Old 12-02-2012, 03:18 AM   #57
RaceR
Drives: 2010 Cooper S, 74 Beetle
Originally Posted by LSxJunkie View Post
BMW peaked with this.
They should have just packed it in and gone to lunch for a few years.
Love E39 M5.. Its probably the most desirable M5 for me.. But this one is also great!
[ame="http://www.youtube.com/watch?v=FzOPR7STqrQ"]1986 BMW M5 E28: The original super 4-door - CHRIS HARRIS ON CARS - YouTube[/ame]
RaceR is offline   Reply With Quote
Old 12-02-2012, 04:01 AM   #58
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by RaceR View Post
My MR2 needed a new engine block, catalytic converters (all2/3 of them!), several O2 sensors, some fuel injectors, some bearing inside the gearbox..two calipers...A lot of problems beying normal maintenance. Luckily I managed to sell it for more than I bought it for, and also got some money back from the person who sold it to me.. But still it became an expensive car.
Generally BMW parts cost more than Toyota parts. But I had a ton of really expensive issues with the MR2. And I know a place that sells a lot of dirt cheap none OEM BMW parts (Mostly for a bit "older" BMWs. Probably not that cheap for you US people, but extremely cheap compared to OEM Toyota parts from a Toyota dealer here).
Yikes, that sounds bad. I haven't had problems yet, but the previous owner used Toyota dealer service for 139000 miles so I am watching the oil levels very carefully. I got it with the sump 1/4 full! I changed the oil and it's not burning any, so far so good. There is a ton of sludge in the engine though, I see a big chunk sitting there just pulling the oil cap off. Postcat O2 sensor also happened to just die completely last month, and the other 2 are probably out of calibration since the exhaust smells horrid. Scumbag dealerships.
The GT86 certification fuel efficiency is I think a regulatory failure, they don't test manual transmission cars fairly most of the time. But you are absolutely right, in America we think 30mpg is completely amazing fuel economy because we all drive tanks, whereas in Europe you can buy cars that return 40-50mpg without even trying, and most people do. Doesn't help that we get crappier gearboxes and engines over here. With the Spyder I'm sure you know the 5 speed sucks balls and revs the engine to the moon on the highway, it's hard to get much more than 30 mpg cruising at the speed of traffic, yet in America we think that is amazing fuel economy.
Old 12-02-2012, 04:27 AM   #59
RaceR
Yeah.. I was not that impressed with the fuel efficiency.. It was OK for a car of that age, weight and size.
Highways in my area are 50mpg. Most normal roads are 30-38mpg.. So not an issue with the gearing.
I would preferred to have some of the gears tighter. Especially 2nd and 3rd gear. The high poweband was quite narrow. Sometimes 1. gear would not go far enough, and 2nd gear would lack some juice because I was down at 3500-4000rpm at times.
BMWs fuel efficiency vs power makes them quite attractive. Not that BMW are better than their other german rivals on the typical engines here. But BMW sure knows how to make good engines. Its not just about looking at HP vs milage..
Here is a great chart to study which engines have recieved the "engine of the year awards". BMW have won a lot of titles!
http://en.wikipedia.org/wiki/Interna...ne_of_the_Year
Old 12-02-2012, 04:56 AM   #60
serialk11r
50mpg? :O Are you still talking about the Spyder? I can get 55mpg if I'm driving 25mph lol, but at 50mph that goes down to 40.
Yea I think the 5 speed gearbox is the car's biggest fault. The gears are not tight enough, 2nd feels really weak because you have a ~3.2 => ~1.9 = 40% rpm drop, 2nd to third is a 30% drop. The 6 speed is much better even with the 4.5 final drive, closer ratios and 9% lower rpm in 6th gear. 3000rpm vs. 3300 is a big deal in a noisy car like this.
BMW definitely makes great engines, but they come at BMW prices :/
Old 12-02-2012, 05:12 AM   #61
RaceR
WHOOPS... A little mix up there.. :p
I meant to say MPH.
Due to tax regulations here the price difference is not as high as in the US.
Old 12-02-2012, 05:15 AM   #62
serialk11r
I meant to say MPH.
Ah I see. With a convertible I wish the speed limits are lower because the wind noise is just so bad above 50mph. But yea with 50-80kph limits the stock gearing is good.
Old 12-02-2012, 06:16 AM   #63
RaceR
I know it does not have a BMW badge, but Ill post it here anyway!
Greetings from Norway!
First proper snowfall in my area... Picture taken early today before it got bright... I miss RWD :p
The Following User Says Thank You to RaceR For This Useful Post:
einzlr (12-03-2012)
Old 12-03-2012, 01:03 AM   #64
streetwaves
streetwaves's Avatar
Drives: e30
Ah, now that's the most desirable M5 for me.
streetwaves is offline   Reply With Quote
Old 12-03-2012, 02:59 AM   #65
einzlr
Drives: several
Gorgeous photo!
