Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
Battle plan for 200+ whp n/a - Tuners welcome inside
So I think I'll be doing the following to see how far it can go, and then eventually go turbo. Partially to try some things, partially to see if I like the power over the turbo anyway. I'll probably do it in 2 stages (seperated by ECU reflashes basically)...
First stage... E85 FA20/FT86-SF tune Injen intake - installed Perrin Pulley - installed Second stage -UEL Borla headers (sorry but I love the sound) -Berk Cat-delete pipe - cheap and effective -Probably either 2.5in piping with a bottle resonator to a berk style dual track pipe (maybe with another bottle res between the tips) or stock exhaust with a berk-style twin tip track pipe -Ported stock throttlebody -Ported Stock intake manifold -Custom dyno tune on E85 I'd love to see this make 220-230whp. But I definitely EXPECT to see 200whp (especially since we're close to sea-level here) As far as the ported stuff goes, plenty of people do it for other vehicles so I'll probably look into people who have done it for me in the past. Specifically my LS2 90mm t-body I had ported with great results... Might call him again. What do you guys (specifically tuners) think?
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech Last edited by seven; 11-29-2012 at 07:50 PM. |
#2 |
Drives: Whiteout FR-S
Motiv overpipe and test pipe but if you want the Borla headers you might as well go with their full system.
stock manifold is plastic, i would wait on a complete replacement. |
#3 |
Drives: 2013 subaru brz
I wouldn't even worry about that intake till some more options come out. My guess is you would change down the road for a different one.
#4 | ||
Tells it like it is
- Many people port stock plastic intakes as well. I'm using the LSX community as an example but many do it
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#5 |
Drives: Scion FRS
None of the intakes on the market are worth it right now and i think the throttle body is more than large enough for a motor this size.
I think cams, Header and e85 are what will make the big power. |
#6 | |
Tells it like it is
While I do agree that cams would likely help with power significantly. I don't plan on cracking the seal between the heads and the block, the idea is a strictly bolt-on ordeal.
#7 | |
Drives: '06 AM V8V Coupe
If you cut between the pairs of runners on the manifold, enlarged the inner diameter from that point to the "plenum" (that you're effectively enlarging), and then joined the cuts, you'd have shorter runners, which could increase the high rpm torque. |
#8 |
Vtec Jesus
I fully believe that 240 wheel would be easy on this engine once people start tapping into cams and head work / port work.
#9 |
Drives: 2014 Widebody Cosworth FR-S
If you are going to get creative with it, then try running ITBs. It's only money, right?
-Zach |
| The Following 7 Users Say Thank You to RallySport Direct For This Useful Post: | 20valvewynn83 (11-22-2012), dabocx (11-20-2012), finch1750 (11-20-2012), raz0rbladez909 (11-22-2012), soros151 (11-20-2012), Spartan65 (11-22-2012), zohare (12-26-2012) |
#10 |
Most n/a cars need headwork before they make significant power. You're better off getting tires and suspension mods so you can be faster around the track. The manifold and throttle body should be large enough. Lighten up the car some more. What is this car used for? If you're looking to make 1/4 mile times you bought the wrong car. Do these engines have TGV? You could delete those if it does. ITB is another route like rallysportdirect says. It would be interesting
#11 | ||
Tells it like it is
1- I don't know of anyone making them or anyone willing to fab it for me 2- If I'm going to go turbo anyway (eventually) I'd have to rip them off (most of the other stuff besides the header I could keep) 3- Yeah it is definitely an expensive proposition. Someone should do it tho. Quote:
![]() I don't care about 1/4 mile times, If I did, I'd have kept the 500whp C5 I owned before the FR-S. I'm legitimately curious about how far you can push the bolt on envelope (especially with E85), also looking for the learning experience to with dyno tuning, etc. Just trying to further the community with some experimentation is all ![]() As far as TGVs, not sure if the FA platform has those, I'll have to look at the breakdown Crawford did again, the might have said.
#12 |
That Guy
Drives: 2013 asphalt FRS MT
No TGV's.
I understand the desire to remove breating restrictions, but the TB is 70mm IIRC. |
#13 |
| Bought it Friday tracked it Sunday!! NC Miata battle video inside... | track_warrior | Tracking / Autocross / HPDE / Drifting | 311 | 02-28-2014 09:31 AM |
| When do you plan to get your BRZ? | switchlanez | BRZ First-Gen (2012+) — General Topics | 33 | 08-16-2013 01:25 PM |
| Reputable tuners in GTA | Philly | CANADA | 10 | 07-11-2012 06:38 PM |
| Tuners Delight: 2013 Scion FRS | FRSDREAMER | Scion FR-S / Toyota 86 GT86 General Forum | 158 | 03-22-2012 08:09 AM |
