Old 12-12-2012, 10:33 AM   #15
sure74
sure74's Avatar
Drives: 2016 Toyota 4Runner Trail Premium
As far as I know, the factory amp gets the signal from the same wires as the speakers in the dash.
I have not replaced my stereo but many have and I don't remember reading about any issues like this.
If you have a test light I'd say to test the power wire to the factory amp and make sure it is powered up.
sure74 is offline   Reply With Quote
Old 12-12-2012, 01:14 PM   #16
rbizzle004
Well Im an idiot. I figured out the reverse wire. I just tapped into the wrong wire. Still having issues with the door speakers. Getting no sound from them. I havent tested the factory amp to see if its powering up.
rbizzle004 is offline   Reply With Quote
Old 12-13-2012, 09:02 AM   #17
sparks
sparks's Avatar
The green wire IS the remote turn on for the amp
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
The Following 3 Users Say Thank You to sparks For This Useful Post:
rixter145 (01-08-2018), SkAsphalt (09-12-2013), SVXdc (12-15-2012)
Old 12-14-2012, 06:28 PM   #18
rbizzle004
Update: I have been waiting form my Antenna adapter and received it today. After I installed it, the factory subs (door speakers) work. But only on FM radio (HD and analog stations). But they do not work with XM, iPod, Bluetooth or anything else. I am confused and dont understand why this is happening.
Old 12-15-2012, 02:33 PM   #19
rbizzle004
Alright everything is up and running perfect. The factory amp problem was because I had the power antenna wire from radio hooked up to the power antenna wire from toyota metra harness. That wire is actually the remote turn on for the factory amp. So once I connected that and the remote wire from the HU everything worked out. The BRZ does not need a power antenna hook up.
Old 12-15-2012, 07:16 PM   #20
SVXdc
Radio wiring harness guru
SVXdc's Avatar
Drives: 1996 SVX L AWD
Not quite correct...
The BRZ and FR-S (and recent Toyotas and Scions) have a pair of factory harnesses used for power and speakers -- one with 10 pins and one with 6 pins.
On the 10-pin harness:
  • Pin #8 sends +12V power to the car's antenna booster amplifier (Subarus only).
  • Pin #9 sends the +12V remote control turn-on for a speaker amplifier.
Viewing rear (wires side) of the car's factory 10-pin harness (or socket on rear of HU), the pin numbers run:
Code:
 4 3     2 1
10 9 8 7 6 5
On the BRZ:
  • Pin 8 is PINK.
  • Pin 9 is BROWN at HU's harness, and changes to GREEN at the amp's harness (transition happens at intermediate connector "HD2" behind the driver's kickpanel).
Subarus require that the pin 8 power antenna wire be connected. Without it, you'll have poor radio reception. This applies to the BRZ, as well as other recent Subaru models which have the Fujitsu Ten nav HU (Impreza, Forester, and Crosstrek). The factory HU provides +12V on that pin only while you're in AM/FM mode (both analog and HD radio). On Subarus, the power antenna wire is never on the antenna harness (that pin/wire is vacant on the factory antenna connector).
Since the BRZ and FR-S also have a subwoofer amplifier (for the door speakers), they also require that pin 9 have +12V whenever your HU is on.
The other Subaru models (Impreza, Forester, Crosstrek -- which don't have an integrated factory amp) do not have a factory wire at pin 9. The various OEM accessory subwoofers in those models do not use this pin.
Toyotas have the power antenna lead on their antenna harness and not on the 10-pin harness.
Bottom line: When installing an aftermarket HU, you'll need to make these connections:
BRZ:
  • Do not use BLUE wire on antenna adapter (you can remove wire).
  • HU's Power Antenna remote turn-on to car's pin 8.
  • HU's Speaker Amplifier remote turn-on to car's pin 9.
FR-S:
  • HU's Power Antenna remote turn-on to BLUE wire on antenna adapter.
  • Nothing to car's pin 8.
Aftermarket wiring harnesses (Metra, Scosche, etc.) all seem to have one BLUE wire on pin 8, with a short loop tying that to pin 9 also. You can either:
  1. Connect the long BLUE wire to your new HU's amp remote turn-on lead. This will power both the BRZ's antenna booster and sub amp whenever your HU is on.
    On the FR-S, the unneeded connection to pin 8 won't hurt anything. But if it makes you feel better, you can cut off and discard the short loop wire and its pin, and move the longer pin 8 wire to pin 9.
  2. Cut the loop wire off of pin 8, so you have separate wires on pins 8 and 9. Then connect to the respective leads on the HU's harness.
SVXdc is offline   Reply With Quote
The Following 9 Users Say Thank You to SVXdc For This Useful Post:
Deathalo (05-05-2014), Pointmutation (04-09-2016), Prog (12-07-2013), rbizzle004 (12-18-2012), rixter145 (01-08-2018), SilverlightPony (06-17-2014), SkAsphalt (09-12-2013), weepel (12-01-2021), Williampreza (01-11-2019)
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 02:43 PM
Scion Factory Remote Start? mikeg7827 Electronics | Audio | NAV | Infotainment 16 12-24-2013 01:00 AM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
