Old 11-19-2012, 08:40 PM   #57
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I met with the district rep. again today after a long hiatus. Supposedly the delay was due to not having a BRZ available for a direct comparison. In any case, the noise has gotten somewhat quieter with time and thus I had a difficult time pointing it out to the rep., even though I was able to hear it with my ears being attuned to it. To try to isolate the noise from road noise and other distractions on the road test, they put the car on a lift to see if they could hear the noise that way. The preliminary word is that the rep. heard a noise from the differential and will be putting another BRZ in the air tomorrow to try to do a comparison with my mine. Hopefully the other BRZ will either not make the same noise or the rep. will consider the noise abnormal due to its annoying nature, and replace the differential. I'll keep you posted as I find out more.
Subie is offline   Reply With Quote
Old 11-19-2012, 10:05 PM   #58
ducks
Drives: car
my car is noticably quieter on the highway after switching the diff fluid to motul gear 300
ducks is offline   Reply With Quote
Old 11-19-2012, 10:13 PM   #59
Subie
Señor Member
Subie's Avatar
...which is precisely why I didn't change my differential fluid. I'd rather not mask the problem with gear lube.
Old 11-20-2012, 09:55 PM   #60
Subie
Señor Member
Subie's Avatar
Good news! The dealer called and told me that the district rep. did not hear the same noise on the BRZ he was using for comparison, and they therefore ordered a new differential for me. I'll be getting it installed sometime after the Thanksgiving holiday, either next week or the week thereafter.
Old 11-20-2012, 10:52 PM   #61
White64Goat
Has anyone tried a different set of wheels & tires (different brand tire) to see if the noise goes away? Tire tread can cause this type of noise as well.
Old 11-20-2012, 11:16 PM   #62
Subie
Señor Member
Subie's Avatar
If the district rep. heard the noise with the car in the air, it's not the tires.
Old 11-20-2012, 11:25 PM   #63
FirestormFRS
Thanks for the update! Mine has reduced to the point of not being a bother but if it comes back ill for sure take it in.
FirestormFRS is offline   Reply With Quote
Old 12-03-2012, 07:38 AM   #64
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Originally Posted by clayrush View Post
When I am 70-80 I can hear a sort of high pitch wine. I had the same thing in my celica.
I have that same high pitched whining sound around same speed ever figure out what it was?
DanoFA20 is offline   Reply With Quote
Old 12-03-2012, 04:18 PM   #65
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
na cant here it over the exhaust we have on the car now.
clayrush is offline   Reply With Quote
Old 12-22-2012, 11:16 PM   #66
Subie
Señor Member
Subie's Avatar
Edit: The new differential makes the same noise.
Old 12-23-2012, 09:33 AM   #67
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I had the same high pitched "tuning fork" noise at 70 mph as everybody seems to be describing. Recently did the noise generator delete and noticed that the noise is gone. Not sure if this is what everybody else is hearing, but it would be worth a try just plugging the noise generator hole in your passenger side to see if it fixes the problem (easier than having to take it to the dealer )
Old 01-06-2013, 01:32 PM   #68
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
Originally Posted by Subie View Post
Anyone with this problem: the noise is coming from the rear differential. After having the differential replaced, the noise at 70 MPH is gone. It's so much more pleasant road-tripping in this car now.
So did the Subaru rep say anything about a TSB or any other fix coming out soon? I hear the resonance once in a while since I don't really do highway driving too much...
ap5512 is offline   Reply With Quote
Old 01-06-2013, 02:30 PM   #69
Subie
Señor Member
Subie's Avatar
He did not. Truth be told, there is still a little additional noise/resonance at that speed that the differential replacement did not cure. I'm thinking that it may be something that is common to all 86s, but that mine was making additional noise that, coupled with the noise that was already there, made that tuning fork-like noise. I also still hear the noise at 35 MPH that I did before -- does your car make a cyclical noise at that speed?
Old 05-29-2013, 10:23 PM   #70
Subie
Señor Member
Subie's Avatar
I'm bumping this thread to see if there's any new information from anyone with this issue or if anyone else has this issue that has not spoken up.
Intake resonance pipe? tranzformer Engine, Exhaust, Transmission 20 12-05-2011 05:09 AM
