go_a_way1
Old 12-28-2012, 09:57 AM   #239
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Originally Posted by ayau View Post
so you're selling?
No longer selling. I figured that I can always get a BRZ down the road. It would be hard to find another CR & wouldn't want to start over with the track s2k. I'll get a BRZ down the line.
Just to add... The dealerships have quite a few BRZs in the NYC area. Selling for MSRP.
iLuveKetchup is offline   Reply With Quote
Old 12-28-2012, 11:23 AM   #240
ayau
Drives: Some rust bucket
Just as a reference point, this is how hard I'm driving the cars. Look at the rear tire in this picture. Looks stretched right? You can see the rim against the background. Also look at the compression. I'm on 16k springs square this day.
This is what the car looks like at rest...
just curious, what dampers are you running on the 16k springs?
Old 12-28-2012, 11:29 AM   #241
OrbitalEllipses
Drives: Attitude
Originally Posted by fenixv8 View Post
LOL not faster than my S2000 was:
Body kits make you go fast?
Old 12-28-2012, 11:29 AM   #242
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
Probably Tein super racing coiler overs?
fenixv8 is offline   Reply With Quote
Old 12-28-2012, 11:32 AM   #243
CSG Mike
CSG Mike's Avatar
More specifically, a custom valved set of Tein SRC (not EVS spec) that were on loan to me for setup and feedback.
Old 12-28-2012, 11:32 AM   #244
MattZ28
Drives: 2005 S2000
I don't see a car in this picture.
MattZ28 is offline   Reply With Quote
Old 12-28-2012, 11:37 AM   #245
fenixv8
fenixv8's Avatar
well the kit was less weight than some of the stock parts and some of this helps too
Engine Modifications Mugen carbon-fiber intake system, header, exhaust system, oil cap & rad cap; J's Racing carbon-fiber radiator plate & oil catch can
Drivetrain J's Racing 4.4 final drive, ATS carbon 2-way LSD, AP1 flywheel
Engine Management Hondata Flash Pro
Wheels, Tires & Brakes Volk Racing CE28N 18x10.5" (f/r) wheels, Yokohama Advan A048R 265/35R18 (f/r) tires, Rays aluminum lug nuts, Spoon monoblock calipers (f), Mugen active gate brake rotors, Endless CC RG brake pads, Endless brake lines
Suspension & Chassis KW Variant 3 coilovers, S2000 CR sway bars, ASM GT strut tower bar (f) & floor brace; J's Racing strut tower bar (r), bumpsteer kit, roll center adjusters, camber ball joints & rear diff spacer; Spoon Sport lower tie bar & X-brace; aluminum diff bushings
Also the body kit is 10cm wider in the front and back to hide the wider track and 10.5 inch wide wheels
Old 12-28-2012, 11:57 AM   #246
CSG Mike
CSG Mike's Avatar
I'd be willing to put my CR against your car on track to demonstrate what a few well chosen parts can do versus a fully decked out car
In "full" trim (I've never actually run it in this state...):
BYS cooling plate
Tein SRC, custom valved (note my "almost stock" ride height)
J's racing front offset ball joint
SPC rear offset ball joint
BBS RG-R 17x8.5 with 255 RS3
J's Racing 70RR
FlashPro
Everything else is otherwise stock with no additional weight reduction, unless an aftermarket clutch and bucket seat count.
ayau (12-28-2012)
Old 12-28-2012, 12:02 PM   #247
fenixv8
fenixv8's Avatar
BYS cooling plate
J's Racing 70RR
FlashPro
Some solid mods you have there.
I had Custom Tein SRC at one point. You should look into KW Clubsports.
Old 12-28-2012, 12:15 PM   #248
CSG Mike
CSG Mike's Avatar
But that's a downgrade! (and a rather substantial one...)
Alas, the SRCs are a loaner set that I won't have much longer
If I were to purchase my own set, at this point, the only two options I'd consider are SRCs valved to the spec of my loaner set (~4150 retail) or JRZ RS (~5700 retail). While the KW work, IMO, they're not really suited for track duty with modern tire compounds; KW's stubbornness and refusal to update their product for modern tire compounds really shows. Their products for strut fronts are a great value, but not the V3/CS for the s2k. The problem here is similar to the brake problems that S2ks have: the car was designed 15 years ago for compounds available 15 years ago, not today's stuff. A 255 RS3 is easily sticker than the 205/225 R-comps that were run on s2ks when the car first came out.
You can read the woes of trying to get custom valved V3/CS on S2ki's R&C subforum... KW swears that their shocks are perfect and that we can't possibly improve them.
Old 12-28-2012, 12:26 PM   #249
ayau
BYS cooling plate
J's Racing 70RR
FlashPro
i'm assuming some sort of track pads too?
Old 12-28-2012, 12:29 PM   #250
CSG Mike
CSG Mike's Avatar
I can get away without them for a lap... maybe...
ayau (12-28-2012)
Old 12-28-2012, 12:35 PM   #251
ayau
kind of off topic, but i'm interested in @CSG Mike's opinion.
what "solution" would you recommend to achieve some negative camber on the BRZ? i'm pretty set on some SPC camber bolts at the front, but i'm unsure about the rear. possibly the stock lower control arm with an adjustable one? i figured these parts will get me about -1.5 degrees of camber.
i suppose you could also get some lowering springs for additional camber, but they'd have to be pretty similar to the stock springs, otherwise you're going to need to upgrade to some aftermarket dampers.
Old 12-28-2012, 12:46 PM   #252
CSG Mike
CSG Mike's Avatar
It's not an issue that we've run into since we're currently on coilovers that are fully height adjustable (for camber in the rear) and have a camber plate + crash bolt in the front...
ayau (12-28-2012)
FR-S vs S2000 vang FR-S / BRZ vs.... 436 09-19-2012 04:52 PM
E36 M3 vs FR-S vs S2000 (for me) RearDrive FR-S / BRZ vs.... 48 07-02-2012 10:46 PM
S2000 or MX-5 balance Other Vehicles & General Automotive Discussions 10 11-01-2011 02:01 AM
S2000 from hell CyberFormula Other Vehicles & General Automotive Discussions 13 07-09-2010 09:05 PM
