Old 10-15-2011, 02:39 PM   #267
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
What about other things like airbags? If it weighs around 2400 lbs with 200 hp/150tq then I am in love!!! Thats the same p2w ratio as a GC 3.8 track.
SUB-FT86 is offline   Reply With Quote
Old 10-15-2011, 02:43 PM   #268
MiguelAE86
Drives: NB Miata
Guys, did you notice how the rollcage nicely fits into these pre-cut (i think) holes in the dash? WIN.
Edit: found a picture. The yellow arrow points to the actual factory-made holes (maybe it'll have a plastic cover when not in use? most likely, i believe) and to the left of it, you can see (for some reason) Gazoo Racing has made alternative holes and placed the Rollcage there.
MiguelAE86 is offline   Reply With Quote
Old 10-15-2011, 05:05 PM   #269
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Originally Posted by Kiwi View Post
Also plus the weight of the passenger seat and rear bench, that should be where most of the extra weight is.
Rear bench weighs 10 lbs, passenger seat weighs 35 lbs, that was included in the interior weight reduction . . . I also think they either deleted AC or it never came with it(optional), since the vents are fake.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 10-15-2011, 05:20 PM   #270
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
the admin from the 4agze forum mentioned a while back that it will have holes in the dash for the purpose of adding a rollcage
VenomRush is offline   Reply With Quote
Old 10-15-2011, 06:47 PM   #271
Matador
hashiryu
Drives: Mk4 Supra
lol.. looks like the stole the tyres from off the Lexus CT200h nurburgring racer.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 10-15-2011, 07:02 PM   #272
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by blur View Post
Subtract 150 lbs for the massive rollcage, add ~75 lbs for interior weight reduction... 2350 lbs? INSANE. lol
Nah. I think a roll cage in a car this size will be lighter than that, and also there was probably a lot more than 75 lbs of weight reduction. But 2555 might not be as far fetched as I initially thought (I'm trying not to get my hopes up until it's official).
Yeah that was reported a long time ago... between the pre-cut holes in the dash and the engine mount points being the same as EJ20, they're really trying to make this car track and mod friendly.
Last edited by Deslock; 10-16-2011 at 08:26 PM. Reason: rumor was for 2555 pounds, not 2550 pounds
Deslock is offline   Reply With Quote
Old 10-15-2011, 07:30 PM   #273
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Marrk View Post
FWIW, the October 2011 issue of _Car_ magazine says that the FT-86 will have "around 200 hp and 170 ft/lb torque." Their info is probably old, but I like that torque number.
Edit: They also said that there was a lightweight Type R "in the pipeline."
Bull. Shit. That's 85 ft-lb/L, Ferrari territory (89 with the 458), and Ferrari has fancy continuously changing profile cams and a complete disregard for noise and fuel economy. With 7400rpm redline max power comes at about 7000 probably, which someone computed to be about 150ft-lbs at that speed. Max torque isn't going to be much higher than that, 160 at best I think.
Old 10-15-2011, 07:38 PM   #274
Marrk
Drives: Honda Fit
Don't sugarcoat it, serial. Tell us what you really think.
Marrk is offline   Reply With Quote
Old 10-15-2011, 07:46 PM   #275
serialk11r
I don't think we have confirmed figures yet, but I can't see this exceeding the 2GR-FSE specific torque, which is a tad under 80 lb-ft/L. The 2GR has the advantage of larger cylinders so theoretically less thermal loss. Because they're using a Subaru based engine which doesn't have enough height to accomodate sophisticated intake timing systems, I think this is the best they can do (160lb-ft).
Because the red bar is at the 7400 mark, I assume that means max power happens around 7000. Combine that with the upper limit of 160lb-ft and I think we won't be seeing 210hp even, which if other people's calculations are mistake free requires 157.5lb-ft at 7000rpm.
Old 10-15-2011, 07:49 PM   #276
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by PAImportTuner View Post
It's for the turn signal. In this location there is a logo that also lights up. Subaru has a GM-like fender vent slightly above this location and the turn signal is mounted on mirrors instead.
Originally Posted by madfast View Post
is this a joke? a logo that lights up? where the hell do you get this stuff from?
Originally Posted by Sea1monkey2 View Post
errr...ummm...
i'll just leave this here
Originally Posted by KevinDuMa View Post
I get the idea of what he's saying, turn signal symbols like the ones on the Z
But I doubt those will be on the Fr-s
PA, you sounded so certain it was for a light! So much for that
Old 10-15-2011, 07:54 PM   #277
Marrk
Drives: Honda Fit
Dude, everyone on this forum is "certain" about everything. That's why making a simple post here is like entering a fight to the death.
Old 10-15-2011, 07:57 PM   #278
sfwg
Drives: 2007 saturn ion(dd)
i hope there is a way to replicate this in the production model so once i get coilovers(post warranty) i wont have to roll it up on 2x4's just to get a jack under it.
sfwg is offline   Reply With Quote
Old 10-15-2011, 08:02 PM   #279
RRnold
2 wheel member
RRnold's Avatar
Here is a better angle. You can see the partial circle closer to the pillar but since they added the stress plate with the embossed holes, it looks like they had to fabricate another opening in the dash.
Old 10-15-2011, 08:03 PM   #280
Marrk
Drives: Honda Fit
If that is what it looks like, then I'm surprised. Because it adds weight.
Have other race cars had such things?
Bad news about race gas in california. Tougerenner Southern California 15 09-13-2013 10:38 PM
OMG this is hilarious - motorcycle race bofa Other Vehicles & General Automotive Discussions 6 07-06-2011 07:37 PM
Leo Parente on Toyota Race Cars and Motor Sports (FT-86 included) Matador Scion FR-S / Toyota 86 GT86 General Forum 22 07-06-2011 09:07 AM
Mazda MX-5 GT Race Car...WOW Mouse Other Vehicles & General Automotive Discussions 9 03-31-2011 02:02 AM
what/who do you race Abflug Off-Topic Lounge [WARNING: NO POLITICS] 33 09-03-2010 02:13 PM
