Old 11-12-2012, 11:30 PM   #15
wootwoot
Drives: FRS
I am worried the stage 2 tune may lean the mixture out a bit more.... perhaps a bit too much for my liking... Any dyno and AFR info?
Old 11-12-2012, 11:34 PM   #16
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
Originally Posted by GTSEightysix View Post
im clocking that at 8.1 -8.3 sec 0 -100kmh
i was hoping more for 6.9's to keep up with GTI's etc..
Nop wrong it's a 7.25, I timed with after effect frame by frame.
And it's a false start as you can see the bad lunch. And the video is on Perrin tune not FA20. So up to now I would say jsut by the feeling of it that I feel the FA20 is twice the power of Perrin, but wait Perrin is only beta for now will see the end result when both are done testing. And the ultimate test will be on dyno.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 11-12-2012, 11:36 PM   #17
WatchmaN
WatchmaN's Avatar
Originally Posted by nonicname View Post
what is the difference between stage 1 and this? just the intake?
yep stage 2 is for intake and exhaust but mostly intake
Old 11-12-2012, 11:46 PM   #18
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I have a Stage 2 with no intake, i just a have a drop in filter and test pipe. Catback is coming soon but he will adjust it for you if you send the logs in.
Old 11-13-2012, 02:57 AM   #19
Le86
Drives: Asphalt FR-S
Originally Posted by WatchmaN View Post
yeah exactly, for the pull it would'nt be good cause i'm on winter tires with stud. With the tune now with all controls off even in fourth gear my tails gets happy on a WOT so its pretty dangerous. but be sure you gonna have a minimum of a sec of your 0-60.
To give you an idea i'm also beta testing Perrin tune which is not finish cause jeff found something wrong in the data reading with the intake and with even with that when I flash my car with it I droped .75/sec on my 0-60 from stock ecu. Go see the video of that but you will see that there's something wrong at the pull off. And FA20 tune I don't have that at all and i'm pretty sure ill drop another second from the unfinish Perrin tune.
Was this video with the Perrin or FA20 tune?
Also, I'm sure you have noticed the harsh rev limiter, cutting power and such on the stock tune. It really bothered me when I was at the track (drifting) and it would literally bounce off the limiter once and lost power unless I shift. My question now is: Do either of these tunes remove the power cut at rev limiter, or at least raise the limit?
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 11-13-2012, 04:14 AM   #20
WatchmaN
WatchmaN's Avatar
That video is on Perrin, and the rev limiter is raised to 8000rpm, have to ask for cut off but pretty sure it would be doable.
Old 11-13-2012, 08:27 AM   #21
WatchmaN
WatchmaN's Avatar
Alright so fa20tune better launch I can see a 6.9 0-100kmh or 60mph hehe
Not bad .. Not bad at all
Yes pretty sure i will be in the 6s area, for sure i lost time with fail start. Don't forget sea level is also a factor. No promess but i might put by my summer tires a do another run cam in hand to show you guys and for my self lol cause i m curious to see how fast it is with FA20 tune.
Old 11-13-2012, 08:30 AM   #22
travace
travace's Avatar
Drives: Scion FR-S
DO WANT
travace is offline   Reply With Quote
Old 11-13-2012, 09:37 AM   #23
Opposed
Drives: 2013 Asphalt FR-S
It would have to be better than that. Some auto mags have hit 6.2 0-60 mph stock. 20+ whp should cut that into the 5's for sure with a good launch.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-13-2012, 10:16 AM   #24
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Jokes apart the FA20 tune is funtastick, and their sevice is on par with the tune, I highly recommend it.
Are there any good driving videos of the Stage 2 tune?
Old 11-13-2012, 10:33 AM   #25
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
0-100km/h is 0-62mph so you would have to change gear to third for that on OEM car.
That's why every test of 0 to 100 km/h are around 7,6 - 8 second in the euro mags
Mars2 is offline   Reply With Quote
Old 11-13-2012, 10:53 AM   #26
Opposed
Agreed, but not with the raised limiter. You can hit 62 in second.
Old 11-13-2012, 08:28 PM   #27
WatchmaN
WatchmaN's Avatar
To tell you the truth they said it but i've never seen it. Or maybe they are a lot better shifter than me lol. And yes 0-60 or 0-100 is done in second gear with the raise rev limiter at 8000rpm, it's all in the vidéo on perrin tune i've made.
Look at this guy he did about 9.5 on stock
[ame="http://www.youtube.com/watch?v=6a3rBVXTs9g"]2013 Scion FR-S 0-60 mph speedometer (3k launch & 2nd gear chirp) - YouTube[/ame]
Old 11-13-2012, 08:39 PM   #28
ATL BRZ
ATL BRZ's Avatar
Video of the fa20club stage 2 would be great
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 05:58 PM
FA20CLUB.COM ECUTEK TUNE hayleybeaners Engine, Exhaust, Transmission 21 11-13-2012 10:52 AM
Ecutek tune in Hampton Roads draggin_az Mid-Atlantic 2 10-28-2012 11:32 AM
Heading to NC - Come get your EcuTek tune from Visconti ! Visconti Southeast 16 09-18-2012 09:15 AM
Can DBW tables be changed via Ecutek tune??? Norkoastal Engine, Exhaust, Transmission 1 09-11-2012 07:51 PM
