#15 | |
SLO NO MO
I have mine set to disable at 11.8 volts or 120 hours. |
| The Following User Says Thank You to Foobar For This Useful Post: | Mo707 (01-21-2013) |
#16 |
Drives: Scion FR-S
can you take a picture of where you installed it? in the rear or front? thanks
#17 | |
#18 |
SLO NO MO
Not sure I'll be able to get a picture up tomorrow - I'm working late so I probably won't see any daylight, but I'll see what I can do.
Install was easy. If you've used an add-a-circuit in your car's fuse box, that's the bulk of the effort. F1point4 has a pretty good DIY article on it if you're not familiar with this. My install went very similarly to his, but I mounted my Magic Pro right above the cutout (it didn't interfere with the harnesses). Wiring goes up the A-pillar on the driver side, tucked along the headliner and right into the camera by the mirror. I have the camera itself mounted right above the rear view mirror on the driver side. The adhesive is on the dot matrix tinted area so it's nicely hidden from view. If you didn't know what you were looking for, you probably wouldn't notice it from the outside. I also have 35% tint on the sides/rears, so that helps to obscure the view as well. I'd mount it on the passenger side for more clearance from the mirror, but I have my Passport radar detector in that spot already. |
#19 |
Drives: Pegasus GTS86
Cool might have to get the 500. I have the 400 and am thinking about moving it to the back for reasons explained above. I'll have to play around with the unit to see how well it captures through a tinted window.
#20 |
Drives: 2013 FRS, Raven, Auto
Does the DR500 still record video at 15,000 bit rate like the DR400?
#21 |
Drives: Scion FR-S
I'm getting a escort 9500ix and I bought a mirror mount for it so I don't know if I can't install the cam behind the mirror
where else could I put it
#22 |
Drives: 2013 Argento Silver FR-S
Post some vids whenyou get a chance? How's the wifi feature? transfer vids and permits live viewing?
#23 | |||
SLO NO MO
Originally, the 1920x1080 resolution seemed like it had quite a bit of video compression going on, so I switched it from high to normal. We'll see what change that had on the video output when I get home tonight. Edit: Just wanted to add that I've had the camera running all weekend in park mode as well as normal, and this new design does not appear to have any overheating issues. It does get warm, but nothing that you wouldn't expect from any other solid-state electronic device that is always on. Seems that the larger enclosure and the double-vented design is a winner here. Last edited by Foobar; 01-22-2013 at 10:56 AM. |
#24 |
Right click on the video file, select the Details tab. What does the data rate say.
My DR400 uses 7407kbps. (I was wrong on the 15000) Compared to GoPro HD2: 15000 GoPro Hero 3 Black 1080 @ 30fps: 20000 GoPro Hero 3 Black 1080 @ 60fps: 30000 When you look at the black asphalt road on the DR400, the blacks are grainy on the fast moving road. It looks much better on the GoPro with higher bitrate. My DR400 (from ebay) seems OK in the heat and winter. |
#25 | |
SLO NO MO
I can tell you that fast moving video on the 500 is nothing like that captured with a GoPro. This is good enough for security/evidence capturing, definitely not good enough for actual fast-action video recording. |
#26 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i wish there was a good camera that had both front and rear at same time, or front and inside at same time.
gonna order this most likely though...foo loving the catback btw! |
#27 |
Drives: toyota camry
i wonder how it performs when u park your car under 44 deg C sun with parking mode on..
#28 | |
SLO NO MO
Re: catback - I knew you would. No silencers right? I should've charged you more ![]() Sent from my Galaxy Nexus using Tapatalk 2 |
| DIY Blackvue DR400G-HD/Power Magic Pro Dashcam | F1point4 | DIY (Do-It-Yourself) Guides | 194 | 06-12-2020 01:08 PM |
| Dash Cam Installation (BlackVue DR400G-HD) | DarrenDriven | DIY (Do-It-Yourself) Guides | 93 | 05-01-2018 09:54 PM |
| GROUP BUY: Blackvue DR400g-HD II | LeavingNormal | Audio/Visual, Electronics, Infotainment, NAV | 61 | 04-11-2013 11:14 AM |
| Bad luck kitty (Blackvue) | BRZranger | BRZ First-Gen (2012+) — General Topics | 20 | 10-11-2012 12:00 AM |
