so that they are their most efficient where it matters and least efficient where it doesn't.
You also have to remember that direct injection only gives better torque, not worse. As it's able to deliver the fuel charge very close to the plug the flamefront propogates through the fuel charge quicker minimising the risk of detonation, this lets you run more timing to maximise torque. A number of tuners have remarked that the tune is very aggressive through this area in the maps which re-inforce that the issue is intake harmonics, not tune. The fact that no-one has been able to tune this out even though they have contol over when the port injectors are used also tells you that the problem is harmonics, not tune.
Everything in an engine is about compromise and to me it screams that they've compromised on cost by not using variable lift or variable length intakes (also a reliability issue for that one) which will result in losing VE somewhere which they've placed at the least important spot in the rev range. To minimise this they've gone aggressive in the tune however you can only make up for a lack of air so much in the tune so we're still left with a hole.
The Following User Says Thank You to IMOA For This Useful Post:
Mikem53 (07-21-2013)
Old 01-26-2013, 12:02 AM   #39
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Very interesting thread...
Hoping one of the guys who has been able to mess with the tuning on this car can shed some light...
Flat Black VW is offline   Reply With Quote
Old 01-26-2013, 01:50 AM   #40
sierra
Are you are suggesting the port injection was turned off in that rpm range so that purely direct injection could maximise the torque to compensate for a lack of air? That it's nothing to do with an emission target?
Old 01-26-2013, 02:54 AM   #41
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
That is absolutely correct. The torque dip has absolutely nothing to do with fueling. It's all about VE of the engine across the rpm band. The torque dip is due to a combination of intake manifold and head design. Otherwise, they would have tuned it out from the factory and we wouldn't be having this discussion.
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 01-26-2013, 03:42 AM   #42
sierra
-Acree
Apart from turbo or supercharging, what would be the best modifications to minimise it or would it be a combination of exhaust, intake and ECU tuning across the board?
On the positive side it gives it character. Even at less than 1/2 throttle it lights up at 5,000rpm giving great performance while literally sipping fuel.
The only way I can think to get more air in there is by blowing it in. A free flowing panel filter will maximise the air at those rpm's.
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 07:56 PM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 11:55 PM
It has more power, but less torque. white_knight Scion FR-S / Toyota 86 GT86 General Forum 9 08-09-2012 02:46 AM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 01:22 AM
