Old 12-06-2012, 02:01 PM   #15
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
Congrats and welcome to the community!
Luke.Cariveau is offline   Reply With Quote
The Following User Says Thank You to Luke.Cariveau For This Useful Post:
swift996 (12-10-2012)
Old 12-10-2012, 09:43 AM   #16
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by swift996 View Post
Ordered JDM OEM Clear Side Markers (should be in tomorrow or Friday)
Where did you order them from? I want a set but I don't want to pay $100+ to import them. I figured some would eventually make their way to a stateside store for a lower price.
Next Up:
Armrest
CS Style Front Lip and Side Skirts
Eibach Multi Pro R2 Coilovers (or KW V3s)
Injen Intake (need to wait until I get some more mileage on the car)
May I recommend against the Injen intake. Lots of problems reported here on the forums related to CEL's and stalling, possibly due to running a bit too lean on the stock tune. The Injen reportedly makes good noise, but the open faced design takes in heat from the header/radiator at idle. I have an Airaid, and the filter is fully shielded, which I think is a good design, but not ideal. The Airaid was a good price, makes a bit of power and good noise, but I'd still go with either
FA20club:
or Perrin's:
to be released very soon. They both feature a filter outside the engine bay, under the bumper cover. I'll bet they will make more power on a dyno without a tune (with the hood closed) than the others that are out so far. They will both also offer a tune for their intakes that should make the most of them.
Old 12-10-2012, 09:54 AM   #17
swift996
swift996's Avatar
I'm going to install them today. I got them from a vendor member on here (Carson Toyota - Luis). I think they were $100 +$6 shipping. Probably the best price you will get on some OEM ones. I'm sure DEPO will make them for $30 a pair here pretty soon, but I hate the orange look, so whats $100.
Thanks, I'll look into those intakes, I want something black (matte) and sort of OEM looking. I'm only at around 600 miles so I'll wait until I get around 2K or so.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 12-10-2012, 10:06 AM   #18
ATL BRZ
ATL BRZ's Avatar
I hear you about the matte black intake. Thankfully I'm pretty sure Perrin and FA20Club will offer them in black or matte black. I forgot one other intake with a similar design from Vigilant Motorsports, also matte black: http://www.ft86club.com/forums/showthread.php?t=22625 looks pretty nice!
The Following User Says Thank You to ATL BRZ For This Useful Post:
Old 12-10-2012, 12:06 PM   #19
swift996
swift996's Avatar
I ran out for a lunch break today and decided to install the OEM JDM Clear Side Markers (in the post office parking lot).
Comparison vs Stock (Same size, just an odd angle. The clear version has an area that protrudes out, makes it look a little more aggressive I suppose)
On the car:
I'm waiting to receive some LEDs that light up amber. With the stock bulbs it looks similar to how a Christmas light would look. If the surface was more translucent, I'd keep it but it has some transparent aspects so it looks a little like a Christmas light.
Next Up:
Armrest
CS Style Front Lip and Side Skirts (Still on back-order/pre-order)
Intake
Red Overlays or Black the Housing in the tail lights
Phase 2:
Sway Bars
Strut Towers
18" Emotion CR Kai or BBS LMs
Upgrade the brake package
Phase 3:
Innovative Motorsports Supercharger
or
AVO Turbo Kit
The Following User Says Thank You to swift996 For This Useful Post:
chanomatik (02-15-2013)
Old 12-10-2012, 12:37 PM   #20
ATL BRZ
ATL BRZ's Avatar
the clear markers look great! I'm tempted to get a pair!
Next Up:
Armrest
Intake
Phase 2:
Sway Bars
Strut Towers
Phase 3:
or
AVO Turbo Kit
I like where this is going!!!
