Old 09-26-2011, 02:46 AM   #57
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Hey all, i found some more scraps at my cousins house that i thought was decent technology so i picked it up.
2x 1G Corsair PC3200 DDR400 Ram sticks
LGA775 Pentium 4 HT 670 3.8ghz
So a quick question, i noticed that some LGA775 motherboards use a higher FSB for dual core processors and DDR2 or DDR3 ram. With my Pentium 4 having only a 800mhz FSB, will it be compatible with the newer/recent LGA775 motherboards even with the higher rated FSB?
I mean id love to get like a $40-$50 LGA775 MOBO and a few RAM sticks and build a $100 PC that can run PS better than old rig that just blew up. If i can reuse this processor whats a good motherboard? what should i look for?
WingsofWar is offline   Reply With Quote
Old 09-26-2011, 10:17 AM   #58
n2oinferno
Praise Helix!
n2oinferno's Avatar
It should. When they say they support higher fsb, it means they can go that high. You can always downclock. Easier to be backwards compatible than forwards compatible, like in the case of my old LGA775 board that didn't support Yorkfield CPUs.
Buy the cheapest motherboard you can find if you want to go this way. Don't worry about good, just worry about getting by until you can get something better. No reason to spend more money than necessary on ancient hardware. Spending 100 dollars here is half the cost of an i5 2500k.
Old 09-26-2011, 12:59 PM   #59
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
What about the Intel P43 and P45 and some g41 chipsets? i was reading that the newer boards didnt have any compatibility with LGA775 Pentium CPUs? why is this?
Old 09-26-2011, 01:28 PM   #60
serialk11r
Drives: '06 AM V8V Coupe
Oh dear, a P4...last time I used one of those I wanted to tear my hair out. I have a G33 board, and I think it's backwards compatible with all LGA775. But for even 30 bucks I wouldn't get one to stick an old prescott into. I'm fairly sure G41 boards should work...I agree with n2oinferno, if you want to take this route, go as cheap as possible.
Old 09-26-2011, 02:25 PM   #61
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
yeah i definitely want to super cheap because its going to be replaced soon. But i need working PC now with the parts i have.
I mean, if i could make P3 700mhz 1.5G SDRAM and a 128mb AGP video card run windows XP Professional and Photoshop CS4..and still build those photochops iv posted on here..Im pretty sure a small bump in performance would mean a world to me.That is the PC im coming from.
So anyway..i was thinking of this MOBO for $30...any good? has a P35 northbridge and ICH9 south bridge..and i read its the one of very few "newer" boards that still accept P4.
http://www.ebay.com/itm/Biostar-P35D...a#ht_500wt_922
Old 09-26-2011, 04:00 PM   #62
n2oinferno
Praise Helix!
n2oinferno's Avatar
I've had no issue with refurbs, but I'd definitely want to know what kind of warranty it has before I spend the money.
edit: nevermind, the G41 doesn't work, only supports 800 minimum. damn, that's old technology lol
That P35 board will work though.
Old 09-26-2011, 10:22 PM   #63
82mm 4g63
4G63 & Rotary
82mm 4g63's Avatar
Drives: 92TalonAWD, 93RX7, 11F150EcoBoost
Send a message via AIM to 82mm 4g63
If you can make a working rig using the parts you just acquired with that $30 motherboard, I say do it. With hardware that old the only thing you should be concerned about is if it is compatible, and it is. So I say buy it and don't spend another penny on it. Any more money spent on this thing and you're eating into your new rig's budget.
HOWEVER, If you're holding off until Black Friday for deals to build the NEW rig, I would say buy it(new rig) now. In all honesty that $45(including shipping) you're spending on an ancient motherboard will negate most/all savings you'd get from the BF deals, so why bother waiting? I really don't see you saving over $50 in BF deals with the rig we talked about. From my experience the deals are usually focused towards the high end processors and peripherals.
