Drives: Ultramarine FR-S 6MT
Metallic buzz over 4000 rpm?
Hey guys.
I was having some fun on the back roads today and noticed a new sound. There's kind of a metallic raspy buzz now, along with the engine sound of course. I have the car stock and wondered if it could be a bolt on that system, or,of it was maybe something else. Almost sounds like a bolt rattling loose, from approximately somewhere forward of the dash. Haven't focused on it enough to really pinpoint, and I am thinking of jacking it up for a look see in the morning. Anyone have a high rpm specific noise other than engine yell? Thanks in advance. |
#2 |
Drives: Toyota 86
Had a similar sound while cruising on the freeway under acceleration. However, the noise disappeared the next day... Been a week and all looks fine. I suspected something to do with the exhaust sound amplifier. Let me know what you find.
#3 |
Drives: Black Subaru Brz Limited
Funny i get the same noise when i pass 2000 and it get louder the higher rpms you go but it sometimes doesn't happen. It's pretty faint when driving normal but its still there. I was going to take it in but considering how it only happens every now and then it might have to do with gas. I'm still checking into it and it happened around 1200 miles. You are not alone sir. I thought it was the chime noise that everyone else got but it only happens when you press down on the pedal.
#4 |
Drives: AVO BRZ
I get this occasionally, when up shifting at high revs and wot, like a burst of a rasp for a moment before the revs drop. Exhaust shield type sound.
#5 |
Drives: 2013 Raven FRS
Same behavior here, and I run only 93 octane, so I doubt it's got anything to do with the fuel quality. Can cross that off the possibilities list I guess.
#6 |
Drives: Firestorm FR-S (MT)
Is this the sound?
[ame="http://www.youtube.com/watch?v=-zsPn6YMf5g"]2013 FRS buzz when clutch partially engaged/slipping - YouTube[/ame] Although he doesn't seem to know what it is either. |
#7 |
Drives: 2013 FR-S Hot Lava
I definitely do not have the same sound as in the video. Knock on wood!!!
Live to drive another day
| The Following User Says Thank You to whtchocla7e For This Useful Post: | winsometang (02-06-2013) |
#8 |
No that is real bad and I would of taken it in asap. The noise I get is not that loud its more of a light buzz . That vid sounded like he was drilling a hole in the dashboard and engine. I hope no one gets that sound cause damn...lol
#9 |
Sure it's not this issue.
http://www.ft86club.com/forums/showthread.php?t=17964 I fixed mine by installing the washers. When I had Toyota replace my transmissions the noise came back. I think they didn't install the washers again. Sent from my flux capacitor using Taptalk |
#10 |
You can lay on the ground and see if that shield moves by hand. On the passenger side.
#11 |
Nope, that one would drive me INSANE so I'm glad that's not it. The one I have now is kind of driving me batty, anyway
I may go digging for it this evening.I don't think it's the skid plate (though I may preemptively fix that one) and I went down the freeway at about 5krpm today looking for it. I could not get my hands on anything on the dash that muted it, but the shifter seemed to have a rattle of its own that changed when I grabbed it. Go figure huh? Blahhhh. Oh well. Part of the thrill yeah? PS, these are a hoot: ![]() I was blown away by the sport button - what a rush, and SO EASY to keep up with. NO correction needed. Poetry in motion, honestly. <3 But that damn rattle... |
#12 |
Any update on this. My washers are on there but still having this buzz.
#13 |
Drives: '13 BRZ Ltd WRB
Put your hand on the rear view mirror and see if the buzz goes away.
Mine rattles against the windshield. I swear it sounds like it's something loose inside the dash, but holding the mirror instantly makes it go away. I've stuffed a piece of folded paper between the top of the base and the windshield and that helps.
#14 |
Drives: WRB BRZ
if its like a high pitched noise im having some too
2013 WRB Subaru BRZ Sport-Tech -TRD intake -Perrin 2.5 inch cat-back exhaust |
| Installed Amp & Speakers, getting constant buzz | Gir | Electronics | Audio | NAV | Infotainment | 8 | 11-16-2012 03:28 AM |
| Continuous BUZZ/HUM from HPFP in ACC mode. | stevo_12v | AUSTRALIA | 2 | 10-22-2012 06:46 AM |
| Metallic based tint | DSOmegaX | BRZ First-Gen (2012+) — General Topics | 11 | 08-26-2012 03:15 PM |
| DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 | Redline360 | Brakes, Suspension, Chassis | 0 | 07-07-2012 01:41 AM |
| Canadian Pricing Prediction: Scion cheaper by $4000 minimum. | pastuch | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 11-03-2011 09:44 PM |
