Drives: DGMBRZ
So, I am not a fan of the Limited's spoiler, to put it lightly, and I really want to replace it with a lip spoiler. As far as I can figure it, my options are:
1. Find someone to trade trunks with. 2. Use a spoiler that covers the holes. CARSMO & TRD so far... 3. Buy a new trunk. I've seen CF options @ $560 & $740 (Seibon's). Dealership quoted me $469.95 for OEM Trunk, Unpainted, Not Including Installation. Also, there's the Seibon trunk with a lip spoiler built in, @$800. 4. Have the holes filled and painted... has anyone done this? I've seen it mentioned a couple of times as an option, but I'm not sure if peeps are speaking theoretically, or is someone has actually done this. If so, what did it cost/how did it turn out? 5. Have I missed any other options? I'd like to hear what choices you all made and how it worked out. Thks. Last edited by Flow; 12-01-2012 at 07:39 PM. Reason: Update w/ OEM Trunk Cost. I'm going to use this thread to document my progress. |
#2 |
Drives: 2005 Subaru STI
Get the trd lip wing, its a direct fit using factory holes. U just have to debadge the subaru and brz
#3 |
Drives: 2013 BRZ Limited
Can anyone confirm the above statement?
#4 |
Drives: 86 ZN6
#5 |
yeah it covers the brz and subaru badge about half way.
and trd comes factory matching paint either white or black or not painted http://www.ft86club.com/forums/showt...t=19008&page=2 scroll down
#6 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
TRD wing requires removing the Subaru and BRZ badges, the CARSMO does not. Also the TRD wing will require drilling two more holes, the CARSMO does not.
#7 |
Drives: 2013 FRS/01 Tacoma
CARSMO will fit
#8 |
It doesnt require you to drill holes, you could but you dont need to. The holes that came on the limit wing is enough to hold the wing. Most frs guys are using it without any holes drilled, only with double sided tape
#9 |
Drives: DGMBRZ
So, I updated the original post w/ CARSMO & TRD.
Are these the only spoilers that anyone is using to cover the holes? |
#10 |
Drives: GBS BRZ Limited
#11 |
Drives: Subaru BRZ Limited
Sorry to bring this back to life but I want to be certain that the TRD lip spoiler actually uses the holes drilled from the stock BRZ Limited spoiler.
A few of you have said that it covers the holes, and that drilling is not needed. However, I do want to bolt it down, but I really don't want to drill MORE holes on top of the 2 on each side that are already there.
#12 |
Drives: 2013 BRZ Limited 6MT GBS
^+1 do we need to drill more holes?
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
![]() SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist |
#13 |
Wise old man
Drives: 86 GTS
+4 i want to know too.. so i can order the trd spoiler and then go to the BRZ limited wing if i hate the trd.
#14 |
Shorter of breath
Drives: a soft bargain
I'm 99% that the TRD covers the unused stock holes, but requires new holes of its own.
And some folks, reluctant to drill them, are using tape instead. |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
| Canadian FR-S options VS U.S.A's options? | Tino | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-06-2012 10:07 PM |
| Picture of the limited's key? | Elgancho | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 05-18-2012 07:01 AM |
| Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