82mm 4g63 is offline   Reply With Quote
Old 09-27-2011, 05:31 PM   #64
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
October heralds the AMD Bulldozer architecture. That's going to be a significant change to AMD's units. I've noticed nothing but Intel jibberjabber in the last couple pages so I thought I'd just chime in :P And IMO, it's worth waiting to see if Bulldozer is everything it's hyped up to be -- because chances are it'll be cheaper than any Intel cheap (even if only marginally) and according to numerous reports, much faster.
"Bulldozer will be the first major redesign of AMD’s processor architecture since 2003, when the firm launched its Athlon 64/Opteron (K8) processors, and will feature two 128-bit FMA-capable FPUs which can be combined into one 256-bit FPU. This design is accompanied by two integer cores each with 4 pipelines (the fetch/decode stage is shared). Bulldozer will also introduce shared L2 cache in the new architecture. AMD calls this design a "Bulldozer module". A 16-core processor design would feature eight of these modules,[8] but the operating system will recognize each module as two physical cores.
The module, described as two cores, can be contrasted with a single Intel core with HyperThreading. The difference between the two approaches is that Bulldozer provides dedicated schedulers and integer units for each thread, whereas in Intel's core all threads must compete for available execution resources"
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 09-28-2011, 04:18 AM   #65
Giccin
Giccin's Avatar
Gief Budget. And what you want to keep. Also a link of what your tower looks like. I'll build you a media building pc. :>
Sorry took so long to make a post. Lol But after seeing this thread go on for so long.. with more information than needed.. it was time to step in and just throw out sets. Lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 09-28-2011, 04:48 AM   #66
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
I guess you can say it looks kinda like this
http://www.tigerdirect.com/applicati...635&CatId=1509
but its not a cooler master.
iv been reading up on so much computer stuff my head is going to explode...
i was even looking at my credit card earlier and was very tempted to use it and buy this shit.
http://www.tigerdirect.com/applicati...0998&CatId=336
but iv kept my composure, and i want to keep to a <$800 budget, or at least pretend that i will...
Old 09-28-2011, 03:43 PM   #67
Giccin
Giccin's Avatar
Cool beans. Will give you a full list in a couple of days. :>
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 09-28-2011, 05:26 PM   #68
StealthESW
Drives: '09 Ducati Monster 696
Try looking up your parts on pricewatch.com. If you have not already. I have found many good deals there.
Engineering graphics cards are best for rendering. I'm sure you already knew that.
Projects:
'88 Fiero Formula
'88 Fiero Coupe
StealthESW is offline   Reply With Quote
Old 09-28-2011, 05:37 PM   #69
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
thanks for the suggestions! I actually haven't looked at any cards that were built for engineering and rendering. I saw the intel quad core work processors go all the way up to $3000 for those 30G/Ts Bus speed..yikes..
but ill look on pricewatch.com for some stuff too.
Thanks again!
Old 09-28-2011, 09:58 PM   #70
Giccin
Giccin's Avatar
What memory size and HD size?
Edit: Ok I got a friend to do it because.. he does art work and builds PCs often. Lol
So this is what he got with the info I gave him. No monitor. and New Case because it comes with PSU. $800 budget.
CPU
http://www.newegg.com/Product/Produc...82E16819115071
MOBO
http://www.newegg.com/Product/Produc...82E16813128512
MEMORY
http://www.newegg.com/Product/Produc...82E16820104173
CASE
http://www.newegg.com/Product/Produc...82E16811119207
VGA
http://www.newegg.com/Product/Produc...82E16814500197
HDD 2TB HD for storage and its pretty fast too.
http://www.newegg.com/Product/Produc...82E16822136792
He also mentions... if you're willing to spend a little more... get a faster HD just for running your editing programs and saving them to that 2TB HDD.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
SWP's 13' BRZ Build Thread SWP BRZ Member's Car Journals 2 01-16-2015 02:23 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
