Old 01-23-2013, 01:42 PM   #15
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by RYU View Post
10k? your box says 8k springs
Above the label is says 10k/10k EXTR, which is the true specs.
636 is offline   Reply With Quote
Old 01-23-2013, 01:43 PM   #16
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by RRnold View Post
I know this might be an obvious question but did you preload them?
I called BC because they seemed already preloaded, they told me custom kits come from the factory with preload already adjusted and I shouldn't touch it. So I left it alone.
The Following User Says Thank You to 636 For This Useful Post:
RRnold (01-23-2013)
Old 01-23-2013, 01:44 PM   #17
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by Missourifornian View Post
Well #1 fix the install issue and see if the noise persists. #2 if that isn't it maybe you're bottoming out on something because your car is too low? like tires hitting the plastic liner? Also something could be loose. If nothing else, this weekend tighten up every bolt you removed just to be safe.
It's not a plastic liner/bottoming out noise. Definitely a metal clunk noise. I'll let y'all know how it goes today after the install.
Old 01-23-2013, 06:29 PM   #18
636
636's Avatar
Drives: '23 CWP BRZ
GOOD NEWS EVERYONE!
We adjusted the endlinks, they were colliding with the control arms. After adjustment, there is NO NOISE, and it rides smooth, and stiff as hell! Going lower tomorrow! Here's some good daytime pics of how it's standing right now!
Taken with iPhone 5. Click for HD resolutions.
Old 01-23-2013, 06:31 PM   #19
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That's great to hear. Is the back lower than the front and how much lower are you going to go?
Old 01-23-2013, 06:33 PM   #20
try2findmark
Drives: Bukkake FR-S
Sweet, had the same setup on my lexus but they were 14kf/12kr. How do they ride? Smooth? You on stiffest setting?
try2findmark is offline   Reply With Quote
Old 01-23-2013, 06:35 PM   #21
636
636's Avatar
Drives: '23 CWP BRZ
I'm on 15 front, 15 rear for dampening. They go up to 30. The ride is great though, I love stiffer rides and it feels like a dream. If anything I wish it was a little harder, which it will be!
I'm pretty sure the rear is the same height as the front, but I can double check. And how much lower...well I'm going to keep going until I can't drive the roads I drive on a daily basis anymore. :P I'll probably bring it down another half inch tomorrow, and once camber arms come in, maybe another inch on top of that!
RRnold (01-23-2013)
Old 01-23-2013, 08:23 PM   #22
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
You should get rear spacers for the meantime until you get custom wheels. They'll make the rear tires poke out a little more and look better imo. Car looks great that low dude, good choice
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
The Following User Says Thank You to 6-Shift For This Useful Post:
636 (01-24-2013)
Old 01-24-2013, 12:19 AM   #23
636
636's Avatar
Drives: '23 CWP BRZ
I appreciate it, and I'm thinking of grabbing 25mm spacers for the front and rear!
Old 01-24-2013, 01:29 AM   #24
6-Shift
Señor Member
6-Shift's Avatar
25mm in the front will make the wheel stick out to even with the wheel well and probably not fit as low as you want to go: I'm basing that off this:
http://www.ft86club.com/forums/showthread.php?t=24702
Post #11. just be wary. I'd for sure recommend it for the rear though!
Old 01-24-2013, 01:55 PM   #25
636
636's Avatar
Drives: '23 CWP BRZ
We'll see! :P
Old 01-24-2013, 09:05 PM   #26
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
i got the same box yesterday haha
"8k/8k" label with " 10/10 " written above in magic marker.
the EXTR i thought was "ext" for extenders. i was freaking out because i ordered extreme drops and the labels/manual didnt have any notification of extreme drop but reading in on this thread i noticed the " ext " is " EXTR "
are you maxed out all the way low?! i cant wait to dump this damn thing. keep us posted with pics when/if you order spacers:happy0180:
SLICVIC is offline   Reply With Quote
Old 01-25-2013, 01:18 AM   #27
636
636's Avatar
Drives: '23 CWP BRZ
No where close to being maxed out low, haha. I have a LOT room left. I can probably go about 2-3 inches lower, in all honesty I feel like the frame will be touching at max low.
Although we did lower it another half inch today! Here's some pictures. Once again, click for HD quality.
Test fitting new wheels. :P
I'm not nearly low enough yet.
Another FRS on lowering springs.
Stock BRZ.
And lastly, the clearance to get into my driveway, so going lower!
Old 01-25-2013, 01:36 AM   #28
6-Shift
Señor Member
6-Shift's Avatar
You're crazy dude...I love it. When are you getting the spacers?
K&N Drop In Filters! Available at Vivid Racing!! vividracing Engine, Exhaust, Bolt-Ons 6 06-29-2012 06:53 PM
FRS/BRZ Extreme racing or Traditional racing for success? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 59 12-20-2011 11:46 AM
