Old 01-16-2013, 10:20 PM   #547
CSG Mike
CSG Mike's Avatar
Originally Posted by Hanakuso View Post
Yeah I was talking about where I made a red arrow. Noticed the more inner J-Hooks also have some very slight grooving on yours and mine but it's barely noticeable.
I also noticed my left front brakes sound like a train going "chee chee" at low speeds after I swapped back to street pads. I'll make a sound clip and post it. I'm guessing I might of slightly warped my left rotor.
Are you using the C300 or S100 in the front?
Old 01-16-2013, 10:49 PM   #548
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
sounds like pad deposits.
Surok is offline   Reply With Quote
Old 01-16-2013, 11:34 PM   #549
Hanakuso
As of right now Hawks HPS. I was using C300 for the track
Hanakuso is offline   Reply With Quote
Old 01-17-2013, 01:50 AM   #550
CSG Mike
CSG Mike's Avatar
Sounds like you may have deposits... just bed the HPS and u should be ok
Old 01-17-2013, 02:01 AM   #551
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
just FYI - my choice on pads for the Essex Endurance kit
I went with Ferodo DS2500 allaraound for the street use (huggy & acceptably silent), and will be swapping the fronts for AP C300 for the events, leaving rears with DS2500's
Jeff assured me this combo would work great in both cases
Cheers!
MSTiFK8R is offline   Reply With Quote
The Following User Says Thank You to MSTiFK8R For This Useful Post:
Anthonytpt (01-24-2013)
Old 01-17-2013, 08:33 AM   #552
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Grooved discs
A little bit of grooving on any disc with race pads is nearly inevitable. I don't think I've ever tracked a car without having some sort of minor grooves appear on a disc. When I worked at StopTech and had their brakes on my C5 Z06, the discs looked like Pringles! That said, I never had any problems as a result. As Dave was alluding to, if you're tracking your care frequently, you're going to crack your discs long before you run them thin...period. So nothing to worry about there.
Hanakuso,
Your discs are not warped. And yes, the hat is seated properly on the disc. Please don't waste your time searching for a "problem" because of a little squealing. That's just pad interaction on the disc face. When you run ANY pad hot on a disc, it's going to leave a film of pad on the disc called a transfer layer. All pads are different, and how much and how thick the transfer layer is will be different...and how that pad reacts with other pads is going to always be different. When swapping from street to track pads, you have to manage the process. Have you ever seen this video I did? There's another one on there about bedding pads as well.
If you guys start running into massive judder/vibration (you hit the brakes and the brake pedal and steering wheel go thunka-thunka-thunka), then you need to start looking at solutions...and you will know if, when that happens...and that can happen, even with the best system. You just have to know how to manage your brakes.
From everything I've read/seen in these last two pages...everything is working awesome, and as intended, with our systems under heavy track use. No brake fade, no judder, soft pedal, no odd pad wear, no serious disc cracking even after quite a few events and extended hot lapping sessions.
Is that a fair statement? It's obvious that some of you have been to this rodeo before, and others have not. Those of you who haven't just need to understand/and learn about what you're seeing and how brakes react to getting cycled at 1200 degrees F over, and over, and over again. I'll do my best to show you that. The videos on our website will help a bit, and I can answer other questions. Finally, if you're ever unsure about something, just call me! :happy0180:
Off to a meeting...I'll check back in later to answer any other questions. Thanks.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following 2 Users Say Thank You to JRitt For This Useful Post:
track_warrior (02-05-2013), WillRacer1jz (01-18-2013)
Old 01-17-2013, 09:32 AM   #553
JRitt
JRitt's Avatar
How much track use will the endurance kit take?; I do about 10 trackdays a year and will add an sc kit shortly.
As someone else mentioned, we've had 300+ whp FT86's run our smaller Sprint system without any issues. The same components are regularly winning races on 500hp circle track late models. We use the components from our Endurance system on C5 and C6 Corvettes, Evo's, STI's, M3's, FD RX7's, etc...all substantially faster and heavier cars. These brakes offer stellar track performance on all of those platforms...you can see some of the customer responses on our blog under the "essex racing" tag.
There is a red 643 WHP Lancer Evo RS in San Jose California regularly running our Endurance System on the track, and they work great on that car. If that thing can't put a dent in the Endurance System's armor, an FT86 certainly won't.
To answer your question directly, even the most souped up FT86, on a brutal braking track, with a top driver will not exceed the Endurance System's performance envelope. That's precisely why it is designed the way it is!
www.essexparts.com
The Following User Says Thank You to JRitt For This Useful Post:
ICantAffordAnLFA (01-17-2013)
Old 01-17-2013, 10:44 AM   #554
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
I'll be sending you an email; just need to recheck the fitting template.
I've 18x7.5 CE28s
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 01-17-2013, 04:10 PM   #555
Hanakuso
Grooved discs
Hanakuso,
Thanks for the info. That makes sense about why there is some noise. I wasn't too concerned since it was just purely noise, I didn't have any negative braking feel like shutter, vibrations, etc. Just thought I might of reinstalled the street pads incorrectly.
Old 01-18-2013, 02:59 PM   #556
JRitt
JRitt's Avatar
Big news on the AP Racing road car systems gentlemen. We are officially getting the fully built AP Racing front and rear system that fits stock wheels!
I'm going to start a new thread on them and get all the details up on our blog. Thanks.:happy0180:
www.essexparts.com
Old 01-18-2013, 03:13 PM   #557
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Not for me, but nice!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-18-2013, 03:26 PM   #558
Ro_Ja
Drives: TOYOTA
YAY!!!!
Ro_Ja is offline   Reply With Quote
Old 01-18-2013, 03:34 PM   #559
JRitt
JRitt's Avatar
Originally Posted by Ro_Ja View Post
YAY!!!!
You asked for it buddy...now you better buy one.
www.essexparts.com
Old 01-18-2013, 03:43 PM   #560
Ro_Ja
Drives: TOYOTA
Oh, don't you worry.
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
