Old 12-28-2012, 09:12 AM   #15
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by Foobar View Post
The dot matrix border on our windows will not allow tint to adhere. That's just a fact of the raised surfaces preventing cohesion. The only way to address that is by paying extra to have it glued in or by cutting before the area and using a vinyl wrap instead.
Agreed and I can live with that. However, the job that they did was not everywhere the same. On some part of the Window the dot matrix was visible (Thats ok with me if it is like that all around) and on some it was not.
I'm used to the dot matrix not being tinted on my previous cars, however seeing the dot matrix line for 3cm, than 2 cm not seeing it, and onther 1 cm seeing only half of the dot matrix, next 4-5 cm seeing the full dot matrix again etc just looks shit in my opinion :-)
Killerbee is offline   Reply With Quote
Old 12-28-2012, 09:14 AM   #16
Killerbee
Killerbee's Avatar
Originally Posted by gily25 View Post
Bubbles as in expanding air or you can see bits of liquid? If it's cold then when it warms up they should dry up and it'll be fine. Ditto on the dot thing mentioned above. Some rear defrosters mess it up too fortunately our car isn't one of them.
It was air, no water in it. Also, I asked specifically the tint guy about if it needs another 2-3 weeks to dry out, and his answer was no, that just what it will be - and we think is fine like that.
Old 12-28-2012, 09:33 AM   #17
Foobar
SLO NO MO
Foobar's Avatar
OK yeah that's messed up then, assuming the car had plenty of time to sit in the sun so that all the liquid was dried. It should be a uniform break all the way around. If any part of it adhered at all, then they should've been able to make it adhere all the way around. Normally, it looks good upon application, but once the sun does its thing, you see the border.
Not acceptable. Air should not be between the glass and film.
The Following User Says Thank You to Foobar For This Useful Post:
Killerbee (12-28-2012)
Old 12-28-2012, 09:53 AM   #18
gily25
Drives: Silica BRZ 6MT
That's not what you paid for...I'd make them do it again.
We had a window start to peel at the edge a year after it was done in our Lancer...went in and the guy says, you have 45 minutes? I'll do it again right now...and that was a year later. Unfortauntely he's in the Dominican for 6 months so I have to wait on my tints
gily25 is offline   Reply With Quote
The Following User Says Thank You to gily25 For This Useful Post:
Old 12-28-2012, 10:48 AM   #19
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Anyone have issues with the driver/passenger window's tint since the windows go down/up when the door is opened? About to get my windows tinted and it seems that the main issue is the back window and the third brake light.
Eurasianman is offline   Reply With Quote
Old 12-28-2012, 11:13 AM   #20
Foobar
SLO NO MO
Foobar's Avatar
No issues - they'll hit it with a heat gun while it's still in the shop to make sure it has a good seal, then just don't roll down your window for 3-5 days after that and you're fine. The auto-down when door opens won't be a problem during that time.
Also, there's no need to remove the third brake light when tint is being applied. With the proper squeegee tool, your tint guy should be able to get it in there without removing anything.
Eurasianman (12-28-2012)
Subaru BRZ Clear bra Install (self healing), Window Tint & Wolf's Hard Body Sealant Rickrack Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 03-15-2015 02:54 PM
Hard to See at Night with Tinted Windows? GhostofAkina Cosmetic Modification (Interior/Exterior/Lighting) 26 01-05-2013 10:50 PM
Windows 8 Khalis Off-Topic Lounge [WARNING: NO POLITICS] 33 10-17-2012 10:20 PM
Ice + windows... brzninja BRZ First-Gen (2012+) — General Topics 23 10-09-2012 09:29 PM
Anyone else have problems with their windows after pushing the car too hard? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 9 06-21-2012 11:39 PM
