Drives: 2013 FRS Whiteout
First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!!
First Turbo FRS in Maryland is complete @ Pure Automotive Performance!
This car belongs to @TyperRspec789! This is the new Full Blown Motorsports Stage 1 Kit which includes: - FBM Base EL Turbo manifold - Garrett GT2871R - FBM Aluminum Wrinkled Black intercooler Piping with couplers - FBM 3" Downpipe - FBM 550hp Intercooler with cast tanks - FBM Intake Pipe - FBM Dump tube - Precision Turbo 39mm wastegate - Tial 50mm Q BOV - FBM 550cc injectors - FBM 270LPH Pump - FBM Dual slim fans - All Hardware/oil lines and gaskets - FBM 7psi Basemap (does not include license) First Half Installed ![]() ![]() There is quite a bit involved with the installation of this kit including modifying the stock fuel pump assembly, installing injectors, removing the oil pan and welding an oil return fitting to the oil pan, running coolant and oil lines for the turbo, fabricating -10 line and fittings for the oil return, removing the front bumper assembly to run piping including modifying some of the plastic ducting behind it, but all in all, its going great! 2nd Half Installed ![]() ![]() ![]() ![]() Completed ![]() ![]() ![]() Custom Boost Gauge Install ![]() Overall, we're very satisfied with the kit! The fitment is great, it takes time and patience to get it right. We also installed a catch can, vacuum manifold, and manual boost controller. The boost controller is there to keep the wastegate in check. It adds the ability for the customer to turn it up later on when he switches to E85 without changing wastegate springs. The vacuum block allows for the boost guage and a much more organized vacuum setup, the stock motor has so few vacuum sources. Once everything is together, it is a little crowded around the area under the turbo, but it is manageable, you don't have to disassemble everything to make adjustments. We're hoping to get some base map dyno numbers soon! We are a Full Blown Dealer, PM for pricing! Last edited by Pure Automotive; 01-30-2013 at 12:13 PM. |
| The Following 6 Users Say Thank You to Pure Automotive For This Useful Post: | Bonburner (01-30-2013), cobrabyte (01-30-2013), Dipstik-sportech (01-23-2013), King Tut (01-24-2013), swift996 (01-24-2013), TyperRspec789 (01-24-2013) |
#2 |
Drives: BRZ DGM
Looks like Russ canceled his kit with avo lol
| The Following 2 Users Say Thank You to Coastermikey For This Useful Post: | TyperRspec789 (01-24-2013), _F-R-S_ (01-23-2013) |
#3 |
Drives: 13 whiteout scion frs
| The Following 3 Users Say Thank You to _F-R-S_ For This Useful Post: |
#4 |
Drives: 2003 Subaru Outback
200 dollar difference and look at what you get, I am not sure how you could go with AVO. Lets not start that though. Kit looks great and I am excited to see the rest of this build.
#5 |
Drives: BRZ DGM
I'm not bashing I just remember he put a deposit on the avo a while ago I don't even know the prices whatever.
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
JKIt's not $200 difference, its $700. AVO adds $600 for ceramic coating. The original $3800 is a more accurate comparison since this one is not ceramic coated either. BUT I digress!! (Even at $700 difference this is a great deal and I agree with you you get a lot of things, but let's be accurate ) I'm sorry, I'm a sucker for accurate information. There are things that some people prefer about AVO like turbo location, UEL header,, internal Wastegate, OEM look, simplicity of the kit (no fuel upgrades, no oil pan weld). I want to end it right here. Let's not start comparing kits here, its Pure Automotive's thread (feel free to delete my post, no hard feelings
#7 |
No worries, just end it there, I have nothing bad to say about any of the other kits out there, I would love to try every single one of them!
| The Following 3 Users Say Thank You to Pure Automotive For This Useful Post: |
#8 |
Drives: BRZ DGM
Become a dealer with innovate ill be your first buyer
#9 |
Version 2 Coming Soon...
Drives: Turbo Argento FRS, Asphalt FRS
I fap to these pictures everyday.. Also I kinda feel like the Stig now that you have revealed who the "customer" is from the parts reviews you've posted. "Some say he only drinks pina coladas when he gets caught in the rain and sells Agency Power catbacks for crackhead prices... but all we know is... he's called 'my customer'".
Part Out Thread: http://www.ft86club.com/forums/showthread.php?t=39992
#10 |
#11 |
This got me excited! More reason to put that oil cooler kit together Brady!
#12 | |
NASA SpecE30 Racer
Did it come with any instruction manuals?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#13 |
The catch is, if you get the new stage 1 kit, which is more affordable, they supply the drain pipe and fitting but you have to drop your pan and drill a hole and line it up and weld it. The old stage 1 kit had a pretapped pan with it, the new one does not.
The reason they send the AN lines and fittings unassembled is to allow for different angles/lenths in case you don't weld the bung in the pan exactly perfect. I have the majority of the instruction manual via email, its not fully complete just yet but they have been more than helpful with things I needed to see a picture of. If you do not have a good amount of experience with turbo kits, AN lines, welding, fuel pump modifying, etc, I would not recommend "giving it a shot" unless you feel comfortable with it. |
| The Following 2 Users Say Thank You to Pure Automotive For This Useful Post: | Asphaltfrs1 (01-26-2013), King Tut (01-24-2013) |
#14 |
NASA SpecE30 Racer
Well that is disappointing news. I knew that the original "Stage 1" came with an oil pan. I was never told that the oil pan was not included in the new "more affordable" kit. I was told the differences were the v band flanges, production parts instead of custom welded parts (cast endtanks), slightly cheaper turbo and wastegage, and no EcuTek license. It would been to nice to have been at least given an option to have it included.
- King Tut
| Full Blown FRS/BRZ Stage 1 Turbo Kit | FullBlown | Forced Induction | 456 | 09-27-2021 04:10 AM |
| First Full Blown Turbo Kit Install @Pure Automotive Performance is In Progress!! | Pure Automotive | Mid-Atlantic | 61 | 01-30-2013 09:38 PM |
| Review of ACT 6 Puck @ Pure Automotive Performance | Pure Automotive | Mid-Atlantic | 3 | 01-10-2013 03:06 PM |
| **Everything Invidia is on SALE!!** @Pure Automotive Performance | Pure Automotive | Engine, Exhaust, Transmission | 0 | 01-08-2013 03:32 PM |
