Old 11-08-2012, 02:58 PM   #1
Synack
Boosted
Synack's Avatar
Drives: Sideways
Burning oil? N/A
Anyone else having issues with burning oil? I know I'm boosted now but I was burning oil before I went boosted. I'll probably have to get it fixed out of warranty LOL. Of course I expected this, but if it can be done under warranty and has nothing to do with the turbo that would be nice.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 11-08-2012, 03:09 PM   #2
dsgerbc
Drives: BRZ(sold), STI
How much are we talking? All OEM turbo-Subarus eat oil. 1qt between oil changes is normal. What's your consumption?
Old 11-08-2012, 03:23 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
and how hard are you driving, are you doing an autocross every other week?
Old 11-08-2012, 03:59 PM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
After 1000 mile break in I drove it pretty hard. I'm talking like 2 quarts per month here.
Old 11-08-2012, 03:59 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Boxer engines will blow oil out the PCV vents in the heads during hard cornering because the heads are horizontal. If you're doing regular track days or AutoXes, you might want to get a catch can if you don't have one already. You'll likely see your consumption go down.
Old 11-08-2012, 04:23 PM   #6
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
if you didn't bed the low-tension rings in correctly very early, it will burn oil. Just like all other subaru's. If you break them in with a lot of cylinder pressure and engine braking to force the rings out to the bore, they use very little oil. You have a very small timeframe to bed the rings properly, miss it and you'll have an oil burner like a lot of the EZ's out there.
JP is offline   Reply With Quote
Old 11-08-2012, 04:32 PM   #7
fistpoint
Drives: Supercharged Golf Cart
So you recommend the "drive it like you stole it" break-in method?
fistpoint is offline   Reply With Quote
Old 11-08-2012, 04:37 PM   #8
serialk11r
Drives: '06 AM V8V Coupe
Rings don't have much to do with rpm, I think he is suggesting to use high loads often and a lot of engine braking, but not high rpm.
Old 11-08-2012, 04:40 PM   #9
JP
Backyard Fabricator
you don't need to use high rpm as stated above
Old 11-08-2012, 04:48 PM   #10
frs23
frs23's Avatar
Drives: FR-S H Lava
Hey I think it worked for me
frs23 is offline   Reply With Quote
Old 11-08-2012, 04:59 PM   #11
TemeCal
Drives: 86
Just curious (serious question)...
If you knew it was burning this much oil before you turbocharged it, why didn't you get it fixed/looked at while you had the warranty?
TemeCal is offline   Reply With Quote
Old 11-08-2012, 06:14 PM   #12
JP
Backyard Fabricator
dealer would most likely tell you to keep driving it any the oil consumption will improve :p
There's been FB20's sent in to reputable subaru engine specialists over here for warranty reports to be written investigating their high oil usage, and Aus doesn't have THAT many F-engines on the road yet.
Burning Oil? RandomHero Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 10-04-2019 04:56 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
Exhaust build up/ burning oil Bu-Tang Issues | Warranty | Recalls / TSB 7 04-04-2013 12:51 PM
