Drives: 86
Scans from a training manual.
Power/weight: HP: 147kw (200ps) / 200hp @7000rpm Torque: 205nm (151 lb/ft) @ 6600rpm Weight:
Columns: First 2 column are for "small FR sport", column 1 is a higher spec model, column 2 is a lower spec model. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart. Top Section: The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight. Top spec manual is 1230kg, auto is 1250kg. Low spec manual is 1210kg, auto is 1230kg. Then its turning radius. High spec rides on 17" wheels and low spec on 16. Second Section: This section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks premium unleaded and 50L fuel tank. Fuel consumption base model: 13 km/l 30.58 mpg 49.21 kmg Fuel consumption top model: 12.4 km/l 29.17 mpg 46.94 kmg Third Section: This section is front engine/rear drive, transmission type, suspension type, brake then tyre size. High spec brakes: ventilated discs front and rear. Low spec brakes: ventilated front, non ventilated rear. Last Section: Last section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more. More update: Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start". MORE THINGS OF NOTE: Strut front, double wishbone rear suspension Base halogens, optional HIDs on base trim, standard HIDs on high trim LSD on all MT cars Stability control standard Only 2 speaker audio on base car High Spec:
The "Customize Grade" at the bottom is interesting:
the car in fact does require premium unleaded gas (無鉛プレミアム) the rear seat is one piece and is foldable (一体可動式) did anyone mention that the high spec model comes with a digital speedo and tachometer? (デジタルスピードメーター revメーター) Here are translated charts (by our members Spaceywilly and dimension6!!) Training manual images: Last edited by Nardi330; 10-31-2011 at 08:02 AM. |
#2 |
BRZerhood Lurker #13
Drives: 15 DGM BRZ Premium
hey ichi can you translate the spec sheet for us?
200ps and 1200 kg is not bad could have been alot worse |
#3 |
Drives: -.-
13.0 km/liter ? damn high or what .
#4 |
Drives: 86
First 2 column are for "small FR sport", column 1 is higher spec, column 2 is lower spec. 3rd column is Mx5/Miata, 4th is RX8 and last is CRZ. It's a comparison chart.
The top section is the dimension in mm, length width height wheelbase, ground clearance then number of seats. Next is weight. Top spec manual is 1230kg, auto is 1250kg. Low spec manual is 1210kg, auto is 1230kg. Then its turning radius. High spec rides on 17" wheels and low spec on 16. I'll try to figure out more and post here. More: Next section is engine. Boxer 4 DOHC, 1998cc. Output as listed on 1st post above. Drinks unleaded and 50L fuel tank. Then it's fuel consumption. Next is front engine/rear drive, transmission type, suspension type, brake then tyre size. Next section is equipment which is not that easy to understand. First thing I notice is top spec has LSD for manual and auto while low spec only has LSD on manual. I'll post more if I can read more. More update: Both spec have VSC, front passenger and front and rear curtain bags. Top spec has front LED, leather steering wheel, 6 speakers audio (low spec has 2 speakers), white rev counter with shift light and sport pedals. Top spec also has "smart entry and start". Last edited by Nardi330; 10-31-2011 at 08:20 AM. |
#5 |
Thanks Nardi. It's looking more and more like a rwd DC2 type R and that'a good thing
#6 |
Drives: 86
Yeah. The only remaining puzzle are the name and the price.
There is even 1 spec that comes in unpainted bumpers and steel wheels!! |
#7 |
Drives: '12 BRZ [CBS]
Looks like the lower spec won't have the switches and digital tacho like the GT-R, and the bare bone spec is ideal for the track. Cheers Nardi for sharing this
#8 |
Drives: '97 RSP JZZ30 GT-T
haha awesome. i believe the non painted bumpers and steel wheels one is for people who want to take it drifting and want their own wheels and stuff. pretty good idea
#9 |
Drives: 86
A bit like the FD2 Civic Type R where they offered a bare bone car. Only front dash, driver seat (basic style), steering wheel, 4 door trims and nothing else!!
#10 |
Delights in pure handling
Drives: Zoom Zoom
So 197hp/151tq in a car that weighs 2662lbs with a nice interior and exterior? Sign me up and take my money Toyobaru.
#11 |
Drives: Company Vehicle
Looks like we might be getting the tuner model after all!
#12 | |
Drives: ae86 levin coupe
actually its 2711lbs with the "nice interior" also note that the nicer ne has what look like steering wheel controls and interior options for red or black and basic ones have only all black clusters with no shift light or digi gauge I think the 16s look nicer than the 17s that the mule has been running aroun on though
#13 |
Drives: 2005 Hyundai Accent
#14 |
Drives: none
Different headlights for the fully specced model ;o
| AutoBild gives specs of the Subaru BRZ | Ice_Man | BRZ First-Gen (2012+) — General Topics | 43 | 10-30-2011 06:43 PM |
| Guessing Scion FR-S specs?? | dClutch | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 04-28-2011 11:07 PM |
| If there is no Toyota will you go with Scion or Subaru | tranzformer | Scion FR-S / Toyota 86 GT86 General Forum | 91 | 04-25-2011 11:53 PM |
| 200hp / 2700lbs - Really? | Rickster | Scion FR-S / Toyota 86 GT86 General Forum | 385 | 04-18-2011 02:47 PM |
| TRD options and Badging? | BanningFT | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 11-08-2009 03:53 AM |
