#15 | |
Drives: 2013 BRZ Limited SWP
On an Auto-X course though I'm sure the wider tires are faster.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
#16 | |
Grip>Drift
Drives: FRS
I have a much wider set-up that is identical to stock tire diameter. I get more grip and no loss of power due to taller tire. In the viedo they mention they use a taller tire, but don't talk AT ALL about how that effects the result. It's put a ton of misinformation on the boards. |
| The Following User Says Thank You to BlaineWasHere For This Useful Post: | glamcem (09-16-2014) |
#17 | |
But I think this still helps to show that for lower powered cars a wider wheel/tire is not necessarily going to be faster around a track. In this case the mild extra grip simply couldn't overcome the lack of power this car has for this track. (you would think with extra grip you would gain speed through a corner and actually be faster out of a turn despite the taller gearing but this wasn't the case) Also wider tires can diminish your road feel, alter the cars balance and willingness to rotate, and affect turn in so for most people who have these cars and will never see a track, wider may not be the best decision and in fact may diminish the 'feel' and 'fun' of driving. One of my previous track cars was a miata and putting huge tires on it really reduced the fun of driving it. It could carry a ton of sped through the corners though. ![]() BTW, in the article they do talk about how the taller diameter and 18" wheels/tires affected acceleration. They may not have addressed this in the video.
| The Following User Says Thank You to TSY For This Useful Post: | BlaineWasHere (09-03-2012) |
#18 |
To the OP
I guess it really depends on what you want and how much you're willing to spend. Ideally, a different set for street and track- one for show and one for go. And if you are doing a lot of track time the extra wear and tear you save driving around town and to and from the track might pay off over time (especially if you move up to R-comps) If you're just driving on track for fun and no one is timing you, then spending thousands of dollars on tires to save you 4/10 per lap probably isn't really cost effective. And as poor as these OEM Prius tires are, it certainly is fun to be on the edge of grip and slide the back end a little. So maximizing your lap times and grip may not be the most fun you can have with this car.
#19 |
Drives: Subaru BRZ
#20 |
#21 |
Drives: Scion FR-S
I agree with TSY. I had a miata with stock size wheels and tried a much bigger wheel and it totaly ruined the feel of the car. I wanted to go 18" with the FRS but do not want to ruin the way this car feels. looks like im going with a lighter 17x7 wheel with a stock size star spec or RS3. and I will be running CS RTR in 2013 at least for now.
| The Following User Says Thank You to Gearhd79 For This Useful Post: | TSY (01-02-2013) |
#22 |
Drives: 3 series
Let me tag my questions on to this thread rather than starting a new one.
I am begining to order parts for primarily a track / weekend toy. No Auto-X, just not my thing. But lots of respect for the guys who make it happen. Just a dizzying array of options for tires / wheels and very little concensus or hard data for what works well. Local track is PIR. Pretty fast track. My thoughts are to go as light as possible as the motor will remain stock. I am settled on 17" wheels, which seem to make the most sense. I am absolutely struggling over wheel width and offsets as well as tire width. Car is going down 20mm, which I understand will bring the wheels inboard a bit??? My inital thought is to stick with 225/45. I know a lot of guys are running 245/40, but I skeptical that this is leading to better lap times. Any input here? Tire options in 235/40 is limited and 235 / 45 is getting a bit tall. So I am liking either 225 or 245. Wheel options are many as well, but I have narrowed it to these. I am going to run Enkeis and have it narrowed to these. Will some of you experts please comment on my thoughts? Especially concerns of offset. 17 x 7.5 +48 - 15.25 lbs. -lightweight. offset may be a bit high. limited to 225 tires. 17 x 7.5 +38 - 17.15 lbs. - this was the setup on the yokohama / enkei demo car. safe / conservative if a bit heavy. limited to 225 tires. 17 x 8.0 +35 - 16 lbs. - can run tires from 225 to 245 no problem. concerned may stick out too far. 17 x 8.0 +45 - 16 lbs. - can run tires from 225 to 245 no problem. Is this too much inset? Finally, does going +35 or +45 affect scrub radius enough to make a difference on these vehicles? I would think not, but wanted to get your thoughts. Thanks in advance and stay safe out there! Last edited by Z-PDX; 01-04-2013 at 01:17 PM. |
#23 | |
your saying you need more than r comps at 225 width? I am looking at going to a 235 or 245 as well next, but unsure if its worth the weight penalty vs potential extra entry/exit speeds |
#24 |
Drives: TOYOTA
I'm curious; there's a lot of talk about diameter and width, but what about offset? I've heard bits and pieces about keeping the offset close to stock, but it was never concrete information. At what point does a wider stance (that offers more stability) outweigh the drawbacks of the scrub radius change? What about track widths? Basically, when it comes to offset, how low is too low? Are the effects of a low offset wheel weakening wheel bearings or knuckles something to take into consideration with this car? Apologies for the semi-vague question, but I hope someone understands what I'm getting at.
#25 | ||
We have a few different wheel setups, so we'll keep you posted as we get more development done. Long term reliability effects are... unknown as of yet. We'll need years of data before we have anything conclusive to say there. Quote:
http://www.ft86club.com/forums/showp...37&postcount=4 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ro_Ja (01-04-2013) |
#26 | |
[ame]http://youtu.be/r_IWa_qlt3g[/ame] |
#27 |
Drives: gt86
Good question ..... that preparers will a 18 "?
another question. the car is approved for 215 ... if we put more tire width .... that would be the equivalent? |
#28 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Reviving from the semi-dead...
http://www.tracksideperformance.com/...13-product.pdf http://www.michelinman.com/mediabin/...orts_Final.pdf http://www.hoosiertire.com/pdfs/speccat.pdf Terminology Note: Race slicks are not DOT-R compound tires. DOT-R compound tires are, by definition, not slicks. DOT-Rs have grooves, slicks do not, and when seen in person it's very easy to visually confirm what you're looking at. |
| The "prius tires" misconception | WhiteGDB | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 04-24-2015 02:56 AM |
| Odometer Functions - "S" & "G" What are they? | kablammo | BRZ First-Gen (2012+) — General Topics | 59 | 12-01-2013 01:28 AM |
| Winter Tires and 17" Rims?? | stalon320 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 06-03-2012 09:33 AM |
| Anybody considered using 16" wheels for the track? | ft86Fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 12-08-2011 10:55 AM |
