| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#337 |
Drives: fast
soo....
You can get this now - and could 11 years ago when honda came out with the s2000. Essentially same targets, speed, mpg etc... Different ways of going about it.
Conv vs coupe .. progress
#338 | |
Drives: fast
30k is steep for a rwd 4 cyl. But you know what.. it will still sell. Just because you've got corolla money, doesn't mean toyota is going to sell you a race car.. they'll sell you a corolla. Save up - the 27k will be worth it. If you don't like it - you can get a Genesis. Or a mustang. Or a civic Si. Last edited by aids333; 10-27-2011 at 03:46 PM. Reason: related info |
#339 | ||
There are going to be a lot of other bits and pieces we don't see that are parts bin, and that was the goal of this car as Toyota/Subaru have stated, to keep the price down by using what they could. Of course the transmission had to be designed for this car, but I wouldn't be surprised if a lot of it closely resembles other Subaru transmissions (its cheaper to modify an existing blank for a part than to make a whole new design from scratch). Quote:
But keep in mind, other than the direct injection, this is just a RWD converted Subaru platform with a new design chassis. There is no reason for this car to cost even close to $30k. |
#340 |
Drives: '06 AM V8V Coupe
Well the engine isn't really parts bin if they changed the block and internals which they did otherwise it wouldn't have the redline indicated in the photos.
#341 | |
Drives: '96 beater Corolla
A different iteration is by definition not parts bin. Plus this engine doesn't even have the same bore stroke as an FB20. |
#342 | |
![]() Nothing is 100% identical anymore. The same part can be slightly different in the same car just because of the different trim level of the car, even from different states they can be different. Does this mean the different part was 100% re-engineered from the ground up? No! The part blanks in Japan or wherever the parts are made are slightly modified per the order. In fact, in Japan parts are made in an "on demand" basis, so its easy and cheap to slightly modify a part and not as complicated as you think. The engine for example, the EJ25 Turbo in the Forester from 2004 has completely different part numbers from the STI motor. However, the differences are so small between the molds for those blocks that its almost impossible to tell they changed something, yet they have completely different engine designations and power outputs. The heads on the FT/BRZ engine are probably going to have quite a bit of changes to accommodate the DI but that doesn't mean the motor is going to be 100% different from an FB. Other than the chasis, the engineers for this car didn't start with a blank slate. We've seen in the articles relating to this car that they used the general architecture from Subaru and went from there, that makes this a parts bin car not something like the LF-A which was designed from the ground up with every bit being 100% engineered just for that car. Does this mean almost every car is actually a parts bin car? Yes. Its not financially possible for companies to make everything from scratch every time they make a new car. |
#343 |
Drives: Slowly
The fact that it's a "parts bin" car is actually a good thing as it:
a) keeps the price down b) means there's aftermarket parts support from day 1 c) is basically the same architecture that I've modifying for 17 years |
#344 |
#345 |
Registered you sir
Drives: 99 impreza coupe
I <3 the lego-like parts aspect of Subarus.
#346 |
Drives: RX8 S1
pretty sure that the heads will be differnt. suspension will be the same TYPE but not the same.. rates of springs and valving in shocks wil be completly different..
so new chassis, new suspension, new engine (part there of), new tranny, thats all i care about. everything else can be recycled from a 1950's fiat for all i care (bar the tires and wheels)
#347 |
Drives: Slowly
Hey 7ONYD, would you like to buy a spare engine?
I'll be slotting an EJ in there as soon as I get mine. |
#348 |
Hmmm... interesting teal like highlighting there...
And that curb weight is not a pretty number. Nor is the city/hwy.
I am the Ice Queen.
Logic > Emotion ┬──┬◡ノ(° -°ノ) Yashio Factory Pink adds +10HP to anything. TOYOTA FT-86 ![]() |
#349 |
hashiryu
Drives: Mk4 Supra
Whoa @ the sniper thread title change
#350 |
Drives: Civic Si
200hp for 30k? Ill pass if thats anywhere near what theyre thinking
| Tags |
| brz review, brz reviews, scion fr-s review, scion fr-s reviews, scion frs review, scion frs reviews, subaru brz review, subaru brz reviews, toyota ft-86 review, toyota ft-86 reviews |
| How come Toyota has 2 prototype and Subaru has none? | moda3 | BRZ First-Gen (2012+) — General Topics | 30 | 09-06-2011 02:39 PM |
| Different wheels on the prototype | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-20-2011 06:00 PM |
| Prototype lapping the ring | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 14 | 05-20-2011 07:05 PM |
| Hyundai Calls 2011 Sonata Turbo "Very Delicious," Reveals Near-Term Future Plans | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-19-2010 03:53 PM |
| Wheels on the Prototype | joshuo | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 11-03-2009 08:37 PM |
