Old 01-15-2013, 09:11 PM   #57
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
How about these??? Legal or not
Again...just Stimulating Thought
Scooby South is offline   Reply With Quote
Old 01-15-2013, 09:32 PM   #58
EN2_Squirrel
EN2_Squirrel's Avatar
Are RLCA'S allowed? i cant find anyhing about them. I would really like rear camber adjustability. For the strut bar i think you can only use a 2 point. the car doesnt come with a factory strut and the rule states a 2 point may be added. For a 3 point it doesnt say you can add one.
Sent from my SCH-I510 using Tapatalk 2
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 01-15-2013, 09:51 PM   #59
xwd
No. . There is no provision to replace the toe link and the trailing arm is explicitly not allowed. I'm assuming you mean the blue pieces, of course the camber/control arm is replaceable as long as the right bushings are used, no spherical bearings.
The Following 2 Users Say Thank You to xwd For This Useful Post:
EN2_Squirrel (01-16-2013), Scooby South (01-15-2013)
Old 01-15-2013, 10:07 PM   #60
Scooby South
Conedancer
@dwx ... ...thanks, you must be the Rules Nazi in your region...... this is good, that way people become familiar with whats legal. Half the reason alot of folks don't go Autocrossing is that they are afraid of what they have done(mods) is wrong, Whereas you and I build the car according to the Rules..because we have a plan..
thanks for the assist ... If we can get others to look at the rules first... instead of just throwing parts on it we will have a better educated community.
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
heeltoe86 (02-14-2013)
Old 01-16-2013, 01:04 AM   #61
EN2_Squirrel
All i meant was for the rear lower control arm. not the blue pieces but that still very useful to know. the car stock has no rear camber adjustability and i would really like some. Thank you.
Old 01-16-2013, 01:09 AM   #62
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
if I do lca's and go turbo what class are we?
Huehuecoyotl is offline   Reply With Quote
Old 01-16-2013, 01:47 AM   #63
EN2_Squirrel
Iknow that the seat with rails must weigh 25lbs but what about harnesses.4 or 5 point. Thanks, I really appreciate having rule nazis who prevent me from unknowingly messing up.
The Following User Says Thank You to EN2_Squirrel For This Useful Post:
Scooby South (01-16-2013)
Old 01-16-2013, 08:02 AM   #64
Biggins
Drives: Yes
If you or any of the FRS/BRZ contingent run the strut brace at a national event and even some big local events, I'm quite confident it will be protested. The Hotchkis site even calls it a 4-point. I already gave my opinion on it here.
Biggins is offline   Reply With Quote
Old 01-16-2013, 08:57 AM   #65
apexaddict
You technically have two options for rear camber adjustment, both are by Whiteline. One option is the rear camber adjustment bushings, which replace the rear upper control arm bushings. They should be legal as the bushings themselves look to be a direct replacement, and the metal insert doesn't contain any additional metal, it just has an offset hole.
The other option (which I don't think exists yet, but they were at SEMA) are the Whiteline rear lower control arms. These are the only RLCAs that are STX legal since they still have a poly bushing where they attach to the subframe - all the other ones I've seen (Cusco, Agency Power, DME, etc.) use a spherical bushing, and would therefore be illegal.
+1, these are absolutely not legal for the class. Not that it's much of a concern, as they are a complete waste of money to begin with...
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 01-16-2013, 09:48 AM   #66
xwd
The SPC one also appeared legal.
http://www.spcperformance.com/compon...AFrom&to=USATo
They are also probably half the cost of the Whiteline at 290. And come with an offset bushing for the toe link if you need it to account for the camber change.
Old 01-16-2013, 09:59 AM   #67
xwd
Street Modified. A class I think the frs and BRZ could be very successful in if prepped well enough, but it takes $$$.
Old 01-16-2013, 12:15 PM   #68
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
Powerflex also has rear camber adjustable bushings as well... I have them up on my website. There are so many I gave them their own menu on the left of my webpage (Powerflex not those bushings specifically). Also I want to note that ALL the Powerflex bushings listed have the correct photo's attached... those are not examples, those are the actual parts.
Sam Strano is offline   Reply With Quote
The Following User Says Thank You to Sam Strano For This Useful Post:
Old 01-16-2013, 10:34 PM   #69
EN2_Squirrel
Sweet. I already have those but have neglected putting them on due to not having complete understanding of the rules. Also the 290 is for each one.
Old 01-17-2013, 11:19 AM   #70
bdohazelnuts
Drives: Asphalt Grey FR-S (soon)
This thread should definitely be stickied!
bdohazelnuts is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
