Car wont start? Anyone else?
Hello, every so often it takes a few tries to get the car started...I assume this isn't normal on a new car
![]() ... happen maybe 4 times total since I bought it in late Aug.
ScionFrsFan
#2 |
That guy
Drives: Ultramarine mt FR-S
If it's manual, make sure you're not pressing against the gas pedal. The engine floods easily.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#3 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Check your battery voltage, could be a bad battery or bad connections.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#4 |
Please define "a few tries"...
Do you mean it turns over several times before firing up, or are you turning the key and just getting nothing, clicks, weak/slow start, etc? |
| The Following User Says Thank You to wheelhaus For This Useful Post: | guybo (07-29-2016) |
#5 |
Drives: 2014 Wrb Brz limited 6m
Happened to me once so far. Let it crank for about 5 seconds. Cranked strong but wouldn't turn over. Cranked second time for about 10 seconds. Cranked fine but again didn't fire up. Third try must have been the charm bc it fired right up. Hoping it was just a fluke.
#6 |
It's a auto and yes I turn it over and nothing, it tries to start put doesn't lol. I hope it was a fluke too! ... 4 times already.
ScionFrsFan
#7 |
Drives: several
+1 on checking the battery and connections. If it's that, then eventually you will get stranded.
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale) "Simplicate and add lightness." - Gordon Hooton |
#8 |
Drives: 2017 Subaru BRZ PP
The Evo X came with those same Panasonic batteries and we had problems starting almost every car with them. When we replaced them with an Optima battery, the problem was solved. I'm not sure if it really is the battery but having worked for a dealer that dealt with those batteries, I wouldn't be surprised.
Toyota + Subaru =
| The Following User Says Thank You to Bristecom For This Useful Post: | Freeman (11-16-2012) |
#9 |
First 86
Drives: Scion FRS Argento Automatic
Try giving it a moment once you turn the key to the first position for the fuel pump to prime the injectors. I've had this problem occasionally.
Life is short...NO BORING CARS |
#11 |
The Answer
Drives: Mazda 2
It happened to me 4 times in 45 days...it's been a long time since the last time it did it.
The engine cranks but takes about 4 seconds to start vs the normal 0.5-1 seconds. I'm not making a deal about it yet. |
#12 |
Drives: 13 GTI
Happend to me 1 time in 1800 miles.
#13 |
Drives: FR-S Hot Lava (AT)
Has happened to me once also, 600km.
since then i have waited after i have turned the key to the first position for the fuel pump to prime and it has not happend since. |
#14 |
Drives: frs
got 4000+ miles - happened to me about 3 times so far, exactly as you described
| After Market Problem Signals Fuse Popped- Car Wont Go into Gear | ScionFR-S | Issues | Warranty | Recalls / TSB | 14 | 11-20-2012 02:34 PM |
| Car Won't Start | schtebie | Issues | Warranty | Recalls / TSB | 25 | 10-15-2012 04:06 PM |
| trunk wont unlatch | bakerr6 | Issues | Warranty | Recalls / TSB | 9 | 09-24-2012 01:32 AM |
| GTS come with push start? | adam | AUSTRALIA | 13 | 06-04-2012 03:28 AM |
| Car won't start, no spark? | #87 | Other Vehicles & General Automotive Discussions | 5 | 12-19-2011 12:29 PM |
