Old 11-27-2012, 11:14 PM   #29
White64Goat
Anybody have a mechanics stethoscope? Sounds like it's time for some probin and listenin..................
Old 11-28-2012, 08:25 AM   #30
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
What cnk said could be a possibility, i may try and use one of those at school and see if i could pin point the noise. The odd thing, again, is that it has something to do with the tune at least in my case. Maybe the throttle activity is adjusted or incremented, made more sensitive... somethings gotta be it.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 11-28-2012, 10:31 AM   #31
xjohnx
Grip>Slip
xjohnx's Avatar
In my experience it is definitely tune related. I know i had this noise on an older visconti flash, i'm currently running fa20club stg2 flash and do not have the noise. Once I find some time I'll switch back to the visconti flash and stock to see if the noise returns.
Old 11-28-2012, 11:41 AM   #32
gmookher
exh valves
Old 11-28-2012, 12:04 PM   #33
yomny
yomny's Avatar
I recall the first tune i had which was done locally didn't have that noise at all, then I switched and immediately heard it at my frost downshift. Hopefully John could do something about it.
Old 11-28-2012, 12:36 PM   #34
Surakusa
Mechanical Guru
Surakusa's Avatar
Drives: 2013 Scion FR-S (Argento) M/T
Use a long screw driver, it works great for a stethoscope.
Surakusa is offline   Reply With Quote
Old 11-28-2012, 04:41 PM   #35
yomny
yomny's Avatar
That long screw driver trick works
I've tried it at school. I was in my way home tonight on map1 which is tune plus stock rev limiter and the noise was pretty much gone, the second I switch to map3, there it was again. I sit think the rev limit has anything to do but once again this confirms something with a map.
Old 12-03-2012, 01:55 PM   #36
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
Sounds like detonation/knock to me from running too lean. The knock sensor will pick up the knock noise and retard the timing, but you will still hear it for a split second before it retards. I have the same issue with my car in between shifts. I've built many motors/cars for track over the years, most of them turbo, and it sounds exactly like detonation. That's why when you put the other flash back on there, it mostly eliminated it because it's most likely running richer with that tune. I don't think it's intake noise, because it should make that noise regardless of what tune you have in the ecu. You said it does it with the new flash/tune. These motors are very high compression from factory, and mixed with crappy 91 octane and a lean tune could create a condition for detonation/knock. I would be concerned, as it could do serious damage, like melt a piston, crack a piston ring, etc. I would firstly get your HPFP (high pressure fuel pump) replaced at the dealer under warranty to fix the cricket chirping, because you never know if that has anything to do with the lean condition too, it shouldn't, but I've seen some strange things with these cars. Have them put the lastest flash on there too, and if the mechanic at the dealer says the noise is "normal", go to a different dealer.
Mark Slide Squad is offline   Reply With Quote
Old 12-03-2012, 02:06 PM   #37
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
You think our engine can suffer from knock/pre-ignition at idle?
Rayme is offline   Reply With Quote
Old 12-03-2012, 02:19 PM   #38
Mark Slide Squad
It is quite unusual for detonation to occur when just free-revving (no load), but I have seen it before in the past with other cars that were excessively lean at low throttle conditions. Another factor is the VVTi. These motors have proven to have issues with the cam gears, and if a cam gear is out of calibration, it could be advancing or retarding the cam too much at certain throttle inputs. The flash can also affect the VVTi.
Old 12-06-2012, 12:58 AM   #39
Pake1
Drives: SWP Premium BRZ
Definitely have this same issue on my brz. Usually happens in the freeway without any shifting and sharp presses of the gas.
Pake1 is offline   Reply With Quote
Old 12-07-2012, 11:15 AM   #40
maj75
Drives: Blue FRS 6sp, 95 M3
Plug/remove the sound tube. It made a difference in the ticking noise in my cabin.
If it doesn't help, you can always undo it.
maj75 is offline   Reply With Quote
Old 12-07-2012, 11:22 AM   #41
Gen
Drives: Scion FR-S
Several of us noticed the same sound after installing the Crawford AOS.
Gen is offline   Reply With Quote
Old 12-07-2012, 09:55 PM   #42
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by brichard0625 View Post
Ive already brought this up to toyota/scion and the tech took the car for the drive admitted he heard the sound and his response was"all 6spd trannys make that noise"
You could own every dollar in the world placing bets on dealerships either not hearing the noise you brought the vehicle in for, or they do hear it and insist it is both normal and they all do it.
The new Genesis Coupe forums for example are ripe with posts about their noisy wastegate rattling. Same responses from their dealerships, "the noise is normal, they all do it". They've gone to making jokes about having a friend drive up with them next time in their "non rattling" GC and asking the tech to use a hammer so that his sounds normal by having a rattle put in.
Keep insisting, go over their heads if necessary, call corporate, try another dealer...multiple choices.
fistpoint is offline   Reply With Quote
The Following User Says Thank You to fistpoint For This Useful Post:
Jesse (01-07-2013)
Clutch Delay Valve? ashtray Engine, Exhaust, Transmission 72 11-18-2015 01:10 PM
Apexi SMART Accel Controller 808Raven Engine, Exhaust, Transmission 2 10-11-2012 08:54 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 10:10 PM
ecu face slap ToxicSneakers Scion FR-S / Toyota 86 GT86 General Forum 15 09-16-2012 04:59 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 07:17 PM
