Old 01-03-2013, 11:12 AM   #127
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
Doesn't changing the trans fluid, void your transmissions warranty?
Nate219BRZ is offline   Reply With Quote
Old 01-03-2013, 12:33 PM   #128
gmookher
not so long as fluid meets api and gl4 specs
Old 01-03-2013, 02:01 PM   #129
Nate219BRZ
Nate219BRZ's Avatar
Are you sure on that, my buddy changed his 350z fluid and because he changed it, nissan voided his transmission warranty?
Old 01-03-2013, 02:35 PM   #130
Cameronghanson
Drives: n/a
Talked to subaru of america and It doesnt unless it was obviously done wrong...just like changing your oil doesnt void engine warranty.
Cameronghanson is offline   Reply With Quote
The Following User Says Thank You to Cameronghanson For This Useful Post:
Nate219BRZ (01-05-2013)
Old 01-03-2013, 04:13 PM   #131
Dezoris
Dezoris's Avatar
If you throw a quality trans fluid in this car and after a week you are still having issues with the trans being notchy or difficult to engage gears either you should not be driving a manual trans or your transmission has a serious problem.
The Following User Says Thank You to Dezoris For This Useful Post:
Old 01-03-2013, 04:21 PM   #132
gmookher
right any fluid meeting gl4 will work, but some do work better than others
Old 01-04-2013, 01:26 PM   #133
Gum
Gum's Avatar
Drives: Honda
I have shifting issues as well. When the car is cold, I cannot get into second so I have to shift to 3rd instead.
The car has 5000miles and I replaced the fluid with Redline MT90. It didn't make any difference when it is cold and it seemed to be better when it's very hot.
My friend has the same issue and his car is even worse. He tried Motul Gear 300, it made it worst. He went with MT90 at the end and issue still not fixed.
Anyone tried any fluids that work ?
Gum is offline   Reply With Quote
Old 01-04-2013, 01:36 PM   #134
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
I tried to search this thread but nothing came up so I hope this hasn't already been mentioned, sorry in advance if it has,
Tripple Cone Synchro 6SPD M/T
http://ken-gilbert.com/wrx/STi_Manua...nchronizer.pdf
I'm no professional but this could be what you guys are experiencing and just not used to tough trannies.
Jared0934 is offline   Reply With Quote
The Following User Says Thank You to Jared0934 For This Useful Post:
Purdue FR-S (04-02-2013)
Old 01-04-2013, 07:54 PM   #135
sierra
Drives: Skoda Yeti DSG diesel 4x4
The Redline is 75w-90 and the Pentosin MTF-2 is 75w-80.
The Pentosin has had some rave reviews in these threads for solving syncro problems, especially cold.
Why not give that a go and let us know how it works out?
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
gmookher (01-05-2013)
Old 01-05-2013, 03:44 AM   #136
ozne99
Drives: GBS BRZ Limited
Same issues when it's cold as well. After about 5 miles or so, it becomes smooth. It's definitely something I don't enjoy during the commute in the morning.
ozne99 is offline   Reply With Quote
Old 01-05-2013, 03:59 AM   #137
sierra
It's summer here so I will make sure to have the oil changed before winter.
Old 01-05-2013, 12:38 PM   #138
David R
Drives: 2013 Scion FR-S Manual / Blue
Well Yes at 750miles I too have a rough shifting transmission/clutch & a clunk in the drive train. It's been like this since day one. I have 40 years experience driving manual transmissions is 240Z, VW, RX=7 Mustang & big trucks + others. My FR-S tranny shifts like its worn out into 1st & 2nd , clunks & grinds. Feels like the input shaft has excessive end-play??
David R is offline   Reply With Quote
Old 01-05-2013, 02:24 PM   #139
Cameronghanson
Drives: n/a
I switched over my diff and tranny fluid to redline and it did solve everything. It just feels a lot more engaged and smooth. Getting into each gear gate is so much easier. Can't recommend this enough especially if you drive the car in the winter or cold temps.
Old 01-05-2013, 02:26 PM   #140
OrbitalEllipses
Drives: Attitude
A friend of mine said that the shift feel on the triple-cone synchro gears (1st, 2nd, AND 3rd I think) would be funky due to the triple cone synchro.
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
