| View Poll Results: ? | |||
| SC |
133 | 38.33% |
| TC |
159 | 45.82% |
| NA |
55 | 15.85% |
| Voters: 347. You may not vote on this poll | |||
I usually post drunk
Supercharger or Turbo ?
I will be getting a SC because I've never had the luxury of owning a FI vehicle and the whine of an SC makes me
#2 |
Enjoy it, destroy it.
Drives: Datsun Racing Hen
I prefer the near instant boost of a S/C. Turbos are for drag racers and bragging about power levels on the internet. On a road car, in terms of torque curves, flat > ski slopes.
Although, that said, I won't turn away from a turbo version if one is made available from the factory. |
#3 |
hashiryu
Drives: Mk4 Supra
Turbo plz.
#5 |
Thee O-ri-gi-na-tor
tornado intake
#6 | |
Administrator
Drives: Boxster 986
#7 |
Drives: Scion xA, Toyota MkI Mr2 (Sold)
It all depends on where the rpm is restricted to.
If the redline is <7k I will take a SC If the redline goes up to 8k or 8.2k I will take a turbo. More effecient a higher RPM and more room for tunning (cheaply) v/s a Supercharger. Turbo will work great on a high rpm vehicle. Supercharger looses its salt value in the top end. If the red line is 8k....that's 5000 rpm to play with without getting a "butt kick" or unexpected rise in boost/hp and torque. Most turbo induction systems are in full boost around 2-3k factory (OEM). If there is a 7k redline supercharger will be good for 5k as well. 1k rpm to 6k (starting to loose efficiency at this point) Also all depends on the turbo etc.. If this is an aftermarket option I would say none of the above unless a TRD version comes out with a F/I option. Last time TRD offered a supercharger for their "sport" coupe (Scion TC) it only added 40 crank hp...and was known to fail often without upgrading the pulley. It wasnt even the S/C that would whine (centrifugal vs. ROOTS) All up to what the options are. If the car weighs under 2700 a good NA build will be more than sufficient unless you are drag racing. Otherwise I can see 50whp and 30wtrq and good increase in power/sound/feel as being sufficient. If they are going to squeeze 200hp out of a 2L engine, it will cost money to get 300hp (ITB's, Cams, Long-tube's, Fuel: E85/93oct Premium) 250 crank will be the most realistic goals in terms of $ per H/P vs. Forced Induction. Not to mention, the compression ratio will not be favored for forced induction unless they change that with a forced induction version. Otherwise you will need pistons, forged internals, fuel system upgrade, fuel upgrade (premium or E-85) to handle higher temps and prevent Detonation. So if toyota releases a TRD version with a forced induction option, it will all depend on the compression ratio and the redline. And out of the 2, turbo is my favorite bb88BBoo00OOss55SSttTT----FfFf3EE3vVVv4AA4 ![]()
| The Following 2 Users Say Thank You to RegisBou For This Useful Post: | thebear21 (09-10-2012), Toyota86.ir (03-10-2016) |
#8 |
MODERATOR-SAMA
Drives: Swagtron Scooter
I am probably going to stick with the N/A D-4S if a turbo model from the factory will not show, and as much as im a fan of turbo, i don't think adding F/I will be as simple with this motor compared to other engines like it.
Id bet money that Toyotas variant of the D4S is going to be pretty high reving, with high compression numbers. So a factory made N/A with +200hp and +200TQ is going to be enough for me.
#9 |
Drives: MX5 Miata Mk2.5 1.6
FI is a bit too feminine
#10 |
Drives: D31a
I would be surprised if the US gets the 2L and not a 2.5L engine. If we do get a high-revving 2L then SC, if we get a little more torquey 2.5L then TC.
#11 | |
Is a Monster
Drives: AE86, MA70
Granted they were ceramic, and boost over 14psi would undoubtedly create a destruction you wouldn't want. |
#12 |
Resident Post Whore
Drives: 2022 WR BRZ
Turbo all the way for me.
Gavin
#13 | |
Completely agree
#14 |
Drives: Toyota Corolla SR5
as my name goes 4agze a 4age w/ a supercharge all the way, but for the FT86 flat4 I may get a turbo.
| Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) — General Topics | 118 | 11-16-2017 02:19 PM |
| 2L turbo exiga. | 86Fan | Engine, Exhaust, Transmission | 16 | 06-26-2010 06:36 PM |
