Visconti
Old 01-23-2013, 05:39 PM   #197
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Pretty flat power curve peak from 7000 RPM to 7800 RPM. Was the Dynojet sniffer in the tailpipe or the downpipe?
King Tut is offline
Old 01-23-2013, 05:41 PM   #198
Visconti
Drives: 05 STi
Tail pipe
Visconti is offline
Old 01-23-2013, 06:37 PM   #199
Supermassive
Supermassive's Avatar
It's pretty amazing how nice that curve looks, John definitely nailed it during our street tuning time! Also for those that want to know, that's only 7lbs of boost on our crappy 91 octane here in Phoenix.
Supermassive is offline
Old 01-23-2013, 06:40 PM   #200
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The only time I like my curves flat...on a dyno.
Tansey86 is offline
The Following User Says Thank You to Tansey86 For This Useful Post:
Batman (02-16-2013)
Old 01-23-2013, 07:10 PM   #201
Xanatos
Xanatos's Avatar
Drives: @redline, '14 BRZ, '98 Forester
mmmmm that RPM!
Xanatos is offline
Old 01-24-2013, 03:02 AM   #202
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
It's pretty impressive seeing the car continue passed its factory redline and make power... Alright John, I'll let you raise my redline when you get your hands on my car...
TyperRspec789 is offline
Old 01-24-2013, 11:42 AM   #203
Visconti
Drives: 05 STi
ha ha - can't wait to work with you again
Visconti is offline
Old 01-24-2013, 05:23 PM   #204
djliquidsteele
Drives: Scion FR-S
Originally Posted by djliquidsteele View Post
Will there be a way with either the Vortech or the Innovative to run flex fuel. I know I saw something in another post somewhere about using a waste gate on the vortech to run a bigger blower but cap the boost so you get maximum boost earlier in the power band. Is it possible to run a waste gate to dial back boost depending on the amount of E85 you're running?
I'm just going to put this here again hoping to get an answer. Thanks
djliquidsteele is offline
Old 01-25-2013, 09:25 AM   #205
Visconti
Drives: 05 STi
Flex fuel won't control boat on the supercharger a, but yes flex fuel
Visconti is offline
Old 01-25-2013, 09:29 AM   #206
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Do you have a preference on boost controllers for those who want some way to have dynamically adjustable boost settings? I'm not sure if I'm committed to flex fuel yet but dial-a-boost knob sounds neat
Huehuecoyotl is offline
Old 01-25-2013, 04:03 PM   #207
djliquidsteele
Drives: Scion FR-S
Cool. Perhaps I was trying to make things overly complicated. You obviously know way more about than I do. Curious to see how you work the flex fuel into the mix.
Old 01-25-2013, 05:38 PM   #208
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Install boost gauge and control with right foot.
But seriously, I believe John can set up boost by gear through EcuTek... no?
Jeff86 is offline
Old 01-25-2013, 08:01 PM   #209
Huehuecoyotl
I guess my question is more like, can you have different ecutek maps that have different boost settings? Different boost cut offs?
Does ecutek plus a aftermarket map sensor negate the need / or benefit of an externally adjustable waste gate or ebov for sc applications? More specifically is adding a boost controller,no longer needed?
Or does the ecutek boost base map triggers cutoff stuff work good enough you no longer need a Tial or blitz product? Or with a smaller pulley and more midrange boost, is adding such an aftermarket add on to the kit a benefit?
Thank you.
Old 01-25-2013, 08:23 PM   #210
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
John will you be offering a tune for us guys who have purchased Vortech through other dealers?
If I'm reading this correctly it's 600 per tune? With me having the hardware.
Gregg
jdzumwalt is offline
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Visconti Tuning - Who wants to run on e85? or 100 Octane Visconti Engine, Exhaust, Transmission 174 05-21-2013 04:00 PM
VISCONTI TUNING WILL BE IN PHX JAN 18-20 WHO'S READY Visconti Southwest 9 01-06-2013 02:40 AM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 05:29 AM
Visconti Tuning NA STG1 Group Buy Visconti Groupbuys 683 08-24-2012 12:28 PM
