Old 01-04-2013, 04:56 PM   #141
Sac-BRZ
Drives: BRZ Limited AT
Dang.. Struck a nerve there it seems. And what is honey boo boo?
Sac-BRZ is offline   Reply With Quote
Old 01-04-2013, 05:05 PM   #142
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
The black smoke is not what a Cat removes from your exhaust.
"The catalyst helps to convert carbon monoxide into carbon dioxide. It converts the hydrocarbons into carbon dioxide and water. It also converts the nitrogen oxides back into nitrogen and oxygen."
Just get a high flow CAT =]
HotLava FRS MT
Neziah is offline   Reply With Quote
The Following 2 Users Say Thank You to Neziah For This Useful Post:
sierra (01-04-2013), Sportsguy83 (01-04-2013)
Old 01-04-2013, 05:36 PM   #143
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
google it.
Old 01-04-2013, 06:54 PM   #144
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
google it.
You're cruel.
For the record, I've never watched the show. But I've been to the internet. Tis a silly place.
On the exhaust:
Does anyone know if there are any potential technical problems caused by running two cans off of the same exhaust pipe? I personally am not really a fan of the setup in general but I know a LOT of exhausts do it. I'm interested in this mostly for curiosity's sake. I want the Milltek myself.
Nathan
SubieNate is offline   Reply With Quote
Old 01-04-2013, 07:57 PM   #145
FR-S Matt
It's a fat, ugly ass baby that's now a small fat little kid. There.
Old 01-04-2013, 10:10 PM   #146
sierra
Drives: Skoda Yeti DSG diesel 4x4
I would feel bad about running without a cat, but then every time I drive I see some asshole diesel owner POURING out black smoke because he thinks its cool. So screw it, I'm going catless.
It's very rare to see a diesel putting out black smoke[unburnt fuel] these days but when they do it's deadly for anyone else in that area. Diesel is a known carcinogen. They would get pulled over and taken off the road pretty fast here.
Modern diesels[I have one] run very clean and quiet, most without a hint of anything from the exhaust. It doesn't smell quite as sweet as the 86 in the garage but it's certainly not obnoxious.
It also has a catalytic converter fitted just after the turbo.
Any cop should be capable of picking up the stink when they follow your car without a cat and should pull it over and take it off the road until it's fixed.
I hate negative emission controls that give small short term savings in exchange for higher fuel consumption, shorter engine life and rapid loss of efficiency. Thinking diesel EGR that blocks the inlet manifold.[not mine]
However catalytic converters have transformed the air we breath while driving and are simple, long lasting and have minimal effect on efficiency.
sierra is offline   Reply With Quote
Old 01-04-2013, 10:21 PM   #147
OrbitalEllipses
Drives: Attitude
Ever seen a chipped and modded VW diesel? Those are DIRTY and go like stink too.
Old 01-04-2013, 10:59 PM   #148
sierra
I had mine chipped for a while. It was done on a dyno and was wild, it even had slightly better fuel economy cruising but there was no smoke from the exhaust. That's caused by overfueling and could be fixed by increasing the boost to burn it or backing off the fuel at the appropriate rev ranges.
If there is enough air for the extra fuel and the fuel pump/injectors/combustion chamber/exhaust/turbo limitations aren't exceeded, then with the correct mixture the emissions should be acceptable.
Old 01-05-2013, 01:11 AM   #149
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Just an FYI, the black that comes out of the exhaust of a built diesel is not smoke it is soot. It doesn't get into the air and stay there it settles to the ground. I would rather drive around the diesels than a cat-less car.
Generally (to an extent) the more you mod a diesel the better economy you get.
Cade01 is offline   Reply With Quote
Old 01-05-2013, 03:47 AM   #150
sierra
I called it smoke to stay with the theme and I agree. If it was smoke it would have been burnt but it's not, it's the result of over fueling, over advancing the injection timing is another cause.
Both of them are bad news for our health.
Old 01-05-2013, 04:48 AM   #151
TRD_86
Drives: 2013 86 white
Originally Posted by NickFRS View Post
Just to get everyone back on track
Nameless
Perrin
If based on the sound of these 2 clips, the nameless has better sound than this perrin imo.
TRD_86 is offline   Reply With Quote
The Following 2 Users Say Thank You to TRD_86 For This Useful Post:
NickFRS (01-06-2013), Sportsguy83 (01-06-2013)
Old 01-05-2013, 05:09 AM   #152
sierra
Yes, definitely the Nameless sound.
It's also a work of art compared to the Perrin big box OEM style with a tail pipe sticking out from each end.
The Following User Says Thank You to sierra For This Useful Post:
Old 01-05-2013, 10:36 AM   #153
FR-S Matt
There's a few reasons why I'm leaning towards Nameless: (Warning, opinions below)
1. Small shop, great guys that are passionate about what they do and produce.
2. Cost, much cheaper and no sacrifice in performance/quality.
3. Design, well thought out, goes above my head in how it works, but it does.
4. Nameless all hand built in house, unsure about Perrin.
5. Sound, unresonated Perrin is raspy as hell. Resonated is okay, but the Nameless rocks it in sound so far with the stock midpipe.
6. Overpipe design combined into one piece rather than charging you 2X for a bent pipe to a front pipe
7. Perrin seems more mainstream while Nameless is that small shop that surprises the hell out of people with the products they make.
Nothing against Perrin whatsoever. I've considered buying their headerback because it has proven performance and a long track record with Subaru's. I will most likely be buying a Perrin product for my car at some point, like the pulley for starters. The Nameless system offers the same performance, even with their tri stepped header but weighs quite a bit less overall.
You really can't go wrong with either company. It's simply a matter of taste and who you are proud to support. The Nameless guys are fun to work with and I had a great experience talking to Jason so far. I'm sure if I contacted Perrin, it would be the same. Jeff is working hard on tuning the cars now and I'm interested in those threads a lot.
Both companies have their headers coming soon. Nameless posted an update about their flanges coming in for them, but they're tweaking the design for production mode. Perrin I haven't gotten/seen an update in regards to their header.
The Following 4 Users Say Thank You to FR-S Matt For This Useful Post:
NickFRS (01-06-2013), number1Tango (01-22-2016), Sportsguy83 (01-06-2013), stockysnail (01-06-2013)
Old 01-06-2013, 04:21 AM   #154
NickFRS
Drives: 2013 Asphalt FRS
Love the Nameless Support!
NickFRS is offline   Reply With Quote
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Nameless Performance Exhaust Group Buy jwuwu Southern California 56 10-28-2012 11:11 PM
Question about Nameless Performance exhaust Metallic BRZ Engine, Exhaust, Transmission 16 08-05-2012 10:06 PM
Nameless Performance Exhaust Group Buy jwuwu BRZ First-Gen (2012+) — General Topics 1 07-24-2012 03:12 AM
