Old 12-03-2012, 02:46 PM   #757
wictech
wictech's Avatar
Drives: Scion FR-S 2013 (alphalt)
Fenrir,
AC? I live in Richmond, VA. It was like 60F when I took that video last night. No point to have AC on.
wictech is offline   Reply With Quote
Old 12-03-2012, 02:50 PM   #758
Fenrir
Drives: Mazdaspeed 3
Originally Posted by wictech View Post
Fenrir,
If you have the heat on, the car will run the AC. AC doesn't necessarily mean cold air. That's the AC compressor kicking on there, so not sure what else to tell you.
Fenrir is offline   Reply With Quote
Old 12-03-2012, 03:59 PM   #759
RoryTate
Drives: 2013 Subaru BRZ
Blatantly stolen from an Outback forum:
RoryTate is offline   Reply With Quote
The Following User Says Thank You to RoryTate For This Useful Post:
FRSFirestorm (01-05-2013)
Old 12-04-2012, 04:32 AM   #760
fistpoint
Drives: Supercharged Golf Cart
And in many vehicles you can disable this from happening using programming codes entered by the radio and/or A/C buttons.
Disabling allows it to still work as intended, only now you have the option of turning off the compressor by pressing the button...how it should have been from the start.
fistpoint is offline   Reply With Quote
Old 12-04-2012, 11:34 AM   #761
whtchocla7e
Drives: 2013 FR-S Hot Lava
Ok wait, so everytime I use the "Windshield" knob option to keep my windows clear, the the ac compressor is running...? Now I know where the poor mpg comes from.. and why I hear something kick in every few mintues.. I don't like this silly design.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 12-04-2012, 01:37 PM   #762
RoryTate
Yes, quite true. Now has anyone figured it out how to do it for these cars yet?
Yep. A majority of manufacturers are doing it this way these days. If you know how to disable this 'feature' (as referenced above), it isn't so bad.
Old 12-04-2012, 03:01 PM   #763
...Now I know where the poor mpg comes from.. and why I hear something kick in every few mintues.. I don't like this silly design.
Not sure I'd attribute poor MPG to this. Even during the hottest part of the Atlanta summer I was getting over 30MPG in mine. It did go up slightly (maybe 1 or 2 MPG) once I was running without A/C, but that could also be attributable to switching to winter blend fuel.
Old 12-07-2012, 09:12 AM   #764
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
Beginning to notice my drls going out when I rough idle.
May have been doing it all along, but having cars I can see my reflection in is making it more apparent.
Spd229 is offline   Reply With Quote
Old 12-07-2012, 09:45 PM   #765
fistpoint
All cars lights dim when the idle dips below a certain point(close to stall). A weak battery can also cause this. That's not an issue more so than a symptom of another problem, in this case the idle dip.
When my compressor cycles on my car I notice the lights dim for a split second. My battery was recently determined to be on the weak side according to the guys who changed my oil. So, normal and expected.
Old 12-08-2012, 03:08 AM   #766
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
Yeah the added resistance or idle drop results in a slower rotating alternator which in turn lowers the voltage briefly.
driftartist is offline   Reply With Quote
Old 12-17-2012, 08:36 PM   #767
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I just read the whole 35 pages of posts. I'm posting here to keep a log for myself and also for everyone's info.
I picked up FR-S in the beginning of June. Idling has been perfectly stable. Even at the moment when the A/C compressor turns on, it would drop from 650 to 630 or so, where the needle hardly moves.
In early October when I just passed 4k miles, idle dip happened for the first time. A/C was on. About 2 seconds after the A/C compressor turns on, it would drop to 500 and then jump up to 800. It kept doing this every time the AC compressor turned on, which is about every 15 seconds.
No idle dip since then for about a month. Then it did it again.
No idle dip for about 2 weeks. Then it did it again...
No idle dip for about a week. Then multiple times a week...