For the tails, I'd recommend using BOTH a soldering iron with a bent knife edge tip and a dremel with a small cutting wheel to separate the chrome bezels from the housings. The only location I'd use the soldering iron is under the "beauty cover" plastic shield, which is a tight spot that you may not be able to fit a dremel in. The rest if the way around I'd use a dremel simply because the iron is messy, slow and dangerous because you can easily slip and melt unwanted areas inside the housing. Ask me how I know. Make sure you cut carefully and at good angles and consistent line as you go around the outside of the housing, keeping constant reference of where the bezel is inside because you need to allow enough clearance for it to slide out after you separate the lens from the housing. It's difficult because of the odd shape and angles of attack you have to patiently double check while you cut. Also sealing them back up well is critical. Use permatex black adhesive silicone sealant in a caulk gun liberally.
Old 12-13-2012, 01:10 PM   #21
swift996
swift996's Avatar
Visiting our sister company's office yesterday and had to park next to this guy:
I ordered the CS Urethane Front Lip and Side Skirts.
Old 12-13-2012, 09:14 PM   #22
DGMBRZ
DGMBRZ's Avatar
Drives: 2013 Subaru BRZ in DGM
Very nice! Just subscribed. Interested in seeing the skirt on a fellow dark BRZ!
DGMBRZ is offline   Reply With Quote
Old 12-13-2012, 11:22 PM   #23
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Subbed, I can't wait to see what you decide to do next
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 12-15-2012, 01:29 PM   #24
swift996
swift996's Avatar
I got this from (Dadhawk) on the forum.
Installed some new black/stealth exhaust tips.
DC Sports Stealth Series EX-1017B. $30 each from Pep Boys (I ordered online)
I figured for $60 what the heck, might as well try it out since I won't be buying an exhaust (maybe one day down the road).
Comparison vs Stock:
One side done:
Finished product (took about 10mins) sorry the angle of the sun might make it look a little funny:
Ordered::
Super Mini ELM327 Bluetooth OBD2 OBD-II CAN-BUS Diagnostic Scanner Tool
from [ame="http://www.amazon.com/gp/product/B0090ZJPMK/ref=oh_details_o01_s00_i00"]Amazon[/ame]
CS Style Urethane Front Lip and Side Skirts
I also got 5 copies of Clayton Christensen's "[ame="http://www.amazon.com/gp/product/0062060244/ref=oh_details_o00_s00_i01"]The Innovators Dilemma[/ame]" coming in. I plan to pass some out at work for Christmas. A great read for those in the business field.
The Following 2 Users Say Thank You to swift996 For This Useful Post:
racecaresuaceb (01-31-2013), Scooby South (03-24-2013)
Old 12-15-2012, 02:57 PM   #25
swift996
swift996's Avatar
Snapped a few more pics:
ATL BRZ (12-15-2012)
Old 12-15-2012, 03:17 PM   #26
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Nice tips. I'm going with the Borla Exhaust myself.
L3P47 is offline   Reply With Quote
Old 12-15-2012, 03:21 PM   #27
ATL BRZ
ATL BRZ's Avatar
I really like that front lip. I haven't seen them for sale that cheap yet. Looking forward to seeing it on your car. You'll probably convince me to get one, though I'll probably end up destroying it on some curb...
Old 12-15-2012, 04:20 PM   #28
swift996
swift996's Avatar
I like the sound of the Borla. If I go with an exhaust, I'll probably go that route. I'm a little too old to be driving around with an exhaust daily. I have a corporate job, so people would judge.
I've seen it on quite a few world rally blue BRZs and it looks great. I think it should look nice and flush with black. $170 shipped isn't bad. I was hoping to install it right before I get some coil-overs but I'm still waiting on the Eibach Multi-Pro R2s. I just hope it doesn't look funny with all that wheel gap and swallowing the tiny stock wheels. I like an aggressive OEM look, so once I lower the car, it's going to look mean.
2013 BRZ Limited (black) Epictetus Cars for Sale/Trade 2 11-14-2012 11:38 AM
My crystal black brz limited chadz Member's Car Journals 37 09-12-2012 06:26 PM
BRZ, Black, 6MT, Limited...DELIVERED! boarder1995 BRZ First-Gen (2012+) — General Topics 3 06-14-2012 04:03 PM
Need a black AT Limited trim BRZ! jaytaurus Northwest 4 05-18-2012 05:29 PM