The Mini is close enough and IMHO is a great car for the winter - takes the cold/snow/ice without flinching and is plenty safe but also fun to slip-and-slide around when you want to. Or do you have a different opinion?
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
The Following User Says Thank You to einzlr For This Useful Post:
RaceR (12-03-2012)
Old 12-03-2012, 03:50 AM   #66
RaceR
Originally Posted by einzlr View Post
Gorgeous photo!
Well Minis are allowed on track-days with BMWs and everything here so should not be that much "off-topic" in i BMW thread. :p
They are becoming more and more similar to BMWs in the future. Same platform, same engines so they will probably be considered even more of a BMW then.
Some people does not like BMWs that well, but everybody seem to like the Mini. It does not have any upper-clas thing or anything negative towards it as far as I have experienced. Its just a cool/goofy looking car, so non car-people seem to like it. And car people know it handles good for a FWD so they seem to accept/like it as well.
There was actually a guy I talked with yesterday who though it was British. I think several people does.. :p
Winter experience. I have to pull the door a little harder for it to close properly, otherwise fine.
The only thing I don't like is that the car is imported from Germany so it was not fitted with typical Nordic winter tires, and they also managed to put on winter tires that is almost 4,8% smaller than they should have been. So they do look a little small. And make the car lower, which is not the best thing on a car with a front end that is already low. But snow plows are usually active during snowfalls, so should not be a concern. Winters are mostly wet on the lower west coast anyway.. I wont bother buying new tires since the tires on the car are band new.
The car is good for a FWD, but its still, FWD..
Im trying to learn how to left foot brake to make it loose the back end, but so far im not able to that well on snow. Gonna practice more, have never experimented with it before since ive mostly driven RWD cars. Tried it on a new VW Golf two winters ago but electronics would always interfer. Would be nice to be able to balance the car without lifting completely off the accelerator.
Car still feels quite nimble and light. Handbrake works well. :p lol
einzlr (12-04-2012)
Old 12-04-2012, 01:30 AM   #67
einzlr
Drives: several
Haha I suppose the reason some people think they're British is that they remember the original and haven't paid attention to who does the "remake". I see the occasional original mini on the roads around here. That was one tiny car!
Old 12-04-2012, 01:44 AM   #68
bestwheelbase
Drives: 1985 P-Type
Some guys put Honda VTEC engines in them, to great success.
Old 12-04-2012, 01:55 AM   #69
einzlr
Drives: several
haha wow
Old 12-04-2012, 07:27 PM   #70
Turbowned
Turbowned's Avatar
Is it a bit common in the US that BMW and Audi drivers are considered to be the least considerate drivers and generally drive faster than others?
Well, they're both built to travel at sustained triple-digit speeds on the Autobahn. Then you bring them to the United States where our highway system is garbage, it's infrastructure is in serious disrepair, there's too much traffic, and speed limits are painfully low because no one knows how to drive, and it's easy to see why Audi/BMW drivers get frustrated, trundling along at 55mph. As much as I loved driving my S4, at the same time it felt like a complete waste of a car on U.S. roadways.
I hold a deep appreciation for older BMW's, as I just bought my second E30 3 series, a 1991 318is. I looked at a couple E28 535is's as well, but their complete lack of fuel efficiency turned me away. Now I'm looking at maybe getting an E24 635csi, maybe. I like the late 80's Bimmers because like many cars of their era, they were just far enough out of the dark ages of carburetors and solid rear axles, but not too far into the age of overweight, electronics-laden cars from the 90's. Bulletproof, solid cars that are easy to work on and rewarding to drive.
I like the E36, E39, E90/92 and E60 M cars, but not much else since then. The new 3 series with the N20 is pretty exciting, I'll admit. However after working in sales for Audi and driving most of both carmakers' cars, I can say that I'd take an Audi over a BMW in most cases if I were looking at a brand new model. *flame suit on* I wouldn't really complain to own any model from either, however. To quote my "Truth in Audi" instructor, "anything from Bavaria, Ingolstadt, or Stuttgart is welcome in my driveway".
Nashville talk... bestwheelbase Southeast 718 05-12-2022 02:11 PM
Soo yeaaa... (Baseball Talk) JDMenrique Off-Topic Lounge [WARNING: NO POLITICS] 0 10-20-2012 09:18 AM
Talk to me about sumps ICantAffordAnLFA Engine, Exhaust, Transmission 8 09-28-2012 05:15 PM
Dealer talk Zoomie BRZ First-Gen (2012+) — General Topics 6 05-23-2012 01:38 AM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 01:51 AM
