Old 11-22-2012, 01:03 AM   #71
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Originally Posted by kmbkk View Post
Dang, Zach, you're making it hard to say no. Unfortunately I won't be able to get a before and after comparison, stock. I'm getting the car back with a turbo kit & exhaust installed and tuned. However, I don't doubt what you say. Thanks again
Awesome! It will be even better with the turbo kit!
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 11-22-2012, 09:18 AM   #72
gmookher
Has this been tested under FI application? Hint, I do testing, and product reviews, and am a paying early adopter, sent you pm.
Old 11-22-2012, 11:16 AM   #73
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Originally Posted by mike2100 View Post
1100 bucks to lose over 10 lbs rotational mass. That's bordering on reasonable
Dunno if anyone caught it but it's not a 10lb loss in rotational mass, I'd say pretty much all of the weight loss is from ditching the carrier bearing which the bulk of it isn't rotating...
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 11-27-2012, 05:00 PM   #74
RallySport Direct
You want an AT driveshaft? Here you go....
http://www.ft86club.com/forums/showt...679#post577679
-Zach
Old 11-27-2012, 05:46 PM   #75
Captain Insano
You are so awesome.
Captain Insano is offline   Reply With Quote
Old 11-27-2012, 09:45 PM   #76
Captain Insano
No I didn't catch this. Please elaborate as I thought and it appears as though all of the weight loss would be rotational due to difference in weight between CF and the OEM DS material.
Old 11-28-2012, 12:53 PM   #77
twincamRob
twincamRob's Avatar
Take a look at the stock driveshaft setup. In the middle, well more towards the front, there's a large bearing that bolts to the body. That's the carrier bearing and it weighs a good bit. Since this piece doesn't rotate but is still a part of the driveshaft it is easy to make a lighter shaft when you make it a one piece, or, without a carrier bearing. But the weight loss isn't as beneficial as you would think, obviously.
Robbie S.
-13 FR-S
-12 H-D 48
Old 11-28-2012, 01:29 PM   #78
Captain Insano
So you think all 10 lbs of weight loss is in the carrier bearing. Not a couple pounds, but all 10.
Also besides weight, you don't think the elimination of the driveline friction associated with that bearing is a good thing?
Old 11-28-2012, 01:57 PM   #79
RallySport Direct
I see what you are saying, but I respectfully disagree.
I was not able to remove the carrier bearing to weigh it, but there is not much to it. It is just two metal rings (1/8" thick each) with a bracket and rubber in the middle. I estimate the carrier bearing to be about 2 lbs. (If anybody has the actual weight, then please post it.)
The heaviest parts around the bearing are going to be the U joint and flanges, which are part of the rotational mass. The one piece design of the CF shaft eliminates the middle U joint, flanges and carrier bearing, which reduces overall weight as well as rotational mass.
-Zach
Old 11-28-2012, 03:50 PM   #80
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
@ RallySportDirect
Silly question I know but what are the operational temperature limits? That is, at what ambient temperature is there a reduction in the strength of the shaft?
Old 11-28-2012, 04:18 PM   #81
RallySport Direct
@ RallySportDirect
PST has not found any ambient temperature limits or reduction in strength. The only temperature issue would be the exhaust being routed too close to the shaft and overheating it (approximately 450*F). These shafts are very durable and I have not seen a problem with any of them.
-Zach
The Following User Says Thank You to RallySport Direct For This Useful Post:
Captain Snooze (11-28-2012)
Old 11-28-2012, 04:42 PM   #82
TuxedoCartman
Drives: '13 86
-Zach
Is the stock exhaust too close, in that regard? I notice in a lot of pictures the midpipe sits awfully close to the driveshaft.
TuxedoCartman is offline   Reply With Quote
Old 11-28-2012, 05:46 PM   #83
RallySport Direct
The stock exhaust and almost all aftermarket exhausts will not affect the driveshaft. The shaft will not see much heat while driving and the exhaust will not be warm enough to have a negative effect while idling.
-Zach
Old 11-28-2012, 06:10 PM   #84
TuxedoCartman
Drives: '13 86
-Zach
Cool. I'm sold... order placed!
The Following 2 Users Say Thank You to TuxedoCartman For This Useful Post:
Jeff86 (11-29-2012), RallySport Direct (11-28-2012)
PST Carbonfiber Drive Shaft In Stock and Ready To Go!! RallySport Direct Transmission and Driveline 27 11-18-2012 02:39 PM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 05:44 PM
HELP...Drive Shaft/Rear Tire Shutter UM FRS Issues | Warranty | Recalls / TSB 11 09-05-2012 12:14 PM
Does FRS come with Carbon drive shaft? STi88 Engine, Exhaust, Transmission 30 07-30-2012 02:40 PM
