Old 01-03-2013, 04:34 PM   #659
exbauer
Drives: Automobile
Originally Posted by sevi21 View Post
Finally got the windows tinted today. Decided to go with 20%,
on my last vehicle i had 5% and i found that a bit too dark.
But here she is!
That is really sick. Talking about sleeper at night.
exbauer is offline   Reply With Quote
The Following User Says Thank You to exbauer For This Useful Post:
sevi21 (01-04-2013)
Old 01-04-2013, 10:08 PM   #660
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Thanks man appreciate it!
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 01-07-2013, 12:34 AM   #661
whataboutbob
AutoX-10/10ths every run
Installed Hella horns. Didn't have to pull the front bumper off. Went in from underneath with the car on jackstands. I hate dealing with those S**TTY clips on the corner markers.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
dun3 (01-07-2013), FR-Shadow (07-11-2013)
Old 01-07-2013, 01:33 AM   #662
dun3
dun3's Avatar
Drives: 2013 Ultra Marine Blue FR-S
Pics if you can!
dun3 is offline   Reply With Quote
Old 01-07-2013, 02:28 AM   #663
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Originally Posted by paula View Post
JDM badge or one from a USDM car?
Cade01 is offline   Reply With Quote
Old 01-07-2013, 12:10 PM   #664
whataboutbob
Originally Posted by dun3 View Post
Pics if you can!
I didn't take any pics, but the install was pretty straight forward. I used this http://www.ft86club.com/forums/showthread.php?t=14123 howto for wiring info.
1) Get the car up on jackstands so you can get underneath it.
2) There's an outer plastic cover that covers the area between the bottom lip of the bumper and the jacking point on the front of the car. Remove all bolts and plastic tab/screws/whatever they are called. Pull the plastic cover off and set aside.
3) There will then be a plastic submember. Remove all bolts and plastic tabs/screws/whatever they are called. There are 2 of these tabs that are connected from the opposite side of the submember, use a screwdriver to push the center UP and then they can be pushed out (actually up) from underneath. Pull the submember off and set aside.
4) Locate both horns (on passenger side) and disconnect the wires at the factory clip.
5) Remove horn from area behind grill on lower end of bumper.
6) Locate the 2 10mm mounting bolts referenced in the above howto and remove them.
7) On the horn that is mounted on the driver's side, run 2 wires from each of the terminals over to the factory lead for the horn behind the grill. The factory lead has 2 wires, black (ground), black/green (power). Connect one wire to each using a vampire tap or equivalent, polarity does not matter for the horns.
8) On the horn that is mounted to the passenger's side run 2 wire from each of the terminals over to the factory lead for the horn behind the grill. Connect one wire to the black wire referenced in 7), and the other to the single wire on the factory harness for the other horn (this is a positive lead).
9) Test the horns. Troubleshoot as needed.
10) Put everything back together.
11) Profit!!!
Build thread:Here
Old 01-07-2013, 02:06 PM   #665
SkitterSkotter
SkitterSkotter's Avatar
Drives: 2013 Scion FR-S (Hot Lava)
I was driving back from town today and there is a ton of gravel on the roads (from recent snows)...well it makes the drive home so much more fun! Holy shit, it was fantastic, just go into a turn going about 25 and get on the gas and do glorious drifts....makes me happy I bought this car. Way too much fun all the time lol
SkitterSkotter is offline   Reply With Quote
Old 01-07-2013, 02:20 PM   #666
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Post 666 sounds like you where doing some evil driving lol
Old 01-07-2013, 02:31 PM   #667
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Have my 86 for one week now. Just had custom tips installed and the muffler delete done. Now it sounds like it should.
RevoG is offline   Reply With Quote
Old 01-07-2013, 02:35 PM   #668
SkitterSkotter
lolz, best be sure I was. I really need to pick up a helmet and take my car to the track.
Old 01-07-2013, 02:45 PM   #669
Accurate Race Shop
Drives: Scion FR-S
Yeah I auto Cross and track mine it's a boat load of fun on a track but it really shows it's true colors during autocross because it is a little low on power for the average track but still a blast to take out there.
The Following User Says Thank You to Accurate Race Shop For This Useful Post:
HotLeopardMama (01-07-2013)
Old 01-08-2013, 01:35 AM   #670
WINFREDFRS
Drives: 2013 WHITEOUT FR-S
WHITE OUT FRS
ANYONE IN SOCAL OR SAN DIEGO COUNTY THAT HAS DONE MODS TO THEIR FRS..I GOT 2000 MILES ON MINE AND ITS STILL STOCK
ANYONE OUT THERE SAVY THAT IS NEAR??..LOOKING TO CHANGE SCION BADGE TO TOYOTA...ADDING THE 86 STICKERS AND OTHER STUFF..PM ME..PLZ..
WINFREDFRS is offline   Reply With Quote
Old 01-11-2013, 04:45 PM   #671
Cade01
Cade01's Avatar
Just finished putting on new badges and mounting my plates, now my badges match my title
Old 01-11-2013, 05:21 PM   #672
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Drove it!!
tuckdaddy is offline   Reply With Quote
