#43 |
The Answer
Drives: Mazda 2
#44 |
Drives: 1985 P-Type
#45 |
The Answer
Drives: Mazda 2
#46 | |
Drives: fr-s!
The problem isn't with the tail lights themselves... I could take time out of my day each month to constantly replace the tail lights and it won't solve anything. Even after scion installed brand new tail lights, the same problem keeps occuring.. OVER and OVER again. Put it this way: having the dealership install new tail lights is like putting a band-aid over the real problem. Once they install the new ones, they work fine for a couple weeks before water collects... then I'm back into the same cycle where I have to get them repaired. The REAL problem is with the defective body of the car, which allows tail lights to collect condensation. It's pretty clear that there is an inherent design flaw that allows water to seep into the tail lights. I think we have established that at this point. So I would challenge you folks to step back and analyze the problem within that context. It's very misinformed for folks to come into this thread and say "LOL lemon law over tail lights?". I challenge you to understand that the root problem is the body itself, not the tail lights. I've gone through 3 different sets of lights so far and the problem hasn't gone away. I know everyone likes to have a knee jerk reaction and not actually think critically, so I feel the need to chime in and set the record straight. When I put down all my cash, I did not expect that my car would need constant service... but that is kinda where I'm at. It's extremely frustrating to buy a brand new car only to have a constant nagging issue with no end in sight, which is why I'm exploring the lemon laws. |
#47 | |
Drives: 12,000 miles per year
#48 | |
Drives: i walk the streets.
The likelihood of having a car flagged as a lemon and refunded/replaced over a tail light is pretty slim.
--- Deebeaux
--- Former '13 FR-S Turbo Owner |
#49 |
Drives: FRS Silver LS1 swapped.
I most have the Golden FRS,...no Cel's, no condensation,no shift problems....nada!,...but the point of the OP I understand,...for me it would be more of the lost time going back and forth to the dealer which is a un-accounted expense, it not being fixed the first time would have me trying a different dealership,....they are highly competitive, I would be sure to mention dealer A failed to fix the problem,...can you Dealer B show them how its done right.
#50 | |
Drives: fr-s!
I've gone through a bunch of tail lights and the problem still persists, so it's tough for me to agree with a statement like that. |
#51 | |
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Actually the problem is not with the lenses or the body the problem is with the foam rubber gasket between the lense & body. The nuts that hold the taillight lense to the body are being over tightened from the factory which pinches the gasket making points of entry for moisture. To op when the dealer replaced your taillamps did they also replace the gaskets?? SU003-04315 & SU003-02586 that should correct the problem. |
#52 |
Drives: Fast
They are replacing the defective tail light with another defective tail light.
You need a new one off the assembly line after they have fixed the problem at the suppliers. It's the same bad quality problems with the fule pump. They just replace it with another bad pump, not a revised version of the pump. In fact the same thing may be happening with the idle problem where members still have the problem after the cam sprockets and other components are replaced. This just shows how bad the quality control is at Toyota. Remember the sticking gas pedal? They refuse to acknowledge that it was a design flaw and blamed it on a mechanical part from the supplier. |
#53 | |
Sent from my flux capacitor using Taptalk |
#54 |
Drives: Supercharged Golf Cart
Did everyone skip my post? I'm pretty sure the TSB mentions that the installation procedure and/or over tightening is what is cracking the seal. It's not the light itself, it's the uneducated monkey installing them.
| The Following User Says Thank You to fistpoint For This Useful Post: | Demandred7 (11-28-2012) |
#55 |
Any time a taillight has a way for air (or water, for that matter) to get inside, condensation will eventually develop. It can even happen if you had a set of taillights sitting on a table in your back yard. It has nothing to do with the body of the car. If your car has gone through multiple taillight replacements, it's not because there is a defect in the body of the car.
#56 | |
| The Following User Says Thank You to White Shadow For This Useful Post: | Demandred7 (11-28-2012) |
| Why the (CA) lemon law seems useless, practically speaking | soconfoozed | Issues | Warranty | Recalls / TSB | 11 | 06-14-2020 09:13 AM |
| Anyone thinking about lemon law? | Accurate Race Shop | Issues | Warranty | Recalls / TSB | 16 | 10-18-2012 10:11 AM |
| Lemon? | grgonium | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 10-08-2012 11:13 AM |
| Lemon laws or equivalent ways to resolve issues with Toyota in Canada? | Ahz | CANADA | 2 | 09-11-2012 10:49 AM |
| Lemon FRS in Tampa FL??? | ICEBONEZ | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 08-27-2012 11:56 PM |