I currently have about 6k miles. It has MT and VIN ends with 3xxx. By reading people's experiences, I'm guessing the dealer won't do anything for mine since there is no CEL. But if it keeps doing this, I'm going to mention this when I get my first service done next month.
Originally Posted by Asphaltfrs1 View Post
Originally Posted by Lytheum View Post
confirmed the idle drop today in my brz for the first time. i was at a taco bell drive thru
and noticed the rpms drop to about 400 then bounce up to 900...it then did it again but dropped to about 500 and jumped up a few then leveled
out. the a/c was running with the fan on the lowest setting.
ill mention it at my first oil change or take it in if it keeps happening
That's the setting I have on the A/C when it occurs, I turn the A/C off and it idles normal again.
My experience is similar to Lytheum's and Asphaltfrs1's.
Originally Posted by enigmaaron View Post
Only 225 miles on mine so far but I thought I would point out that my idle is consistent at 650rpm. Seems like
everyone reporting this issue is idling at 800 then drops to 400, correct me if I'm wrong? Maybe a clue as to what's going on?
If I turn the AC on it will dip to 500 for a moment, bounce up to 750-800, then come right back down to 650 all in a matter of 1-2 seconds.
Also, no crickets here yet (fingers crossed) in case anyone is tracking a correlation.
enigmaaron's one seems similar to mine as well.
Originally Posted by civicdrivr View Post
I've been keeping an eye on my car, and now it only does it with the a/c on or when the rad fans kick on. If
everything is off the idle is rock steady. Im just shy of 5k miles.
Mine stops happening when I turn off the A/C just like civicdrivr's.
Originally Posted by Rob_g View Post
I was parked on the side of the road yesterday with my FR-S (AT) running and the A/C was on (too hot to have it off). I
was eating some popcorn and just relaxing for the moment. I must have been parked about 5 minutes and then all of a sudden the engine
sputtered, idle dipped to about 350, the car shook and it felt like it almost stalled. The engine did recover right away, but after that the
idling started going up to about 800-900rpm.
Rob
Mine is a little bit different from Rob's since mine would be doing it every 15 seconds. It's not something like it does it once and not for a while. When it does it, it does it every 15 seconds until I turn the engine off and turn it back on.
Originally Posted by bneale View Post
I'm sitting in my car right now. I was able to get my RPM's to drop by turning the AC on while the fan was already
running. It dropped from about 800 down to 400 and back up again after a small shudder. I was able to get the car to do this 3 times in a row
just by pressing the button.
I have no cel yet and no whine. Car was warm because I was just driving it.
Bneale
When my car has idle dip, I can do what bneale describes too. But "when" it happens seems to be random and I don't see any pattern. Once it happens, it keeps doing it until I turn off the engine.
Updates for the record:
1/4/13 - idle dip after 3 weeks. Gone after restarting the engine.
The Following User Says Thank You to Sigh-on-Rice For This Useful Post:
Marrk (12-18-2012)
Old 12-18-2012, 02:35 AM   #768
Marrk
Drives: Honda Fit
Would someone mind (re)stating why, to the best of our collective knowledge, this idle dip issue happens only after the car has logged 1000s of miles? If the software and/or hardware is bad, why doesn't it happen at 1.0 miles?
Thanks.
Marrk is offline   Reply With Quote
Old 12-24-2012, 10:57 PM   #769
dano
Just an update: I just received a recall letter from Toy/Scion about an ECM re-flash. According to the letter, the re-flash is to resolve issues with compliance for California smog check laws. Doesn't say anything about the idle issue. When I bring my FR-S in, I'll ask about idle issue updates.
-dan
dano is offline   Reply With Quote
Old 01-04-2013, 09:49 PM   #770
driftartist
Kurenai Samurai
Mine has a weird rattle when i crak the throttle now after i picked mine up after the flash...
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-29-2012 12:38 AM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 02:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 01:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 01:58 AM
