Old 11-10-2012, 10:48 AM   #1
_F-R-S_
Drives: 13 whiteout scion frs
Buying sways..
Whiteline sways with adjustable extenders with bc coilovers but heres my question what else will i need o make this a complete package. How to make everything really work together with veveryhing. Also aany suggestions on good control arms with all this
_F-R-S_ is offline   Reply With Quote
Old 11-10-2012, 11:07 AM   #2
Racecomp Engineering
That's all you need. We're running the Whiteline 20mm front and 16mm rear bars on our car right now with protoptype RCE/KW Tarmac 2 coilovers and it is just about perfect.
- Andrew
Bluecille (11-11-2012), _F-R-S_ (11-10-2012)
Old 11-10-2012, 11:15 AM   #3
_F-R-S_
Appriciate it thanks alot!!
Old 11-10-2012, 11:18 AM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You need rear control arms for camber correction? I have SPC which are inexpensive and do the job, the new Whiteline ones look amazing but i'm sure you will pay for it.
Old 11-10-2012, 05:19 PM   #5
gmookher
seeking 22/16
Old 11-10-2012, 06:19 PM   #6
JoeBoxer
JoeBoxer's Avatar
Originally Posted by gmookher View Post
seeking 22/16
Just get the Whiteline 20mm adjustable front and put on the hard setting. 20/16 seems to be fine.
Old 11-10-2012, 08:17 PM   #7
gmookher
Joe, what Tires you on?
same with
- Andrew
what tires, curious?
Old 11-10-2012, 08:58 PM   #8
_F-R-S_
Adjustable is perfect that way change it every track day
Old 11-10-2012, 10:35 PM   #9
JoeBoxer
JoeBoxer's Avatar
Nitto motivo, regretting it too I should have went with something more grippy.
Old 11-10-2012, 10:47 PM   #10
gmookher
as you address higher speeds, higher grip, I think the 22mm set soft may be interesting. some of this is gonna be about car setup dialability; ie, being able to switch to a race compounds. Interesting in trying both 20 and 22 after this thread
Old 11-11-2012, 12:00 AM   #11
JoeBoxer
JoeBoxer's Avatar
I am probably just going to get the fixed 20mm front and the adjustable 16mm rear.
Old 11-11-2012, 09:06 AM   #12
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Solid bars right?
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 11-11-2012, 09:15 AM   #13
JoeBoxer
JoeBoxer's Avatar
Originally Posted by armythug View Post
Solid bars right?
correct, hotchkis and eibach are 25.4/19 but they are hollow...
Old 11-11-2012, 09:36 AM   #14
ironchef
ironchef's Avatar
Drives: GLI
Noob question.
How important are sway bars for the person who DDs and does maybe 3-4 HPDEs a year?
ironchef is offline   Reply With Quote
If you are buying a BRZ how old are you? blackmist27 BRZ First-Gen (2012+) — General Topics 205 03-07-2013 08:18 PM
Im buying one. Griffdawg Scion FR-S / Toyota 86 GT86 General Forum 10 06-19-2012 01:12 PM
buying BRZ or FRS DIG1992 NY / NJ / CT / PA 10 03-11-2012 11:26 AM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 09:01 PM
