Old 01-15-2013, 11:29 PM   #1527
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
Originally Posted by tuckdaddy View Post
I'd recommend the Adams products to keep it looking that way after your opticoat!
I use Adams as well. So yes, i suggest you use them too.
Got3n is offline   Reply With Quote
The Following User Says Thank You to Got3n For This Useful Post:
tuckdaddy (01-15-2013)
Old 01-16-2013, 12:40 AM   #1528
TravBRZ
Drives: 2013 DGM MT BRZ
Anyone on here have the Firestorm FRS that made it on the news? Story about a Via cop not wanting to cut his hair on KENS5. As they transitioned to a shot of a Via building they got a good shot of the FRS rolling by.
TravBRZ is offline   Reply With Quote
Old 01-16-2013, 01:21 AM   #1529
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I hope to meet up with you folks one day...soon!
tripjammer is offline   Reply With Quote
Old 01-16-2013, 03:27 AM   #1530
FrsRN
Where should i go and how much to get opti coated
FrsRN is offline   Reply With Quote
Old 01-16-2013, 07:05 AM   #1531
blunova
"Slyde"
blunova's Avatar
Drives: 2013 SWP BRZ
Concours Auto Salon! A couple of us had it done there and it looks great! They charge $250.
blunova is offline   Reply With Quote
Old 01-16-2013, 08:40 AM   #1532
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
I got mines done at Jays Detail. Hes very good. Price can vary depending on the amount of work that needs to be done to your car. Mine was $550 cause I had lots of swirls in the coating from the factory, but it was totally worth it. Jay is running a group buy right now for $400 and its a great price, he does the the whole thing. If you want just the coating and want the removal of swirls and what not, then I would suspect it to be cheaper.
You can see my shots here. http://imgur.com/a/aBYqY
Old 01-16-2013, 10:16 AM   #1533
aaronosaurus
The data matters
Drives: WRBP BRZ
Originally Posted by Speedy000 View Post
RCE springs r designed with fuction>form in mind.
What problem with the suspension are they fixing?
most drivers will not install coilovers and have them set up properly to use them at 100% anyway.
Very true.
Improving the motor is easy to prove quantitatively(e.g. dyno graph). Its much harder to do with suspension, partially because at a fine level it really maters who is driving, and how you drive. Harder mounts, and other changes that increase the rigidity suspension or change the alignment under force are even suspect now that the original automotive engineers have simulators that can model the deformation of individual parts.
edit: What I'm trying to say is if you want to make it lower and stiffer BECAUSE RACECAR go for it. But you can't say everything is empirically better just because it's lower and stiffer(twss).
aaronosaurus is offline   Reply With Quote
Old 01-16-2013, 10:23 AM   #1534
Got3n
86-75309
Got3n's Avatar
Drives: Toyota FR-S
If you really want to go, i have an open seat on saturday morning, I dont drive super fast but you are more then welcome to join.
Old 01-16-2013, 11:17 AM   #1535
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Very true.
The FR-S spring differ slightly from the BRZ, we're set up for oversteer. The RCE's are a mild drop (0.8in) and while balancing the car out causing it to handle more like a BRZ.
Also everyone expects something different form the car, and everyone will find things they do not like. I am running wider, sticker tires. To me the amount of body roll is unacceptable, that's the beauty of these cars the aftermarket is there to cover down.
We have a saying in the medical world; " If a placebo works, it's not a placebo". So If I slap on coilovers and tun better times at an autocross event just because I am more confident in the car than so be it.
Just to clarify your edit comes off as slightly pompous, I won't dispute your knowledge on the subject because I don't know you. Hell for all I know you're an engineer with Toyota , that still doesn't make you omnipotent so keep it civil in the local thread ( and if that wasn't you're intent, my apologies)
Ricepuddin is offline   Reply With Quote
Old 01-16-2013, 12:05 PM   #1536
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
On another note. Another reason to love driving this car! Name:  ImageUploadedByTapatalk1358352328.411556.jpg
tuckdaddy is offline   Reply With Quote
The Following User Says Thank You to tuckdaddy For This Useful Post:
Got3n (01-16-2013)
Old 01-16-2013, 12:34 PM   #1537
mRdeMs83
mRdeMs83's Avatar
Drives: Argento FR-S 86
On another note. Another reason to love driving this car! Attachment 25503
I filled up at 35.40 last night
Argento ate6
mRdeMs83 is offline   Reply With Quote
Old 01-16-2013, 01:08 PM   #1538
aaronosaurus
The data matters
Drives: WRBP BRZ
tldr; I'm sorry if I came off as pompous, it wasn't my intention. I just want everyone to have a reason for the changes they make to their car.
I wasn't trying to be hostile, there is a meme of doing things "because racecar," and if thats why someone wants to make a change to their car I'm fine with that. But I'm trying to save johatan25 and anyone else playing along at home from potentially making a mistake on these cars with a modification thats a sure thing on other cars. Most vehicles have compromises made in the suspension for comfort, but the big selling point of these cars is the amount of engineering effort they've put into the suspension.
Your situation is different, you had a problem with the suspension(it's not quite stiff enough for the stickier tiers) and so made a change to try and fix that problem. Saying "I couldn't beat that Mini at autocross, put new coilovers on the car, now I can run faster than him" is as close to empirical evidence of more grip as we can get. It's not 100% because of the amount of variability between each autocross run, let alone from event to event.Motor tuning, on the other hand, allows us to replicate the conditions of each test almost exactly. We can quite literally run an identical test at the push of a button. This lets tuners demonstrate how the changes they've made to the vehicle change the performance of the vehicle.
Old 01-16-2013, 01:29 PM   #1539
johatan25
johatan25's Avatar
Drives: Lightning Red BRZ - Premium 6MT
This decision is getting a little harder to make. While I am wanting to lower my car for looks, I want to keep in mind that I don't want to compromise its performance, but improve it, even if its slightly. (Basically looks + a little performance improv, I'm sold). I know little about vehicle modifications, so I rely mostly on other people's experience. @Ricepuddin, I am still solid on the springs. But if I can get even more details, I'd really appreciate. I would like to add, I am running 235/35/18 Falkens on all 4 wheels. I appreciate all the insight and advice from all of you!
The FR-S spring differ slightly from the BRZ, we're set up for oversteer. The RCE's are a mild drop (0.8in) and while balancing the car out causing it to handle more like a BRZ....
tldr; I'm sorry if I came off as pompous, it wasn't my intention. I just want everyone to have a reason for the changes they make to their car...
Mods done (RED), Mods to come(BLACK): LED Swap, GReddy SP Elite Exhaust, Leather Seats, TSW 18x8.5 + 235/35, MOTIV Over & Catless Test pipe, EcuTek 93 Octane tune, PERRIN Lightweight Pulley, PERRIN Intake Inlet + drop-in filter,, e85 fuel map, 5axis Spoiler?, Borla UEL Headers?
johatan25 is offline   Reply With Quote
Old 01-16-2013, 01:35 PM   #1540
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
In fairness, that's the only part I was referring to. Everything else you said came off knowledgeable and trying to help out, so we can probably chalk it up to an internet misinterpretation, so again my apologies.
Official What are you listening to thread? TRDMAN Off-Topic Lounge [WARNING: NO POLITICS] 2326 12-24-2024 11:16 PM
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
The official hand drawn thread. LexusFman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 12 04-06-2013 06:11 AM
Official 2011 WRC Season Thread 4agze Other Vehicles & General Automotive Discussions 4 04-01-2011 05:13 PM
