Old 12-26-2012, 03:25 PM   #29
Dezoris
Dezoris's Avatar
I just want to clarify the first two places I had my alignment done at, did not have their machines updated. So they substituted the specs for another car to get the alignment machine to start the process. Did they bother to look up the factory specs afterwords? I don't have any idea.
This is why I included the specs on the first page just in case they don't have their system updated, and you can be educated before you go in.
In the alignment I performed myself, the machine was properly updated with the proper specs before we started.
The Following User Says Thank You to Dezoris For This Useful Post:
Captain Insano (12-26-2012)
Old 12-26-2012, 03:34 PM   #30
ayau
Drives: Some rust bucket
@Dezoris, for educational purposes, can you list the possible aftermarket parts (eg., camber plates, camber bolts, bushings, etc) to induce negative camber, and possibly the pros and cons of each
Old 12-26-2012, 03:38 PM   #31
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
There are so many and more coming, one that caught my eye recently was these AST ones from TIC. I trust these guys along with RCE on suspension stuff, if you want camber plates anyways i don't personally.
http://turninconcepts.com/product_in...oducts_id=1258
There are also the Ground Control ones, Whiteline Com C, RCE is coming out with some, etc.
The Following User Says Thank You to JoeBoxer For This Useful Post:
ayau (12-26-2012)
Old 12-26-2012, 03:51 PM   #32
ayau
thanks.
it's confusing when there are so many options to get negative camber. it would be nice if there was some sort of FAQ that has a list of all the different options and their pros/cons.
Old 12-26-2012, 03:54 PM   #33
JoeBoxer
JoeBoxer's Avatar
I tried to make a list one night but i don't have the organizational skills like Darren has done in the wheel thread.
For the front your basic options are just the OEM camber bolts or Whiteline, then you can step up to camber plates.
For the rear you have the Whiteline upper a arm bushing which is cheapest but also most difficult to install. There are a number of rear lower control arms, only a few i like that are reasonably priced, SPC, Whiteline, GTSpec but there are more of these coming out too.
Not to say there are other quality options out there but some of them are over $500 so these are just the ones i like, i sell other ones i could make more money on but those are my favorites.
The Following 2 Users Say Thank You to JoeBoxer For This Useful Post:
ayau (12-26-2012), ericmpena (08-27-2013)
Old 12-26-2012, 04:01 PM   #34
ayau
it is my understanding that aftermarket coilovers don't provide negative camber adjustments, correct? the reason why you get negative camber from an aftermarket coilover is because of the shorter coilover length, but there are no adjustments unless you get some type of camber kit (mentioned in the above posts).
Old 12-26-2012, 04:02 PM   #35
Dezoris
Dezoris's Avatar
It's going to be even more confusing.
Ayau, I added what I used in my original post.
I hesitate to start recommending brands or products when it will be impossible to keep up with all of them. However I will add a breakdown of each type and why you would use them.
However, as Joe mentioned the Whiteline/SPC eccetric front bolts are tried and true for 90% of FR-S/BRZ owners. If you need more camber adjustment than those bolts provide, chances are you will will be spending a lot of time on the track.
Same with the rear bushings, they just work when you need camber "correction."
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
ayau (12-26-2012), JoeBoxer (12-26-2012)
Old 12-26-2012, 04:07 PM   #36
JoeBoxer
JoeBoxer's Avatar
Coilover kits that have upper camber mounts will give you adjustment in the front but not the rear, there aren't any on the market *right now* that offer camber adjustment on the rear.
Old 12-26-2012, 04:07 PM   #37
Dezoris
Dezoris's Avatar
100% correct, lowering the ride height generates more negative static camber. Most kits do not include camber correction.
Some coil overs offer camber/caster plates which are installed and adjusted at the shock tower.
Old 12-26-2012, 05:05 PM   #38
whataboutbob
AutoX-10/10ths every run
Absolutely, Turn in Concepts uses them on their track car also. There are some other LCA's coming to the market soon also. Whiteline and Esoteric should be out soon i've heard of others but haven't seen anything.
On the wait list for the Whitelines direct FTW!
Build thread:Here
Old 12-27-2012, 03:44 PM   #39
Dezoris
Dezoris's Avatar
I'd like to see the whiteline arms as well. Hopefully painted black
Old 12-31-2012, 11:28 AM   #40
ayau
do you think there will be other options in the future to add more camber?
Old 12-31-2012, 11:42 AM   #41
gmookher
between the kc416's and a nice set of camber plates, like vorschlags or GC's you should be able to get 2.5 to -3, isnt that enough?
Old 12-31-2012, 06:28 PM   #42
ayau
getting front camber doesn't seem to be an issue with the current options; it's the back that seems like it's going to be a hassle, especially if your rear camber is uneven from the factory. here are a couple options i can think of to remedy this issue.
1. aftermarket adjustable rear control arm.
2. whiteline rear bushings.
3. lowering the car with aftermarket coilovers (adds negative camber), and you can adjust the rear height to get your desired negative camber.
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-09-2012 11:36 PM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 11:41 AM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
