orthojoe
Old 01-05-2013, 11:14 PM   #29
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Originally Posted by nix View Post
ABS is still active in this mode. What it does is disable VSC, TC, Auto LSD. I agree with you though people should be careful!!
Wow really? I wonder how Mike got his FRS to lock up the tires on the track this way... More mysteries.. ack!
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
Old 01-05-2013, 11:33 PM   #30
nix
nix's Avatar
Drives: AVO BRZ
Yeah I am a grip driver but still had problems with it kicking in. Most people here wouldn't need this mode but for those who really push their cars it's great.
I have thought about installing the auto factory cut switch since I have the matching interior panel space but because I have a push start button I think I have to break the starter barrel open to splice into it. Bit of a job for a rainy day ..
nix is offline   Reply With Quote
Old 01-05-2013, 11:34 PM   #31
ayau
Drives: Some rust bucket
I'm getting two sides of this debate.
1) The pedal dance will disable ABS.
2) The pedal dance will disable auto LSD.
Which one is it?
Can someone clearly explain how this pedal dance is different than holding down the traction button down for 5 seconds?
Old 01-06-2013, 12:00 AM   #32
CSG Mike
CSG Mike's Avatar
Brake bias; electronic brake distribution freaked out and put all the braking force to the rear. I was running a large differential between the front and rear in terms of both compound and piston surface area.
Old 01-06-2013, 12:01 AM   #33
CSG Mike
CSG Mike's Avatar
Which one is it?
My conclusion is that it disables electronic brake distribution and the "panic stop" mode. You can stab at the pedal, and it won't "add pressure".
Take it for what you will; that's just what I discovered in my testing, and as always, YMMV.
Old 01-06-2013, 12:05 AM   #34
ayau
So does it disable every single electronic aid for this car? It seems like we need to get the real answer from Toyota/Subaru.
Old 01-06-2013, 12:07 AM   #35
CSG Mike
CSG Mike's Avatar
Given that it's officially a "diagnostic mode", I think so. The does exactly what I ask it to do in this mode, whether its trail braking, sliding, drifting, or gripping.
Old 01-06-2013, 02:24 AM   #36
gmookher
curious, what pad combo?
must go play with the pedal dance tomorrow!
gem
Old 01-06-2013, 02:52 AM   #37
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Is anyone interested in a module to do this for them?
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 01-06-2013, 03:04 AM   #38
CSG David
CSG David's Avatar
gem
XP10/XP8 on the 225 RS3 fronts and 215 Z1SS rear tires.
The CSG BRZ currently runs XP12 all around and 225 RS3s all around.
The Following User Says Thank You to CSG David For This Useful Post:
IBill4You (10-15-2016)
Old 01-06-2013, 03:10 AM   #39
CSG Mike
CSG Mike's Avatar
I may have tried some other combos...
CSG David (01-06-2013)
Old 01-06-2013, 08:46 AM   #40
DarkSunrise
DarkSunrise's Avatar
CSG Crew, really appreciate the time and effort you guys are putting into the development of this car (and your willingness to share your results).
2022 BRZ Build
2013 FR-S Build
Old 01-06-2013, 10:56 AM   #41
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Doesn't turning off the traction control by holding the button for 5secs do the same thing as this or am I missing something? I noticed no weird brake "interference" when I did that at the track...
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 01-06-2013, 01:53 PM   #42
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I can confirm this works on the AT Trans. Should help launching the AT much more easy.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
zohare (01-17-2013)
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
