#71 |
Drives: 2012 Tacoma TRD Sport
TRS carries two different kits for the FRS - Mini H1 projectors or FXR projectors. The FXR is much better in terms of output in my opinion and price is not that much more.
As far as using a different bulb, the relay harness that comes with the retrofit will take care of that. You use one of your existing H11 plugs simply for signal (other not used). The power will be drawn directly from the battery and the harness has new plugs that go to the ballasts that then have wires to the bulb. Anyone in SoCal that needs help with these, hit me up. |
#72 |
Drives: 2013 Scion FR-S Raven
FXR projectors, really?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#73 |
Drives: 2018 Golf R
Yea, they mention it on the front page of their website but Im not seeing the listing itself.
Parting out HERE
#74 |
Terrific, they take a great kit and make it even better
#75 |
For make sure you get the FXR kit, I would call in to order.
#76 |
Drives: FRS :D
damn too late now
retrofitted and installed Thanks again for this DIY @civicdrivr The gap bugs me but its really isn't something you see unless you know about it
Out of the FRS game
| The Following User Says Thank You to Mr.Jay For This Useful Post: | civicdrivr (10-26-2012) |
#77 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
The back of my headlight looks nothing like the ones posted in pictures here... I'm stuck with high beams until I can figure out what's wrong. The headlights posted here seem to have some sort of a plastic dome behind the low-beam... mine doesn't have that and I think that's why I'm having trouble. The back of my headlight looks like this:
#78 |
Those look stock to me, you need to modify them to look like the ones in the thread
#79 |
Lap time enthusiast
Ok, but the TRS kit doesn't specify any modifications, nor does it come with parts that look remotely like that.
#80 | |
Drives: 2018 Golf R
To answer your other question, the high beam is the reflector based beam (the one on the right of your picture). Sent via telepathy
Parting out HERE
#81 |
Drives: '13 White FR-S, 09 Triumph St.3 R
#82 | |
Lap time enthusiast
http://www.theretrofitsource.com/pro...roducts_id=254 This kit says specifically that there's little to no cutting needed, and no modifications needed. The only problem is that the instructions supplied are for a Mazda 6. Last edited by raul; 12-25-2012 at 11:55 PM. |
#83 |
Everything is right
#84 | |
Drives: 2018 Golf R
The two rubber boots/caps should have been included with your kit.
Parting out HERE
| Morimoto Retro-Quik Xenon Retrofit System for FR-S | Xenocide117 | Cosmetic Modification (Interior/Exterior/Lighting) | 63 | 07-18-2014 08:37 PM |
| The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion | Andrew @ TRS | Exterior Parts - The Rest | 84 | 07-23-2012 10:43 PM |
| OEM Fog Light install! ON and working! | 86design | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 38 | 07-04-2012 08:11 PM |
| How to install Homelink mirror? | Grimlock | Electronics | Audio | NAV | Infotainment | 10 | 06-10-2012 07:07 PM |
| Five axis limited retro | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 05-18-2012 04:16 PM |
