#15 |
A clutch bypass should have no effect on it; I've done it both holding and not holding the clutch down, as well as in gear and in neutral...
#16 |
Captain Cocoa
Drives: CBS BRZ MT
I know a tech who said there was a way to turn it all off but he wouldn't say how. I don't think they're supposed to divulge this info.
#17 |
Well, I did the pedal dance right. Mike's procedure worked for me, though it took a while because I kept trying before the car warmed up. It might be easier to use my techstream cable. I worry about pulling things from the OBD port when the engine is running, and I won't want the laptop in the car all the time.
#18 |
Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
This should almost be a sticky thread.
![]() 2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily |
#19 |
Drives: Asphalt FR-S
Ah, now I get it! This is the third thread mentioning "the pedal dance" but not the real effect.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 |
#20 |
Grip>Drift
Drives: FRS
Good info!
#21 |
Drives: nissan frontier, DGM MT BRZ
good info thanks!
#22 |
Drives: BRZ WRB Pearl Limited Manual
Thanks for sharing... I vote to Sticky this Thread.... :-)
#23 |
Drives: 2013 BRZ, 2002 WRX
So, now someone with Arduino smarts should create a little board that performs the 'dance' with the push of a button. I dread having to do this before every track session interval.
Thanks for the info, OP!
#24 | |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
This reminds me greatly of a scenario I experienced in my last Autocross ( ). Thanks for testing this out for us. I'll have to check it out myself the next time I go out.
#25 |
Drives: Many types of cars in R&D.
Ok the secret is out I guess...
![]() Just be very careful as the FRS is a rapid responding car and if the driver isn't quick and accurate and very versed with dynamic car control, things can get hazardous pretty fast at high momentum inputs. We learned on analog cars like this in the past with older cars, but threashold was a lot more forgiving back then with moderate tires and compliant frames, chassis and suspension. This car is like driving a Lancia Stratos or a Lotus Elise when it's fully analog, and if you ask anyone of age who know them, you'll understand what I am getting at here. Go for it! But stay safe!!
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
| The Following 23 Users Say Thank You to Moto-P For This Useful Post: | Celicadude (01-23-2013), chanomatik (01-24-2013), CSG Mike (01-05-2013), CxG (08-03-2015), Fly Guy (04-26-2013), fooddude (04-06-2014), heeltoe86 (03-13-2013), HunterGreene (05-01-2013), IShouldStudy (03-14-2013), Magiclow (04-10-2015), mfbmike (08-31-2013), mixxxx (04-03-2018), mkiisupra (01-06-2013), mo8ius (03-22-2013), Nasty Sausage (02-06-2014), Pat.Thornton (05-10-2016), QFry (02-12-2013), Quentin (10-23-2014), TofuJoe (08-21-2018), TorontoNat (06-05-2018), virobloc (03-25-2013), why? (09-22-2015), zohare (01-17-2013) |
#26 | |
Drives: AVO BRZ
This was posted in September by @086A who found it in the repair manual. This ft86 system is called auto lsd it's like a supplement to the diff where the electronics apply abs pulse to the loaded wheel when the lsd is struggling.
http://www.ft86club.com/forums/showt...186#post464598 Quote:
#27 | |
The VSC intervention in the all off mode from 3 sec press of TRC switch, normally available will allow almost all but the largest of slip angles, and allows you to be sideways pretty much in most all situations... What you get with this additional step is the ABS function to turn off, leaving you with fully analog car. But in most cases the ABS is a completely beneficial thing and unless you're training to be a better all-around driver, the ABS should be left on so you're not flat spotting tires or losing precious seconds off the lap by having it being off. ![]() It's not a performance enhancing mode really, it is more a diagnostic mode for benching the car's performance without electronic intervention.
Moto Miwa
#28 | |
Drives: AVO BRZ
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 11:24 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Dyno testing and "drivetrain loss" | serialk11r | Other Vehicles & General Automotive Discussions | 5 | 11-03-2011 08:55 AM |
